Cruiser Varyag 1901 by Valeriy V - FINISHED - scale 1:75
Amazing work!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Share on other sites
Impressive work Valery, I have a question for you; you will cover the brass parts mounted on the model with something so as not to oxidize?
Edited by dj.bobo
Link to comment
This kind of holder to fit into the toolpost can be bought at reasonable prices:
For light knurling in brass a simple holder to feed straight into the part may be sufficient.
Be aware, that knurling forms sort of triangular ridges - gear teeth look somewhat different, with sort of vertical flanges and a space at the bottom between the teeth.
Edited by wefalck
Link to comment
1 hour ago, Roger Pellett said:
Thanks Valerie,
The project that I am working on will require a lot of gears.  I just bought a pair of knurling cutters on eBay.  Now I need to build a fixture to hold them.
Roger
Roger, I'm glad to help you.
Please note that with the help of rolling knives, you can only create an imitation of a gear.
Real working gears must be manufactured using a different technology.
Edited by Valeriy V
Link to comment
Thanks , Dj bobo !
To protect against oxidation, brass can be coated with transparent nitro lacquer, zapon lacquer.
Link to comment
Valeriy,
They will just be imitation gears- deck winches, cargo winches, and gears for turning vowel ventilators.
That guy’s fixture is really clever.  I have a large heavy gauge aluminum angle. I’m going to use it to make a knurling fixture that mounts on the cross slide of my lathe; similar to the one shown in the Sherline catalog.
Link to comment
beautifully done - as ever Valeriy.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Valeriy, phenomenal realism. It's always a pleasure to observe your work.
Link to comment
No words are adequate to describe your work Valeriy!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Terrific work. I love the panelling detail inside the wheelhouse. How much will one be able to see once the model is complete?
Link to comment
16 hours ago, amateur said:
Stunning as always.
Did you use your computer and printer to do the 'tiling' in the wheelhouse?
Jan
Jan, linoleum for the floor is printed on a printer and covered with adhesive tape on top.
To avoid excess shine, the tape is treated with fine sandpaper.
Link to comment
Did they really had 'inlaid' (as it was called) linoleum on Russian ships at that time, rather than the sober 'battleship' linoleum (which was also thicker as the domestic one), that usually comes in a dark reddish brown ?
Link to comment
In the "Varyag" wheelhouse, the linoleum pattern was just that.   :)
Link to comment
It is interesting that the binnacle was tied down with turnbuckles. This is a carryover from sailing ship days when the compass/binnacle was "portable" and normally tied down to eye bolts in the deck with lanyards.
Link to comment
What beautiful engineering. What is the purpose of the foot switch at 1 O'clock?
Edited by Keith Black
Link to comment
Fabulous work Valeriy!  I know I've said this before, but your work is so precise, clean and meticulous.  I also know that it takes dedicated hard work to achieve such a result.  I've been looking at your brass and wood capped railing and it appears flawless.  Bravo!
Gary
Completed Scratch Builds
Link to comment
Lovely work Valeriy. Vey impressive rails - so crisp and clean.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Amazing work!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
