Now fully assembled with most of the PE Brass installed.  Still working on installing the deck railings on the main deck. Some touch-up paint, apply decals.
Photos below: IMG_6669.JPG.5f526ec462f6667e4d4a2d8032c048c0.JPGIMG_6670.JPG.b4285b00658a4f523f88c35220721a58.JPGIMG_6672.JPG.efa6d62c2a31fbad4f4adcd8dd088429.JPGIMG_6671.JPG.97e2f035c79f555be15700572a8bcd83.JPG
Looking good, Jack.
Nice job Jack. The camo really makes her stand out while still looking authentic.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
That's a quicky, mate. If you want to touch up brasswhich has been added to your build you might want to use Liquid Surface Primer from Tamiya to cover the brass first and then add the colour. I like the stern part of the ship, there is quite a lot to see.
Carl
Expand
Thanks Carl, yes I had a lot of free time to work on it every day. RE: the primer - the only non-rattle can primer I have is Tamiya gloss white, I have to find some flat gray primer. I've tried the gloss white and it doesn't work to well.  The other problem I have is the paint filling in the gaps between the rails, even the rattle can primer does this and I spray from a distance and keep the can moving left to right as I spray but it still fills in the "holes" with paint.
  On 2/28/2019 at 11:14 PM, CDW said:
How did you like the Gator Grip glue for your photo etch?
Expand
Thanks CDW..   I found the Gator Grip worked well if the two pieces being mated were in a horizontal or near horizontal plane but not so well in a vertical plane. Example;  trying to attach the ladder to the mast the Gator Grip did not hold long enough to set, the ladder kept falling over. Same with the railings around the upper and lower decks. The Gator didn't have enough holding power to keep them vertical until the glue set, so I had to resort to medium CA for these brass parts. Otherwise it was pretty good.
General comment on painting - I'm still trying to work out the right combination of paint to thinner for my airbrushes - so far all I get is a clogged brush so I resorted to hand brushing the past 3 models. Still working on the airbrush.  All of the plastic Armor (Tamiya kits) I did before were done with Floquil paint which was easy to mix (for me at least), these acrylics are a bit more difficult (for me) but they do brush on nicely.  I'm also experimenting with different brands.
I used Lifecolor Acrylics for my Warspite build  and brush painted all the top and hull with them,  my tips for this was diluting the paint 50/50%  with distiled water - then apply thin layers that at first look patchy,  a dried inbetween layers and soon the thin layers smoothed  out with a good flat layer.
My rules to myself was  - to work in controled areas,  not to load too much paint onto the brush,  keep the area to be painted clear from dust (drying with a hairdryer helped this),   and not to go back over an area when it was  becoming tacky during its drying.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
With Vallejo I thin even the Model Air. I'd rather spray an additional layer than having to unclogg the brush. Tamiya I thin down 50%, same reason. I only use the brand's thinner. I am still working out how I can spray lifecolour, since I can't get it to work properly with my brush H&S or Black Bull both gravity brushes
Carl
As a thinner for Tamiya paints as well as the Mr Hobby/Mr Color line of paints, you will not find a finer thinner than this:
https://spraygunner.com/gsi-creos-mr-color-leveling-thinner/
It's fabulous. Mix 50-50 with the paint.
As an alternative, use common rubbing alcohol (60% alcohol or higher) as a thinner. Works well with Tamiya paints and I use it all the time for a quick drying time. Mix 50-50. Cheap and easy to find.
OC, Carl, CDW,  thanks for the info.
OC, I use LifeColor too , don't dilute like you do but  I do dilute with tap water,  I put a small amount of paint on a pallette, dip the brush in water then mix with paint till I get the consistency I want, then brush onto  model.
Expand
I diluted in the jar  - if you have an empty jar I just put half the original paint in and top up with distiled water, then just thoroughly mixed it, that way I have a half jar of un diluted for small areas than need a thicker bit of paint, and a full jar  - diluted.
OC.
Current builds
Completed works.
  On 3/1/2019 at 7:22 AM, RGL said:
What’s next?
Expand
I think I'm going to reduce the stash by building the 2 Testors/Italeri kits of the F117A and F19 Stealth Fighters which have been sitting on my shelf for ages, then I'll go back to boats. ;):D
Expand
Now they will be cool  - what scale are they?
OC.
Current builds
Completed works.
  • 4 months later...
 Jack -- just happened to pick up the build on the England -- great job -- but my comment is on your picture of a Corgi -- I've seen it on several other build logs and always wanted to ask. I know this is WAY off topic -- do you have a Corgi? I've had three, lost the last one last November and still grieving over him. I've developed OCD -- Obsessive Corgi Disorder -- having had the three, so just curious as to yours.
Thanks.
Allen
Hi Allen, off topic is okay!
Yes, the photo in my Avatar is a Corgi. She is female, age 13, classic Corgi coloring red and white. We got her as a 6 month old puppy directly from a breeder.  At the time we got her she joined our 2 other Corgis, a 6 year old male and 6 year old female,  bringing the pack to 3 . The older two were semi rescues, we got them from 2 different breeders who stop breeding them at age 6. Both were black headed tri-colors with predominately black bodies, a rare coloring.  So we had a male and two females, all neutered of course. The male lived to age 16, the female to age 14. We had another red and white female, a "true"  rescue at age 6 but she died after 2 years of a rare muscle cancer, so we got 2 more. We have had 4 in total.  The male came first, then the female rescue who died, then the 2 females.  It was great fun having 3 at one time, especially when we went to Corgi gatherings with 2 black headed tri-colors in tow, both from different breeders and blood lines.  Made a lot of the breeders a little jealous that we had two black headed tri- colors,  a male and a female.
   [For the non-breeders, to get a tri-color Corgi takes a recessive gene in one parent ; to get a black headed tri-color takes a double recessive gene in both parents. As I recall from talking to the breeders who sired our dogs]
Here's photos of the 4 Corgis
Derby (male)
Pepper (female - died of cancer 2 years after we got her)
Fini (female)
IMG_0058.JPG.e42b299dcd04e15040a4467b648a0c8b.JPGIMG_0060_2.JPG.98cd3dbe7c144000cd62d0704b948496.JPG
Sunny (last of our Corgis - still with us)
That's her 7 inch cloth frisbee by her front feet
Edited by Jack12477
  On 7/20/2019 at 9:12 PM, cog said:
That explaines a lot ... Jack has a dog, you have labs :)
Expand
LOL
Greg, our 3rd Corgi Fini was actually of New Zealand blood line, bred to NZ/UK breeding standards. She was shipped to a breeder on US west coast then to another breeder (partner) on east coast.  She was much smaller than those bred to US standard. She never got past 20 lbs US in weight, whereas the others were 25-30 lbs US in weight. We got her from the east coast breeder at age 6.
  On 7/20/2019 at 9:03 PM, RGL said:
For the first time I actually have a stash! Im hoping they release a USS Langley but I have two little kits I bought off e-bay to do in shore leave.
Expand
Iron Shipwrights makes a resin USS Langley in 1/350 scale.
Building:
1:200 Russian Battleship Oryol (Orel card kit)
Yes, that’s the unfortunate part.
 I was looking at Taubman’s a while back.  They have a plan set for the Langley.  I thought about doing a POB scratch build of it.  It is on my eventual to-build list.
I’ve wanted one ever since I saw the model at the NAS Pensacola Museum.
That would be an awesome build!
Building:
Expand
I paint alot with enamels but am using some acrylics but your 50/50 is my rule sometimes a touch thinner not much.A modeler on another site who does A/C and the best painter I know used Tamy acrylics alot and said your consistency should be that of milk.Nice build!and not an easy scheme.
Edited by Javlin
