Greetings MSW.    I am back after completing Chuck's Confederacy scratch after a 7 year build finished in 2016.  (he did give me some cheats on the figurehead and some sculptures....)  She is an incredibly designed kit - I learned a ton - and ironically it was built in several apartments while single with nothing but a crappy Delta scroll saw and an old Preac table saw, along with Xacto knifes.  Jeff Hayes perfectly milled wood helped a ton !  And then I got married and my twins were born which slowed down everything in 2013.
I have always wanted to build a fully framed French ship and collected a full library of Ancre subjects (the 74 Gun Series, Monographs of the 74 timbers, Commerce de Marseille, and La Renommee).    So  after buying a house in the suburbs - I built out a workshop.  I gathered the necessary tools over the past few years -  Byrnes Table Saw, Thickness Sander, Disc Sander,  Proxxon Mill, Proxxon Planer, Wood River spindle sander and a Dewalt full size table saw to reduce my flitch of pear wood to usable size.  I have also collected Lie Nielsen chisels and its Lee Valley Sharpening system.
So it seems I can't fail right ?
I did...
Call it being a Dad of young twins or just sheer intimidation.  I could not complete the stem for La Renommee to my standard so I quit.  I then decided - maybe a simpler subject would work - so I began construction on La Jacinthe in 1/32 scale.  Not only did I have issues with consistency of enlarging the plans (thanks FedEx/UPS store) - I grew bored with its construction - I have already successfully completed several plank on bulkhead models.
So I returned to the enlarged plans that Delacroix sent me for Le Gros Ventre in 1/36 scale - a noble subject - with nice lines, simpler sculptures and yet a serious challenge.  I have heard from several members on this forum that building fully framed in larger scale is easier...
So here is the start of my build log - it will be messy showing all of the mistakes in order to build a fully framed model.  Here are my results after 2 months of work - the last photo showing my useable parts.
Good for you to be willing to go up the learning curve, Chris. There will be scrap (with and without the 'c'!), but the end result will be well worth it.
Hi Chris,
Glad to find you with a whole new subject !
A beginning certainly, but you have to give time to time and have fun, so wholeheartedly with you for this new beginning !
Patrick
No more confusion caused by many models built in parallel. Let's hope this one will turn out great! The start is pretty good anyways.
Is that still your french pear? Looks very neat!
Edited by Mike Y
Thanks guys - yes Mike - it is my French Pear - cuts beautifully.
This really is a learning curve - I'm having to relearn how I build using for the most part the Byrnes tools, the Proxxon Mill and chisels.  I am finding the larger scale 1/36 a little more approachable.   So far its really challenging and I have yet to complete the keel and its assemblies !
I'll pull up a chair also, Chris.  A challenging project, learning curve, and and fun.  What more can we ask for?  My only suggestion is about the scrap box.. make if bigger than what you think you'll need and don't toss anything into the burn bin or trash.   I've found uses for most of the wood that when into mine.
Thanks John and Mark - you were with me every step of the way for Confederacy !  Don't worry Mark - Im keeping all of my "precious" French Pear scraps- since the ship will almost entirely be constructed out of it - Im sure I will find a use for most of it at some point or another.
  • 10 months later...
  • 2 years later...
Greetings Group,
I restarted this build in earnest beginning of August and have completed 20 frames (roughly 1/3rd of the total frames).  The frames have not been sanded or bias added, simply assembled (each frame is 12 parts and stacked) with some extra "fat along the bold line of the frame patterns.
I carve out early a couple hours early 430 AM - 630AM before the kids go to school and my day starts - has been working really well so far !
Edited by ChrisLBren
Well done, and I am humiliated by your neat workspace. Mind if I follow?
STAY SAFE
current builds:
Looks like a very good beginning, Chris. I was never up early enough when my daughter was young, and got no model-making done for ten years. Most enterprising of you!
As mentioned in the Arsenal great and clean job Chris.
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
Welcome back. 1/36  scale. You must have a bigger bench than me. Very neat work.
Dick
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
They look really good when they are lying there. 😉
Greetings Tobias
On the workbench:
After 2 months of consistent work - 63 frames are cut and assembled and ready for sanding/bevels. One partial stern frame remains to be assembled later.  I need to tweak both the stern keel parts to make sure everything fits snug and re do bow parts part h and i.  Then to cut the rabbet.  Thanks for stopping by.
Nice progress Chris!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Very nice Chris wonderful work
Greetings Tobias
On the workbench:
Hi Chris, in answer to your question, yes the vice will fit the MF70 but you won't have much room to move upwards.
Greetings Tobias
On the workbench:
