M16 US Multiple Gun Motor Carriage w/ Church Ruin by Jack12477 - 1:35 scale - Tamiya / Verlinden - FINISHED
1 hour ago, Jack12477 said:
long before the plaque arrived.
No, you said that you went outside to take the pictures TODAY. And further more you intended to go out again to take more pictures in the natural sunlight.:stunned:
I had no idea Egilman. Shows you how much I keep up with the plastic offerings these days.
19 minutes ago, Canute said:
Factoid: most fighters fired no more than a 2 second burst, any longer risked warping the barrels.
It must  be the same for the M163, (I still want to call it a M113) as the one I got to see just did short bursts and EVERYTHING down range either fell over from being cut in half or just disappeared! Just a soft BRRRRRRRRRR, BRRRRRRR, BRRRRRRRRRRRRRR was all it took. The sight and sound of it has always stuck with me.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
1 hour ago, Canute said:
6,000 rounds per minute for the aerial version in most fighters. Slinging 20 mm ammo of every description. Most fighters hold 650 to 1200 rounds. The F-4 held 10 seconds of ammo. That APC must haul a ton of ammo.
Factoid: most fighters fired no more than a 2 second burst, any longer risked warping the barrels. That did happen, because we had one set of barrels at Korat that was twisted like a candy cane.
That's not the cannon mounted in fighter aircraft, (well a modified M-61) with the Navy's Phalanx system adapted to 20mm rounds, mounted on a mobile chassis.... Limited to 1,000RPM in burst mode The Israelis are the only ones that actually used it to shoot down an enemy aircraft in combat.... and they did it only three times. It was mostly used in the same manner as the M-16 modeled above, as infantry support. It's no longer in use by the US military being finally phased out in 1994. (replaced with the M-6 stinger equipped Bradley AFV.
Currently the US Army uses the actual Phalanx system (known as the Centurion C-RAM Scroll down for it) mounted to trailers for DIVAD. (can also be mounted on a HEMTT) and I understand that they are phasing that out as well.... Guns for DIVAD have been rated as ineffectual for several decades.
Edited by Egilman
Quote:
We don't have any of those type restrictions up here. I can go out in my yard or even take a walk with admiral in neighborhood. Hell the streets in my neighborhood are deserted, only 1 or 2 people out walking..  Btw those last photos are from  last year already loaded onto PC.  I can still go out for groceries, doctors, post office, even parks, except the idiots descended on 2 state parks in throngs and now they are closed, spoiling it for the rest of us.
I may be in NY STATE but not NY City Metro area. I'm over 100 miles from Manhattan island.
Edited by Jack12477
Jack
Current buildUS Constellation
We have the same here, can go out for supplies and work,  even for a walk, exercise etc... but the numbnuts crowded into the national parks, one lot even held a rave, now all public gardens, wood and country parks are OB
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Loving those pictures  - takes me right back   there have been some stunning 1/35  Armour  kits created over time, always fancied doing the Accurate Armour  resin kits  but so expensive  but the detail in them.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Yea, one of our parks covers 2,000 acres with probably hundreds of miles of isolated trails but the citidiots decided to fill up the one or two common lawns with hoards of people and no physical distancing, ditto some of the trails. Luckily there are a few trails known only to locals that can be used.
Jack
I found the Tamiya brand to have some really fine detail and they fit together without a lot of gaps or flash to remove. And they were not too expensive, at least here in the States. All the models I have shown are Tamiya.
Jack
Yep, same as myself  something about Tamiya kits  made you think you had a kit a great quality  - deffo the  best "go to"  kits.
OC.
Current builds
Completed works.
13 hours ago, Canute said:
Yeah, real front lines. And bad guys wore different duds from the locals.;)
And it didn't require an Okie-Dokie from some REMF sitting in an office somewhere before you could return fire.  Gasp.. in 'Nam, we didn't ever think about firing first.
Jack,
Great looking armor corps you have there.
Ok, Lou, Edward, EGilman  - part II of the Armor collection
Modern US
Abrams M1,  Bradley M2 IFV (2 variants), HumVee, Sgt York Air Defense
IMG_8053.JPG.61a18324af5b2ab5fcd12972df4b2c57.JPGIMG_8058.JPG.c66947e5acc5952d44710adfb230ce46.JPGIMG_8054.JPG.38ce08bff4f1fad089bb0080580944ab.JPGIMG_8055.JPG.858b988b794fb25b507b1d8d0b9b7fc1.JPGIMG_8056.JPG.149c0337245aee316551df1021e99ab5.JPGIMG_8057.JPG.8fa7fa3c19c897b4a9526e5fa993ba37.JPGIMG_8059.JPG.478ee6d5b62af070c9efce23e1211d53.JPGIMG_8060.JPG.6f0d8614dcdefc9f99cde5b6d7d786fc.JPG
British Chiefton
IMG_8063.JPG.83bf8fa9f929ba7152cf67af9c99f9ac.JPGIMG_8062.JPG.3e50fc6dbf82f9cfd12ee554df4e6c1b.JPG
German WII and Modern
IMG_8064.JPG.8d5ce37090e3280de0986b3d83954cad.JPGIMG_8065.JPG.cecf3a870d5137f49fcf39df77c44db5.JPGIMG_8068.JPG.98a9ad53bcf464c6fa0306364e97d6fb.JPGIMG_8066.JPG.88dafd6c2983f1891878765c2ef2c043.JPGIMG_8067.JPG.cd48b47a72d6ac1735043512ba163f90.JPG
German Mardar (I think) APC
IMG_8069.JPG.5af23feb9080862d32418c48b752cd52.JPGIMG_8070.JPG.3cfc6d224006b5a4e296d03946efad54.JPGIMG_8071.JPG.ae1f7ad89f41ae1416c5465143deb03d.JPG
And that Gentleman concludes the collection - at least for now - probably order some more kits in future.
Edited by Jack12477
Jack
Great collection Jack, I can see I've got a long way to go yet 😉😂 thanks for showing us
Edited by Edwardkenway
Current builds;
Completed:
Thanks, Edward.  Yea it was done over a span of years.  I might add that all of the painting with the exception of the HumVee and USMC amphibian, were done with a Badger airbrush and Floquil's military color paints; the soft edge camo was done freehand without masking. The two exception were brush painted with Vallejo and Tamiya paints.  Haven't done any airbrushing in decades, not sure how steady my hand would be now. Have to do some practicing and relearn the skill.
Jack
that's quite a collection Jack.........real nice camo and dioramas :)   the church came out great too.......the set up looks super!
no type of lock down here.....but Wally made sure we were set to go if they did.  they gave us a letter in the event that we'd get stopped going to work........seriously! :rolleyes:   they're hell bent and determined not to shut down,,,they are even setting up trailers with parts and stuff in the event that someone infects the shop........we'll have to work outside  {that's what they think}.  part of me thinks I'm nuts with this picture?!?!....but the idea of putting money before lives is unsettling :unsure:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
...guess they didn't want to name it Jack the ripper  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks  Craig and Denis
Edited by Jack12477
Jack
If you think about it, businesses like WalMart could be considered critical infrastructure due to the critical role they play in distribution of life sustaining goods to the public. Short of that, it would have to be nationalized in a time of emergency and run by military forces or the like. A tough position to be in, but I had to do that (work 24-7 in declared emergencies) for a lot of years before I retired. Given all the certificates I have in emergency management, I wouldn't be surprised if they couldn't press me into service even though I am retired.
I better get busy, your battalion would kick mine's butt in any engagement...
Very Very nice......
Edited by Egilman
Quote:
Thanks
Jack
Love   those tanks   - built a few Tamiya Bradleys  and M1's    great selection.
OC.
Current builds
Completed works.
Some randomness that may or may not be apt.
My crib sheet for Amphib Ops has a loaded can of 100 linked cal..50 at 65# per each.  Can of linked 7.62nato at 24# per each; belted 5.56nato a nifty 18#.
The War Department directed that M1 helmets would get a horizontal white stripe at the lower rear for NCOs, and a vertical stripe for officers.  That stayed Army policy until about 1952 when cloth covers became general issue.  Helmet liners sometimes were still marked that way well into the 60s.  Note that the Navy Department never followed suite, and was issuing camo helmet covers as early as 1942.
US armor crews are really proud of their CVC (combat vehicle crewman) helmets, and are as loathe to doff them as they are to dismount.  And, one of those crucial details is, in the mid-late 80s, it was policy that the treadheads had to wear a k-pot when dismounted, so thouse are kept within easy reach of which ever hatch they ingress/egress.
And to this day, it still amazes me that Tamiya went the the trouble to include the duckboards with the M-577 command post, but only include about half the poles for the CP tent (or even the pattern for the CP tent.  [grrrr]  Also, it's aazing that the afterarket has not offered up a set of camo net spreaders.  Sigh.
Thanks for dragging your not that small army out and sharing it Jack. I am not normally an armor type of person but your collection has some very nice examples.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
11 hours ago, Javlin said:
Jack love that church it has movement much like film
Thanks Kevin
Jack
Glad you liked it, Lou.
Jack
Thanks, Phil
Jack
Question: On the Mardar and Panzer at the end of the second set, both have the look of wind-swept dust. How did you achieve that effect?  Great collection/beautiful work! Thanks for sharing!
Mother Nature did it for me ! :D
The entire collection used to sit on an open bookshelf for years until the Admiral decided to remodel our den right down to the wall studs.  So they got removed, dusted off with small brush, some compressed air, a Q-tip, and then stored in plastic storage bins. The "wind-swept dust" is what I could not remove without destroying the decals.  Sometimes it pays to be a lazy modeler and not cover or dust your models. ;)
Thanks, glad you liked the collection.
Jack
