Sherry,
Was that a beer glass or a wine glass that was dangling? :P   I assume it was empty?.... :D
Cheers,
Jim
:cheers:
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
Alright.. some more fodder for the photo hounds....
And to keep a certain You-Know-Who.. and a certain slave-driver of a moderator happy :P , or if not happy.. satisfied enough to lay off the whip for an hour or so... ;)
First bit of standing rigging... the gammoning. And this morning's progress on the bands on the top of the main mast.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Looking very sharp, Andy.  The Gammoning came out quite nicely.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Hi Andy -- I've been checking out your log surreptitiously and now I have to weigh in and say that your work looks good.  That gammoning is espcially nice.  I'll also be really interested to see which way you go on the bunt dilemma.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks guys, I've since given the gammoning a coat of clear matte acrylic, did a good job of handling the fuzzies (that you guys couldn't see ;) ), I'm probably going to use that throughout the rigging process.
Andy
Edited by realworkingsailor
USF Confederacy
looks very neat and tidy Andy, I will have to try your trick to tame the fuzzies...beeswax just doesn't seem to suffice for me, I think I handle it too much.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
'looks all ship shape to me Andy! Good job!  B)
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Andy,
Looking fine! :D
Excellent close -ups......
Your anti-fuzzy treatment sounds intriguing.  I've had problems with beeswax too.
Cheers,
Jim
:cheers:
The nice thing about doing it the way I just did, you can get all the knot tying and glueing out of they way first, then come back and coat the lines. Next time I'm down at the hobby shop, I'm going to pick up a bottle of matte medium, same basic stuff, but a little cheaper by volume ;)
One thing I will mention, the rigging line supplied by Amati isn't too fuzzy to begin with, so results may vary based on the line supplied.
Andy
USF Confederacy
very nice Andy - good god another post to you - without a mention of wabbits - ooooops
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Seems I read somewhere that beeswax is best if heated after applying. IIRC it was with a hair dryer or some such device, which helped melt the wax into the roping fibre. Of course this is from memory of something I've read, so dont hold me to it. Andy's method looks great, but again that could be related to how it started life, with or without fuzzies.
When in doubt, try everything and use what works best for your application. I've seen some pretty amazing things used in unexpected ways. For instance Dubz (Dirk), wax treenails. check post #19 out http://modelshipworld.com/index.php?/topic/75-hmc-sherbourne-by-dubz-pimp-my-sherbourne/page-2
Your fault for that one :P
Andy
USF Confederacy
I been coating my threads with diluted white glue.......and then pulling it taught to dry.   that works reasonably well.   I've also stained white thread {the Billing's stuff I have} with india ink.....than also works well with the fuzz control.   I'm not a real big fan of bees wax....not fond of how it collects on the deck while rigging.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I do have some wax, but seeing how well the matte acrylic worked, I don't think I'll be using it.
My next trick will be figuring out small scale serving (since I don't have a "machine").... I have done it in real life, and it wasn't that hard...
We shall see....
Andy
USF Confederacy
Well.. before my mind goes numb, a quick little morning update..
The weekend is proving to have some good "indoor" weather...
So I've started the wooldings on the mainmast this morning. And you can see the mizzen all painted up. Doing the battens on the mizzen top was... well... let's call it amusing... :rolleyes:
I think I'm also going to make a few changes. On the mizzen the Amati kit says to use a piece of walnut and make some sort of vertical pinrail, which to my mind looks more than a little wonky. Looking at TFFM IV (especially the colour section in the back), it looks more like there are supposed to be actual cleats on the mast (at first I thought it was some kind of spider band, but no..), looks muck better to my eye.
That book is starting to open up a whole new can of worms... I may not follow it to the letter, but I can pick and choose the changes I feel I can make...
Andy
USF Confederacy
Those tops look great, Andy.  Coming along mighty fine!
Wayne
Epictetus
Oddly enough, Keith, those photos on the link you posted, are right out of TFFM IV....
Andy
USF Confederacy
Nicely done Andy. Of course, with such a great resource as TFFM, you will no doubt find that the more you "pick", the more you will "choose"! :D
Within the limits of my abilities and resources, of course ;)
USF Confederacy
Looking great, Andy!
hamilton
Nicely done Andy..... the gammoning looks great.... are you going to paint the figure head?
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks, Ham (you don't mind Ham? :P ) and Frank. :)
Frank, the figurehead is already painted.. She was grey resin to begin with, I gave it a coat of white and then dry brushed and highlighted some of the details in black.
Andy
USF Confederacy
Hehehe, no worries, blame the fall of MSW 1.0
I had it all explained, way back then.. ;)
Andy
USF Confederacy
doing a swell job Andy......good to see you moving right along.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
