Kevin,
I just came upon your HMS Enterprise build and spent a very pleasant couple of hours going through it.  It's fantastic and I'm impressed that you took on a challenge like this. You've done a great job. As others have said, don't let trolls on Facebook get to you...most of them probably couldn't glue two toothpicks together. I'm looking forward to you getting back on this build and seeing your results.
Patrick
2 hours ago, Patrick Haw said:
Kevin,
Patrick
TY Patrick
at present i am up to my neck in foremast backstays, she will be back def by the new year, i will need a break from the AV by then
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
well she made it back to the work bench, it took most of yesterday and this morning to get back into it and sorting out
But i have done something wrong
real wrong
I made up deck beams 1 to 4, sanded them down, milled the notches and located the correct position, and they fitted, with out any agro, that is just so not right (well not for me anyway)
i need to think carefully now as i am going to have to adapt the lower deck to accept ladders and hatches now, but i am so happy, i could skip
new deck beams to the left, and the adapted originalsIMG_1326.thumb.JPG.3e820d99cefc678d776843055546e476.JPG
now im confident that this will work out,  the mast is going into correct place
IMG_1329.thumb.JPG.9a2ed6f65847de7c3538170eb8673f43.JPGIMG_1330.thumb.JPG.af8e08e4ef9a734b4f263fd69149e5db.JPGIMG_1331.thumb.JPG.b70a1989743223fb26b2ba31a8d5e84c.JPGIMG_1332.thumb.JPG.337cdc15ccd7e8c8373d34ecee39508e.JPGIMG_1333.thumb.JPG.b98dd3f39260849eb689ef32e9fe11e5.JPGIMG_1334.thumb.JPG.d77c61d8780f87b17bf977d09f34b9bc.JPGIMG_1335.thumb.JPG.be370dbf58a64e70d1984886c5ce5c47.JPGIMG_1336.thumb.JPG.5fd1dd82fdba884aa2c9e23720271810.JPGIMG_1337.thumb.JPG.6056f13e21718e5fe71998a9d2640f82.JPGIMG_1338.thumb.JPG.ac7d257cf9d6e430a335f3f365cb0344.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon everyone
for a few months now, reluctant at the start, i knew i had to return to this build, a few of my followers know the reason why. but having got over that i have my build back on the table
my next step was how to proceed, i used the main deck (for some unknown reason) in the lower position and had to order a replacement from CAF in china, i should have just used some cherry and made horizontal deck beams, but was worried i would not get the internal bulkheads height right,
then i was concerned that fixing the lower deck beams in would hinder the top ones going in if they were not quite in the correct position, if placed the to far fwd or aft
Anyway i have been setting up the replacement beams and everything lines up (im totally amazed)  only because my photo' make the hull look like a two year old had made it
with that hurdle out of the way, i am now going to plank the rest of the inner hull
new upper beams being test fitted, they were then taken out
now going to continue planking inside the hull
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looks really nice Kevin, this kit clearly has lots of potential beyond the box. Maybe you’ll inspire Tom to offer or include the lower decks.
JJ
             Portland Scale Ship Co.
JJ
lol, i hope not
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
plans were to continue with the internal planking, But i very quickly realised i need to do the transom,
i rebuilt the after part of the building cradle, and ensured everything was still lined up
i have messed the last two frames up, but for now i am going with it, and regret later not sorting it now
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
On 10/4/2021 at 10:10 PM, Kevin said:
just arrived today the replacement upper deck about a week from China, Thank you Tom  @cafmodel
That all looks amazing.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Its great  seeing you back on this my friend  - what you are doing  is amazing  - when you push a build to show as much detail as possible  goes far further than  kit making,   keep it up  Kevin   welcome back.
OC.
Current builds
Completed works.
thanks guys , your the best
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hmmmm…….can I persuade you to re-think this Kevin? A few hours spent now fixing the problem would be well invested……..
I’d hate to think that not fixing this now might cause the build to hit a wall later on.
agred, its the last two sub frames numbers 59 and 60 i put them in the wrong way round after shaping them, even now they dont look right
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good evening
today the planking between the two decks was sorted, this should be ready tomorrow, when the excess  fine filler on the simulated fixings has beeb wiped away, then i have to decide whats next
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
42 minutes ago, No Idea said:
I have to echo what’s already been said. I’m glad your back on this as I think your doing a great job. The ships really looking fantastic.
Just remember - if it was easy everyone would be doing it. They’re not - but you are 😉
Thank you very much appreciated
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
The treenails look really good and neat. Looking forward to more progress pics 😀
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Good evening everyone
after a few good days on the build, yesterday i went backwards,
the fwd mast step went into the wrong position and set before i realised, and then i varnished the internal decking with the wrong varnish, i was gutted, i dont even know how i allowed myself to do it
today was much better
the fwd mast step was salvaged, and although it might be a couple mm more fwd than it should be im pleased with it
the two decks line up with it, and i seam to have plenty of room to put the number 1 deck beam in and the breast hook (please correct me if im wrong)
nothing i can do with the varnish, oh hum (another monster)
tomorrow i will cleam up all the forward frames so they look better in the photo's
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
1 hour ago, PhillH said:
Good to see this build back on the slipway Kevin.
It looks like it is coming along well. I will be following along.
Phill
thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
work continues, but i never thought it would be this difficult, the main deck is fine, but matching the deck below is very slow (i will never make a  model  ship builder)
sail room deck made up and fitted
lower deck in and secure, was also pinned
getting the lodging knee on the port side the right shape is my biggest concern, but it is in line and the right height  for the hanging knee
IMG_1398.thumb.JPG.069bc45d00df7c15647897105ca392f9.JPGIMG_1399.thumb.JPG.fcc745a0a0f36138fb2b2878a4e3aba4.JPGIMG_1400.thumb.JPG.9d83df4068e4de1dc30e73d49440cf8c.JPG
sail room buikhead and pillars inIMG_1401.thumb.JPG.46ccf60c61bce56b654b9d02bdb20470.JPGIMG_1402.thumb.JPG.d6d46e4426ce2ca598767ac32f717843.JPG
lining up the rest of the internal bulkeads
the upper deck is just for the photo
IMG_1404.thumb.JPG.15e9ba37a5de689ae896156912bfd432.JPGIMG_1405.thumb.JPG.4a236e1c71cc23bc2a67bad174e97e96.JPGIMG_1406.thumb.JPG.8ff617f2710e7491669cbb5af981fd78.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
my main worry is how messy it all looks
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
On 10/30/2021 at 8:50 PM, No Idea said:
Hi Kevin - you say that you are worried about being a ship builder.
Mate you are building a ship so you are  a ship builder 👍
keep going bud as it looks great and stop beating yourself up!  This is a really good build.
thank you, i have a nasty habbit of doing that to nyself
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
looking through all my old builds, the one thing i have learnt, if you don't like it, dont hide it, just re-do
the lower deck beams i now believe to be in the correct position
looking through the AOTS Pandora book i need to move the bulkheads to the sailroom and others to match the beams, so as they were fixed to the deck i ripped it out cleaned it all up, which gave me the opportunity to put a  bulkhead in under the 1/4 platform (coal store)
now means i am in a good place now to get the passage way doors scuttles and bulkheads in place
a test fit of the upper beams show they are in the right place
IMG_1415.thumb.JPG.7bc49c3aae6e51ca4e19166b1e2e5cf9.JPGIMG_1416.thumb.JPG.1e98d69c53b215cf476f0b1ff96489d0.JPGIMG_1417.thumb.JPG.249ac5179cb05251b18a1757cf268b8a.JPGIMG_1418.thumb.JPG.35c9d01e14af555af54ef06527435782.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
  • 1 year later...
Compliments Great work is coming very well. The model is very difficult and the instructions of the KIT CAF model are not enough. I had great difficulty doing it and unfortunately there have been some mistakes that are difficult to recover.
A greeting
Iosto
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
La Jacinthe French Schooner
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Bisquine La Granvillaise
Fishing-boat
English pinnace
18th Century Longboat
Kevin, Any plans to continue on Enterprize? Your progress to this point is great, the development of the lower decks is very nice.
ty but my skill levels are not to the standard to achieve the results i would like
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I would disagree. I think you're doing a great job. I’m considering a CAF purchase after seeing your build progress.
