Stage Coach 1848 by Kevin - Artesania Latina - 1/10 - July 2021 - finished March 2022
still to do
fit the roof
leather hand straps
fit any made up bits like the luggage and mail pouches'
and a general tidy up
good evening everyone
thank you for comments and likes
tomorrow should be the last day of this build, and i can get on with the SD14
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
8 minutes ago, wefalck said:
What surprises me, is how fragile these coaches looked. OK, they had to keep weight down so as not to tire the horses too much, but somehow it is difficult to imagine these things going along mud-tracks.
agreed, even the wheels seam very thin, 6mm at this 1/10 scale,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
There were two types of coaches, the eastern road coaches, and the western trail coaches... They were both built in the same manner on similar plans but the western coach was built much, much  more stoutly...
The eastern coaches were usually hauled by two horses occasionally four, (much shorter distances on improved roads) and the Western coaches pulled by four occasionally six horses over wagon trails....
Think GMC inter-city bus compared to a Greyhound or Trailways super liner...
The thin wheels were usually found on the short haul coaches as were the large leather sided luggage compartments in the rear... The western coach had rear wheels that would be about 3-3.5 inches across and fronts 2.5 to 3 inches wide with half inch thick steel rims...  and the rear luggage compartment was usually a simple framework supported by chains at the corners and a leather cover that rolled down from the top and unfolded over the sides in bad weather...
Quote:
the kit is ok, but like everything in our hobby, it could be tons better,
if it wasnt for the love of my ship building, i would do these as a pastime, or non live steam engines replicas
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon everyone
Calling this finished
pretty well OOB with some extra brass trimming, and extra Stanchions on the roof, i have seen much better made example of this subject, but im happy with it
thank you to those who followed the build
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That looks Superb Kevin   - so  nicely done.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Kevin, looks good and would be right at home in a John Wayne western.
STAY SAFE
current builds:
Sweet looking coach, Kevin.
OC.
Thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
superbly done Kevin.........very sharp :)   the leather work is awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you everyone
was an enjoyable build,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
in regards to your finish pictures.......it might look a wee bit better to be on asphalt or concrete.......but certainly not on a garbage can :D
......jess' say'in ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
excellent idea
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Oh god! I missed the stage! 😊 Been catching up, beautiful work Kevin.
I agree with popeye,  would better without the bin underneath 😉 😁
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
back in the day,  when I lived in Florida,  I built a Guillow's Fokker D VIII.  it came to be my best flyer.  there was a concrete slab in the side yard,  likely for a shed,  and it seemed like a good place to take pictures.  I laid on the ground in various places around the edges and took some shots.......some using the grass to look through.  I was very impressed with how they came out........but I lost them in my move back here.  after all these years....I still wish I knew where they went.  would have been great to share with you folks :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thank you everyone
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
slightly better than on the dustbin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Fantastic job on the coach. I am impressed with the intensity of the yellow.  I have found that every brand of yellow paint I have used, including house paint, will not cover without a nearly infinite number of coats!  What is you trick for getting that great yellow?
it was a  rattle can from a car colour range, on white primer
Halfords Ford Signal Yellow Car Spray Paint 300ml | Halfords UK
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Yellow Papa is one of those colors that benefits greatly from a light colored primer underneath..., oranges and reds do as well if you want them bright and vivid...
Quote:
much better Kevin! :)   congrats on an awesome project!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
22 hours ago, SigEp Ziggy said:
Fantastic Job!  I am glad to see this build because I wanted to see what was involved in building this kit, and Wow! you did a great job.  Beautiful!
Thank you Ziggy
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
  • 1 year later...
Hi, My name is Jim. I'm new to the group. A retired tool and die maker who finally indulge myself in model making. My first wood project is the 1848 stage coach that Kevin built. My biggest question is: What finish do I use on the outside of the coach. The instructions just don't specify. Any information would be greatly appreciated.
