Nice work as usual Bug, like the replacement wheel.  👍
Is the way the ropes are attached to the tiller arm from the plans?  Just wondering about the last length going up to the wheel axle at an angle, I have usually seen that rope go through two more blocks under the wheel axle then vertically up to the wheel?  Attached the arrangement for the Bounty I am currently building.  I know there are variations for this on different ships and i'm no expert, just curious.
  Thanks for the comments everyone, much appreciated.
  Hey Andrew, great question.  The plans show it differently (see below) - and closer to what you're illustrating.  But I took this simpler method (linked) from Dan Vadas' Vulture as he was more closely following Antscherl's Swan FFM books.  I'm definitely no expert either - so I have been erring on the side of what other Swan builder's have done; mostly Dan and @Blue Ensign.
   But I do notice on your plans what I mentioned before - how the heck could a helmsman fit in between that binnacle and wheel?  I'm guessing there were no fat helmsmen...
Well can’t be a better example to follow than Dan and BE, but yes you are right sometimes plans and sketches in some sources don’t seem to take into account the crew who worked these vessels, I think ergonomics is the term for it nowadays.
I love the treenails on the wheel, Bug. They're not too easy to see but certainly give it character.
Pete
Pete
Current Build: Charles W. Morgan - Model Expo
Completed Builds: Santa Maria, Cutty Sark, HMS Bounty - Marine Model Co.
On The Shelf: Flying Fish, HMS Endeavor, USF Confederacy
  Put the gangways and gangboards together.  Pretty straightforward stuff with only a couple of wrinkles.  I used the false deck templates, then extended the planking all the way across the waist.  Then I discovered an issue: once again because my deck planking is thick - the step up from the gangway to the other decks was not feasible for a sailor to navigate.  So I added an additional step up. The rest of the gangboards, etc, is nothing earth-shattering.
Peg_417.thumb.jpg.6c2a1fbf08d8148e77eaaa1d1f141fe4.jpg Peg_418.thumb.jpg.b422de1f19d95a47cfea8f23d918da69.jpg
Peg_419.thumb.jpg.e307b73f710ca03d5e4298739772679c.jpg Peg_420.thumb.jpg.983b3408b79586309f88d68b4db5c652.jpg
Peg_421.thumb.jpg.68be63aaaff302ed5939b56bc260d53b.jpg Peg_422.thumb.jpg.65c61b76cf870c3c7efc53a2a90bd607.jpg
Peg_423.thumb.jpg.465e4f99070021ceefb024b78c734d47.jpg Peg_424.thumb.jpg.98f80a11d835518438161e62d346388a.jpg
Edited by Moonbug
  For the ladders in the waist I attempted the slight curve/twist that is reflected in the FFM.  Wow - what a challenge.  I started out using the pieces of basswood that I typically used for ladders.  However, this wood caused two significant problems.  First, it was too soft to shape/sand in the ways that I needed to create the curve that gradually diminishes from top to bottom.  And second - the lighter color just looked weird to me.  So - fail on try #1.
Peg_425.thumb.jpg.8396a4f7677e082c532af6f57d74b3fe.jpg Peg_426.thumb.jpg.5cd10bd77a2981fb744e3ffa69f6f0c2.jpg
  For try #2 I went with Swiss Pear - same material as the deck. This solved both problems.  I was able to sand and shape the denser wood, and it looked much better not contrasting with the deck. I like the contrast for the deck furniture, not so much for the ladders.  But then this presented a THIRD problem - I had already done the hatchway ladders in the lighter color.  The only alternative of course was to re-do those as well. I think this second attempt also produced ladders & steps that are bit more to scale as well.
Peg_427.thumb.jpg.9647ed83fa4a4df0b5a7f2e526c51808.jpg Peg_428.thumb.jpg.9eacd51ce9b8f6cd00a2f1253201fa3e.jpg
Peg_429.thumb.jpg.b43359f817c843a3c548c3b4182ba227.jpg Peg_430.thumb.jpg.23e94bff34a6490c6f14c0c924b316ad.jpg
Edited by Moonbug
   I took on the task of the catheads the last couple of days with some level of trepidation.  They seem pretty straightforward, but getting them to look like the submerge into the deck has been haunting me a bit.  Really, any time I go back and take a chunk out of the deck it makes me nervous.  As others have noted, the catheads that came with the kit seemed a little odd to me - they appeared to be under scale but a fair amount, and also there were no sheaves!
    First, I measured out the angles I'd need off the bow and identified where I'd need to cut through the bulwarks as well as carve out the deck.  Once again in the 'failed to look far enough ahead' category, this happens to line up right where my scarph joints on the margin plank are.  Oh well - hopefully that won't be super noticeable to most folks.
    For the catheads themselves, I started with a couple of 5 x 5mm pieces of walnut, measured them out and a shaped them. I'm not so ambitious as to have created all the sheaves out of metal (I prefer simulating most of them with just drilled holes and carved lives between). But I felt it was necessary with the cathead sheaves as they are very visible, but also will need to be functional later when I rig the anchors.
Peg_431.thumb.jpg.6d6ca20bc8339a1e234c2c9bb4d9e86b.jpg Peg_434.thumb.jpg.ad8e9784cfb1c6b49494aa579034abae.jpg
Peg_432.thumb.jpg.cd2552ff323ded608921d341cbb63f09.jpg Peg_433.thumb.jpg.326c8f3edfb922b17645204d6b467447.jpg
  I drilled out a series of holes for the sheaves, then used this handy sanding string to size them out. The the metal sheaves I actually chose a brass TUBE instead of a brass rod and carved out the groove on the lathe.  I chose the tube because it's SUPER difficult for me to get a nice hole drilled through the brass. I just can't seem to get a strong enough drill bit that holds up without bending or snapping off.  The cutting the sheave from a tube means I only had to drill through the wood to place the bolt/pin.
1713910391_SandingString.thumb.jpg.798c95763fafa8cda772bd6f83d13886.jpg Peg_435.thumb.jpg.8e9b1ab74684a56317929bc5896dc603.jpg
Peg_436.thumb.jpg.8e3bf5605d41d3dfd5a96b43bb3ee329.jpg Peg_437.thumb.jpg.eaecc418c0f0179757b7bfb15bbd1f38.jpg
    Here are the assembled catheads and comparison between the kit version on the left and the scratch ones. I actually feel like I kinda nailed it getting the catheads to look like they go down into the deck.  Pretty happy with the result.  Incidentally, it was WAY easier adding that bolt on the side without having to drill out the brass.
Peg_439.thumb.jpg.70f661b17e8c57045eda63630fd8824c.jpg Peg_440.thumb.jpg.660062d1fe6941de69fc2e2462430efe.jpg
Peg_441.thumb.jpg.87d51ccfe23a19fdead2c103e1dc2aa3.jpg Peg_442.thumb.jpg.8f04b647a811fd9b5d6b5e55462a2557.jpg
  Obviously because the kit catheads were small, so were the knee / braces.  I cut mine out of a scrap walnut from the laser cut pieces and shaped it to the hull. I also tapered it from the cathead down to it's base as it will eventually need to become the decorative headwork on the bow. Final touches include scraping some grooves.
Peg_443.thumb.jpg.3e64bc142d903dce31779c2e63a8b6cb.jpg Peg_444.thumb.jpg.2ab97ba49005c899f996fba72c577330.jpg
Peg_445.thumb.jpg.d6a6164c64cb73df8b46803445187f46.jpg Peg_446.thumb.jpg.55261cb0a77a1daa8627a504a463f24a.jpg
1 hour ago, Blue Ensign said:
angled end should be deck down
   Oh crap!  Ha!  Thanks gents -  I was so excited about the sheaves I totally botched that.
    Love having this forum around.
   Uh... nothing to see here... just flipping some catheads over...   🤦🏼‍♂️
Thanks again @Blue Ensign and @chris watton!
   I started cutting and shaping the swivel gun mounts out of 3mm x 3mm mahogany that I have lying around. I don't really want to paint them, and I want them to stand out a little bit but compliment the rest of the subdued color scheme I have going.  I shaped them based on FFM with the octagonal top and sized to fit my 'scale guy' once mounted.  More on that later.
But of course this got me thinking about how to handle the swivel guns themselves. First, I cut some brass brackets, shaped them and drilled out bolt holes. They're then mounted to pinheads that have been sanded down flat to form a solder-able surface.
A03D4311.thumb.jpg.472721fa2aaeca846967c48b7af8571a.jpg A03D4313.thumb.jpg.f010534228ddb12d1c6b87c633b07f78.jpg
A03D4314.thumb.jpg.502fff983af21a696852ff0886409885.jpg A03D4343.thumb.jpg.4a2c376ea0ea0b57b38dfb43e2066dbd.jpg
For the actual guns, I have these really sweet looking turned brass guns from Syren that I'm going to use instead of the molded die cast kit guns.
A03D4350.thumb.JPG.c637a108a49ef8b7e3f012e08d965ffc.JPG A03D4327.thumb.jpg.b4b48ff4d1b32d04ae17d1a1c4a25253.jpg
  However - one of things that is accurate about the kit guns is the way in which the rear handle extends back.  I briefly considered hacking off the breach button from the brass one and trying to extend a handle back - but quickly realized this was beyond my capabilities without the entire thing looking like crap. So I opted for the secondary style that you sometimes see in which the handle extends from the rear of the gun.  I know it's not ideal - but it's what I think I can achieve. Here's a good representation from  @AON's Bellerophon build:
   After a lot of attempts at trying to get the handle to "loop" around the button, it was just too small of a scale and everything I did once again looked like crap.  My first working attempt was to try and mount/solder it to the bottom of the gun instead:
  At first, I felt like this was acceptable. Mostly since at the end of the day, the combination of the very small scale and the bottom of the gun not being visible made this passable.  Then, of course the more I looked at it the more annoyed with it I got. So I tried again - this time, taking the wire handle, flattening the end, and cutting a small groove in the end with the smallest cut pin file I could find. That groove allowed me to solder it to the rear of the gun and kind of "simulate" the loop over the button.
A03D4346.thumb.jpg.f8f81f7bbad9df42e2a98f149ee79c89.jpg A03D4329.thumb.jpg.bcb9c038c710c5bed75366b992ffa58b.jpg
  Here's a comparison of the two tries:
A03D4319.thumb.jpg.40771443d1aee345eeaaf4071efe2bfb.jpg A03D4332.thumb.jpg.cf2ea0c62a28793f215fc9c3009d6d32.jpg
    Following the idea of my hatch railing stanchion tops, I created the "knob" at the end of the handle by taking a small amount of this ebony wood filler and rolling it into a ball.  Still have to work on getting the size acceptable, so I'm not sold on this technique.
  I still need to do some work on the blackening and finishing touches, as this doesn't look great for a final product (and the knob is way too big) but here's basically what the guns will look like.
Edited by Moonbug
Great work Bug. One idea you might try for the “knob” is a drop/blob of PVA. You can relatively easily control/adjust the size this way too.
  Thanks for the comment and encouragement Dave!
  Thanks Grant, BE, & Andrew.  I tried the drop of PVA initially and had a hard time getting it just the way I wanted. I have gotten it to work pretty well in the past - but this was just a bugger!
     But then @Blue Ensign gave me a pretty great idea by mentioning the rudders - for my rudder brace bolts I used the ever handy .020" mico-mark tiny nails. So why not take another run at the guns using the longer version of those?  Here is the result - I think I finally got close to what I wanted - as the handles themselves are more to scale with the guns.
A03D4351.thumb.jpg.43cafd5d84083b7da1e7e7efb1065411.jpg  1427035390_NewGun.thumb.jpg.97dde2019280a444ed42bcbe048805e4.jpg
It was  a real trick soldering them however - as the melting point of the little brass nails was almost exactly that of my softest silver solder. So often the nail would melt a little along with the solder and had to be fiddled with.  Then I shaped the handle after it was cooled. About 1/3 of the time, shaping the handle also meant snapping it off and starting over.
Edited by Moonbug
  Thanks BE - It took some persistence and trial and error, but I think I got to something I'm pleased with as opposed to just "ok" with.
You have quite a talent.  If I attempted that there would be a puddle on the table top.
Alan O'Neill
Same here and the air would be a deep blue.
   A little bit of a chaotic weekend, but I did get some work done in between yelling at the television during the American Football playoffs.  Full disclosure: I've been a MASSIVE 49ers fan my entire life.  Here's me getting ready for the game in my bar:
  Anyway - on to the build.  Like many folks, my success with blackening has been hit or miss, and I always ended up having to do touchups or over-weathering to make up for the inconsistencies.  But with the success I had soldering the swivel guns, and how inevitably visible they are - I wanted to get the just right. So I went back to the basics on blackening by doing some MSW research and following Greg's (@dvm27) great tutorial post "Blackening Revisited" with all the steps.  Ordered some Sparex, stole my wife's crockpot warmer, and set up my station.
Needless to say, my results were MUCH improved.
Blackening_b.thumb.jpg.95ce5ee28432d7f747bdc58a7befec79.jpg Blackening_c.thumb.jpg.7245c2228ff1f3436a027d59d6b1fea5.jpg
Blackening_d.thumb.jpg.0a48f31f64f816b3163f4452145f3c59.jpg Blackening_e.thumb.jpg.34e9310ccae9393a2ada8a5ca11dbda5.jpg
  The improvement was so good in fact (and I've had a good learning curve with silver soldering) that I decided to complete Re-do my Stove vent.  Here's a comparison with the old vs new:
Vent_a.jpg.3eb29fc250a766401bc0413d8c9f4921.jpg Vent_b.thumb.jpg.ac82ef92d118cef7dcb698b8a086229b.jpg
I was a die-hard Niners fan for many years, but I lost interest in the NFL a few years back and haven't watched any games for two seasons now. European soccer is my present sports passion. I currently follow Bayern Munich, AC Milan, and Everton FC. For those in the know, I explain my passion for Everton as a kind of pennance for being a Bayern fan. Soccer fans will understand.
   Hey Chris - I spent 3 years in southern Italy and 3 years in Portugal, so I still keep my eye on football across the pond - mostly international, but I do check in on the Premier and Champions leagues, especially around tournament time so I'm loosely familiar with Everton.  :)
YES!! 49ers forever in our household and Giants too!!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
   I've been rolling along with a few things - and had to make a couple of repairs.  I didn't take any pictures in my frustration and eagerness to fix it - but I had something fall from a shelf onto the ship's wheel and it was destroyed.  *Sigh*  So I spent much of the weekend using Chuck's jig/templates to make a new one from scratch.  What a chore.
   Along with that, I've finished up the swivel mounts and affixed them.
A03D4375.thumb.jpg.f42fc5815c71656038764e92e91640ef.jpg A03D4378.thumb.jpg.bf032db1bbbb13088b7189dc75675469.jpg
   I've also been obsessing over the swivel guns themselves and I think I've landed where I've wanted.  After blackening and polishing them, I fixed them all to their brackets.
A03D4391.thumb.jpg.c3f2b53109687a9ff1e8ca6629526a4c.jpg A03D4392.thumb.jpg.816f9097ebdda8402a0ef8c1ee8b3d55.jpg
      So I hit them with a VERY light splash of this Vallejo "Nato Black" with an airbrush and low pressure, then polished them again. Here's a comparison of just the paint and then a really soft polishing with the dremel tool.
A03D4401.thumb.jpg.8169344b05a474c1fc1e81231356bbfe.jpg A03D4402.thumb.jpg.5f8de93bd2b4048d94f22bbd7a0077e6.jpg
  Finally, I added a smidge of my favorite Tamiya weathering rust and brushed off the excess with a soft toothbrush.  Here's the end result. Overall, I'm pretty happy with them. Of course they'll be mounted on the swivels much later lest I snap a few off with a sleeve or other clumsiness.
A03D4408.thumb.jpg.2c7fff1b5fe3cb6453218aafadeeb17a.jpg Final_01.thumb.jpg.960d9d404106577e4445a2c57d374ce3.jpg
   I've had something pretty specific in mind for the Belfry for quite a while, and of course I've been stalking Dan's Vulture (here's his belfry).  A few years ago I purchased a couple of pens (I have a collection - don't ask. 😛 ) at a charity auction, and they came in this snazzy pen case.  I've been looking for a reason to use the wood on these end pieces, but needed the Byrne saw to get a good cut on this really dense wood.
  I cut two 5x5mm pieces to serve as the stanchions, and three pieces of Swiss Pear scrap for the roof and shaped/sanded it all.  Really, one of the down sides to having the Byrnes saw is that I'm half tempted to go back and re-accomplish half the stuff I did by hand.  heh
Peg_465.thumb.jpg.e54b98f8c2cd4afed3d6537f5a0540dc.jpg Peg_466.thumb.jpg.db88daefcc96680011b286a659fed48e.jpg
   For the bell housing, I used walnut, and created a brass bracket to hold the handle.  The handle is a shaved down piece of brass rod that fits into the bracket and bends over to hold the rope. Finally, I outfitted two boxwood cleats instead of metal - which I thought was an aesthetically pleasing and acceptable substitution.
Peg_468.thumb.jpg.b2a544805d94bffeef7a0620066c58cb.jpg Peg_469.thumb.jpg.6490e97d7dcb1aa7f682ac173e55ee31.jpg
   The whole thing put together and mounted. To me, the Belfry was another opportunity to add a little bit of artistic flair.
Peg_471.thumb.jpg.f18cc1e2f57cac01607d107d1f964696.jpg Peg_472.thumb.jpg.7f013037d8a785babc6bf12046fe79db.jpg
Edited by Moonbug
