On 12/31/2021 at 5:11 AM, RGL said:
Lower gantries, the PE is supposed to sit on top of the plastic, so I’ve retained the sponsons and cut away the rest of the plastic. No such luck with the ones that run along the flight deck and nowhere as near as good as a Pontos set.
I had Eduard, Flyhawk, and Pontos for Musashi, actually still do. I used Flyhawk for carpeted parts as replacement, and Eduard, for other models where I could use PE. Pontos was/is by far the best of the three
You could add some more ... still enough deck visible for some trucks, rockets and other items
Glad I can follow still, instead of reading it when finished
Edited by cog
Carl
Amazing work, great skill and attention to detail 👏
Andrew
Completed (Kits):-
Same as  Greg   welcome back  @cog   Craig.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Superb work  Greg.
OC.
Current builds
Completed works.
1 hour ago, Landlubber Mike said:
Looks great Greg.  Any idea what those dark circles were on the Cats from the pictures?  Didn’t look like there was structural damage there but almost looked like a burn of some sort.
Along the wing? The darker paint ?
Greg
amazing work
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
I’m in the process of adding the life rafts. These sit along the gantries, the PE set gives you netting which runs purportedly along the railings but the reference photos show them at 45 degrees with a railing running along the top and the liferafts lashed to them. Also the ends of the flight decks are starting to lift as we have had a spate of unusual humidity.
Greg
I just love the way you coloured the funnel--- so realistic-- its touches like that which elevate into the very special category
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
Looks great. Is the aftermarket flight deck warping forward, or were you just waiting for some other detail.work before laying it down?
Really awesome build!
Greg, is the warping a common effect?  I have a few kits with wooden stick-on decks and heard of this problem.
Is it remedied by pretreating the model with a gloss coat - I.e., does the deck’s adhesive bond better to a gloss coat than plastic?  And in your experience, is it a good idea to use additional glue and not just rely on the adhesive?
Thanks in advance!
3 hours ago, RGL said:
A gloss coat works better. No idea why. Glue is problematic as it’s hard to get a good even spread so just put out spot fires where needed using a metal shim and CA
Have you ever used or considered using contact glue like they use on laminate counter tops? When used with counter tops it gives NO leeway in placing but once placed only acetone or destruction will remove it.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Another fantastic model Greg, congratulations!  I actually went on the Navsource site the other day to look up other Casablanca class escort carriers to see if there were any cool pictures I could represent similar to what you did with the Thetis Bay.  Very creative on your part!
What's next?
