14 minutes ago, Chuck said:
Lovely!!
Thank you Chuck, Very much appreciated
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
On hold
MHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72
U552 German U Boat - Trumpeter -
1/48  Amerigo Vespucci     1/84 - Panart-
HMS Enterprise  -CAF -  1/48
Finished
Belle Poule 1834 by Kevin - OcCre - 1/90 - French frigate - started June 2024 - -
Hercules by Kevin - OcCre - 1/50 - Tugboat - Finished - May 2024
Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished
 Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished
Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Good evening everyone
Thank you for comments and likes
day 157-2 main channels in place
the main and mizzen channels were the easiest to get into position due the to way the kit was designed, the fore however took a few attempts to get right as i lost the lines due to painting and sanding, as a result i went back to the wood and it made it a simple task to get the alignment
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
Lovely   work mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
good evening everyone,
thank you for comments and likes
day 174-6
ive been busy recently, with lots of gardening, and other projects, and  in the last 10 days we have been in the process of finding and new puppy to go with our boi, that has been successful, and will be with us in about 6 weeks time
as for the build i still continue to do a bit daily, however done more today, as i wanted to see if any of my toys are worth keeping, if so, to use them, which is what has happened, and IMHO quite well
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
11 minutes ago, James H said:
Beautiful! Those chainplates easy enough?
so far so good, but only two so far are fixed into position, its a joy to do this build, the only bits that let it down are bits i have to do, lol no pretty pictures to follow now, im on masting/rigging, for me the most enjoyable bit
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
She  is  looking so  nice  Kevin.
OC.
Current builds
Completed works.
good morning everyone
day 176-6 lower masting
will be interesting to see how @Blue Ensign and @ECK tackle the masting, th standard of the builds far surpasses mine, butim thoroughly enjoying mine
the two lower mast come together vey quickly, and although they are only primed they look good in the sunshine
 @yvesvidal - Agreed -  NO dustbin
IMG_7112.thumb.JPG.55eedd29afe79ad2e35a8302edafc78b.JPGIMG_7113.thumb.JPG.25b9d1e7ccd9e3bde7a6300eee756ba6.JPGIMG_7114.thumb.JPG.5b1154458c6799f3a60494c30a52c587.JPGIMG_7115.thumb.JPG.924064dc5123c4e52944a8d27515951c.JPGIMG_7116.thumb.JPG.8e47b1886ed9c1bc18c8e086014ce437.JPGIMG_7117.thumb.JPG.5606bf846876a596fad8d82ed53ca1ee.JPGIMG_7118.thumb.JPG.05902ebad4a7c44304fae798c47e988c.JPGIMG_7119.thumb.JPG.f296f15e646e857fa4441f31a0f6ced6.JPGIMG_7120.thumb.JPG.3884a3425d54c60c7567b83e8e634818.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
Awesome work Kevin,       :cheers:
"Start so you can Finish!"
In progress:
Astrolabe 1812 - Mantua 1:50; Golden Hind - 1578-Air Fix.
In queue:
Pegasus - Amati 1:64
Completed:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
Getting enjoyment from the build is the main thing Kevin, without that a build is unlikely to be finished.
I like the look of your Indy, and it will be interesting to see a fully masted and rigged version.
I'm sorry you won't see that on my version,  which will have  stump masts only, if any masts at all.
ps. You haven't forgotten to fit the lower finishings of the Qtr galleries have you?
Regards,
B.E.
Regards,
B.E.
at present im unable to make them look right, so i will try again when i redo the midships to aft repaint
plus i may have a bit of a problem with my coppering, i used the tape, and put a water based varnish over, but im wearing the varnish away with constant use, lol its looking very polished by the rudder post and lower bow
no masts, is that a personal choice or space related?
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
19 minutes ago, mugje said:
That's beautiful in the natural outside light!
thank you
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
Maintaining copper is a tricky business during the constant handling during the remainder of the construction. I suppose that unless the copper  is damaged, it could be re-treated later.
I seem to recall that on my Pegasus build I used cling film to cover the lower hull taped to the wale with varying success.
I wonder, could you construct a cut out polystyrene cradle to rest the hull in that would allow you to to turn the hull about without contact.
The build board I made to hold my Indy keeps her secure for most activity, and I don't need to handle the hull. The downside is that it is a bit of a beast to move about and there will be times when I  need to transfer her to the keel clamps to get specific angles for better access.
B.E.
B.E.
some great ideas thank you, i will retreat and see how it goes
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
B.E.
Hi I added a Lazy Susan to the bottom of my build board for my 1/72 Victory worked a treat. https://www.amazon.co.uk/gp/product/B07G4FY6VG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
You might consider getting  some cotton gloves or even surgical type vinyl gloves for handing the ship.  Still looking sharp, Kevin.
Bowsprit 177-6  also completed yesterday
well that was a fun little project, i went for the longer version of the two options available and went with the flying Jibboom. this extents the build by another 110mm, the most difficult part was the angle for the masts passing through the cap, done now and im quite pleased with the result
IMG_7121.thumb.JPG.569568309463ae62189157203457e6c3.JPGIMG_7122.thumb.JPG.230e05a7cbd66d3479bfbd777d8eee5b.JPGIMG_7125.thumb.JPG.9af6b6306022fc3661d2c58618ca715c.JPGIMG_7127.thumb.JPG.6e7ea7eb6e8d359f6185c28476c6fcce.JPGIMG_7128.thumb.JPG.448e696018ba867712b29f32adcfcd25.JPGIMG_7129.thumb.JPG.637c47abe2f163d8cbc83ef48fe6c187.JPGIMG_7130.thumb.JPG.11b07de7b4218b56d43d6a7b23f5f89c.JPGIMG_7131.thumb.JPG.9ec747995e8d95115a42f0741186cc0f.JPGIMG_7132.thumb.JPG.9bc6766932c023bfc4b0771ceff91cee.JPGIMG_7125.thumb.JPG.9af6b6306022fc3661d2c58618ca715c.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
35 minutes ago, Blue Ensign said:
Nice Job Kevin, but the sight of that flying jib boom makes me very nervous, you've just doubled your workspace requirement.🫤
Can you draw it inboard until  absolutely required?
Gotta love spaniel pups, which one is yours?
B.E.
nothing is fixed, i am no way ready for masts at this time, but wanted to progress them before the new pup arrival, i also want to redo my display area, so the shed where i did the masts is going to be a temp storage area soon
the pups photo was added by mistake, but decided to leave it there, taken yesterday, with just the boys in it, we will be having one of them but will decide which one, as we have first pick, in a couple of weeks time, his name has already been decided, and will be Apollo
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
Nice looking work. It will be a sight to see fullymasted later on, good call not to have them fixed at this stage.
Regards,
Glenn
Current Build: Medway Long Boat
Completed Builds: HMS Winchelsea HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose, Royal Barge
good afternoon everyone
thankyou for comments and likes
day 180-6
today i made up the mizzen mast, all 3 are very basic for now, but i really wanted to get them out of the ways before the new puppy arrives, a couple of bits are pinned, but nothing is glued, so might seam a bit squiffy in places, also they they might not be in the fully home position
I will possibly be have a few days of soon from the build, as the mancave display area, is to be made larger, and although it was only done a couple of years ago, its its small (lol always something to do)
IMG_7173.thumb.JPG.bb2887310a9101b4c9b67bf52d6dc832.JPGIMG_7174.thumb.JPG.454931e0bd789ada07628ddd8a73ac95.JPGIMG_7175.thumb.JPG.747f88cb35c0a6c7842713ca65f559b3.JPGIMG_7176.thumb.JPG.2f95dfdcc3e5e5c915d88c5a527349a9.JPGIMG_7177.thumb.JPG.3543c07dffe0ccee575733c1ad85f8de.JPGIMG_7178.thumb.JPG.7b83933d9e61eb01e83bff1b6f6a9f54.JPGIMG_7179.thumb.JPG.290aab940c81d7059c1f0c319760a0f3.JPGIMG_7180.thumb.JPG.c0cc90af344342f2c6a6a6e702a04730.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
Foremast day 181 - 6
not a lot to say but oh so enjoyable, even the upper mast battens are included in the kit,
IMG_7183.thumb.JPG.68eeb2acaea75bf5f137643f8af0611c.JPGIMG_7184.thumb.JPG.3ad5193e368b1be361829b73c59f4b27.JPGIMG_7185.thumb.JPG.b38c93851046eac30ac1f964d07f899f.JPGIMG_7186.thumb.JPG.b52c6320d789f4bf12f67da9bbaf203a.JPGIMG_7187.thumb.JPG.eca438979d81c36436a39d056f53f9c4.JPGIMG_7188.thumb.JPG.c9f0a5745d40dc9614d75b2f79d1644e.JPGIMG_7189.thumb.JPG.fb99849ae04c0b80126908308248b1a5.JPGIMG_7190.thumb.JPG.6694ea272a00e6cade7ee9ec03ef7c1f.JPGIMG_7191.thumb.JPG.743e94d4ff9a10d6b5f85ea540a36c28.JPGIMG_7192.thumb.JPG.67e91aa38a8e7f21d7a96f107a7b1054.JPGIMG_7193.thumb.JPG.0ff3ec647dbb29e4c8d061669d01aee0.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
184-6
i have slowly been tidying up the bow and making up the masts, so yesterday i decided to insert the lower foremast, and tapped it into position, which gave a lovely satisfying sound telling ,e it was down on the keel, a measurement check confirmed the it was
1.3mm black thread, and 0.5 natural for the landwards, lets start the rigging
two pair of  pendants in first with 1mm thread and 2.5mm Thimble
first pair to stbd
IMG_7208.thumb.JPG.85ead9a9f7e9c8799c225a7ba09bb809.JPGIMG_7209.thumb.JPG.c5093fe97bff61cbebda09fd5b7468f8.JPGIMG_7210.thumb.JPG.44f7df66ff731a72098a6cd1a350b35f.JPGIMG_7211.thumb.JPG.d39a9e153103ed8ef33e912c8aaf11cb.JPGIMG_7213.thumb.JPG.8a9b59025794be5f0c2ca915b4d94564.JPGIMG_7214.thumb.JPG.88dbdaf113d8954ecf1c8af4cae8d497.JPGIMG_7215.thumb.JPG.6b2815d3bbe91f66b7dbee08d81de69e.JPGIMG_7216.thumb.JPG.7a3c38cb60257c131512a6cb0ec00f6a.JPGIMG_7217.thumb.JPG.c13c184037141a1da20a0710e42fe002.JPG
these will all be removed and tidied up before i go on with the build, i find deck fittings get in my way so these will be added at a convenient time
All the best
Kevin
KEEP IT REAL!
On the build table
On hold
Finished
