1 hour ago, Valeriy V said:
I don't quite understand your question,
Valeriy, Te hull seems to have lines running along its length. I think this is to represent the steel plates that the hull was constructed from (presumably the plates were riveted together). My question was how did you simulate the these on the hull.
Thank you for the details of the power plant - it looks like triple expansion steam engine. The stokers must have had a difficult life - very cramped space, lots of coal dust,  lots of heat. It must have been hell.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, that's right, the hull of the destroyer was assembled with rivets. Metal sheets were overlapped to form sheathing belts.
To depict them on the model, I use a simple method - automotive putty and masking tape.I think that this method is simpler and more reliable than copper strips glued to the hull.
Thank You Valeriy
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I know of this technique, one puts the masking tape, where the inside strakes will be and the fills the space in between to represent the outside strakes. I have never used the technique myself, but would be concerned about the edges of these 'strakes' - they could be quite vulnerable to damage such as chipping. These automotive putty do not have a lot of cohesive strength in order to allow for easy sanding and in their intended application, there would be no exposed edges.
Chips at the edges of the strips can be easily avoided. To do this, you need to use a sharp tool and your caution. ;)
The main drawback, after the complexity, of the copper strip method is the difference in the thermal expansion coefficients of the materials.
In this case, there is a high risk of cracking and peeling of copper strips from the hull.
I have not found an adhesive that would bond brass, copper, etc. to a wooden hull with any confidence that the bond would not fail over time.  Even Epoxy seems iffy.  Some joints are secure, some can be easily peeled off.  I tried 3M transfer tape recommended by the guys that build models for the Navy.  The plates easily peeled away from the hull.
I finally used add free paper saturated with shellac and glued to the hull with PVA glue.  It worked!
Roger
On 3/6/2023 at 7:30 AM, Valeriy V said:
Work on the body of the model has begun ...
Great diagonal Karweel plaking
Nils
Current builds
-Lightship Elbe 1
Completed
Fantastic. I see you found the scale match LOL
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
 Hard to believe that mighty things come from that little space. Thank you for posting photos of your shop, Valeriy.
Yes, this is a small space, parts are produced here, and their assembly takes place in the next room and it is a little larger. But even on this table, models with a length of up to two meters are quite successfully placed.
