HMS Sphinx 1775 by mugje - Vanguard Models - 1:64
46 minutes ago, Chuck said:
Nicely done.
Thanks Chuck! And everybody else for the likes!
First glue attempt of the main gun deck failed 😂. It's really a tight fit and with the diluted PVA....lot's of warping etcetera...I couldn't get it flat on the false deck. So took it quickly off. Tried to clean as much glue off the parts with some acetone. After that I made the lasered gun deck a bit moist with some water and put something heavy on it so I hope it's getting a bit flat again. Maybe need to do that several times before it's flat. We'll see...
Edited by mugje
Link to comment
Share on other sites
Looking good. Your attention to detail at this stage is impressive and will pay off further down the line.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
I let the lasered gun deck drying for 2 days and it's flat again, so that's good. But what I noticed is that the diluted PVA fixated the wood in such a way that it is substantial larger than it was. It doesn't fit anymore. I need to sand it quite a bit more to get it right again. It's even bigger then the other gundeck that I replaced with this one and that one isn't even sanded haha.
So this morning the idea slipped in my head that maybe planking the deck myself would be a better option for me. It's a bit easier to handle, only more work...but that's not a problem.
I'm first going to plank the outer hull so I can let this idea sink in a bit and decide later on.
Edited by mugje
Link to comment
18 minutes ago, Jack-in-the-Blue said:
I like your work and your words and the kit looks pretty good too. This is one to watch’ 👀
Thanks and welcome! I like this kit a lot and it's so well designed, I enjoy working on it  :)
Edited by mugje
Link to comment
I think I reached the point that the hull has her final shape after fairing. It's for me a bit of a uncertain point...because you always think...is this enough, is this her shape?
Did I sanded too much or too little...and reading through other build logs, I'm not the only one experiencing these thought in his building process. But there comes a point
in which you say....I think this is it :D  I found it a enjoyable process to see her lines slowly emerge out of the rough shape.
So after a lot of sanding, producing a big heap of sanding paper this is the result, and i'm looking forward to the next stage :)
Link to comment
Nice to see you back Mugje.  I hear you on losing interest in models and wanting to jump to something else.  I've got a lot of models on the shelf.  To keep myself building, I'll pick up a new one or go back to one I had started earlier when the mood and motivation hit me.  For me, it's always been about the building, not finishing a model.
By the way, that kit looks fantastic!  The way the framing locks in like that is amazing.  A lot different from older kits for sure.  Looks like the fit of the parts is very precise.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thanks Mike! Yeah I stored the Pegasus in the attick, so I can always return to that. But this kit is indeed so different then everything else. It just feels like play, how everything connects and clicks. Don't get me wrong, you still need skill to get a neat and tidy result, but it's a lot of fun working on it.
Link to comment
Very little update...30 degrees here in the Netherlands and melting away in my hobby room.
I made the inner gunports square. These where left a little bit smaller then the MDF frame so you have a bit of wiggle room. I removed
the bulk of the material with a knife and sanded it flush to the frame with a sanding stick. Not difficult, but pretty time consuming, I really took my
time with this...because nothing more annoying then gunports that don't look square :P
And today dryfitted the outer gunport patterns, soaked them first for 45 min and then a lot of clamping. Will see tomorrow if all the curves are there (including the slight vertical curve). Otherwise will just another soak fix that. The outer gunport patterns really give the ship some "body", nice to see. :)
Link to comment
Yay! First plank of the first planking layer glued on the ship. After glueing the outer gunport patterns it's time for some planking. Looking forward to sharpen my skills regarding planking, because it's not there yet where I want it to be :P
Plan is to approach the first layer as if it was the final pear layer (with some liberties, because I have just one size of planks) to practice and refine my skills. Especially lining of the hull etc. The ultimate goal is to leave the pear planking natural (really liked the look of Blue Ensign his Sphinx), but that all depends if i'm happy enough with the final layer. But there is ofcourse always the possibility to paint the hull white, which I also like...but a natural hull has my preference now.
First three strakes will be just straight without tapering, measurement, whatever...this is somewhat the position of the wale so from there I will line of the hull and measuring etc.
Link to comment
First three untapered strakes...gave them a light sand afterwards. When I was working on the bottom one, I noticed that the fairing of the stern was insufficient. It's one of the more difficult corners in my experience and was a bit conservative there with the previous fairing proces. So I spended quite some time yesterday afternoon to really get an idea how the stern needed to be shaped to have a nice flow in planking. Studying Chuck's build log of the Winchelsea and some contemporary models gave me a good impression how the end result should look like. So I spended quite some time sanding the stern piece...to I believe it's final shape. We shall see when planking proceeds...
Now it's time for lining off the hull :)
IMG_20230923_144532101.thumb.jpg.cb0a21614b624d18ad5e0a2c3e4c0a13.jpgIMG_20230923_144553369.thumb.jpg.83de70e057f4b390c980bd79e9480c32.jpgIMG_20230923_144637404.thumb.jpg.7b5aeb4244aa2c54008f367e614cb56b.jpg
Edited by mugje
Link to comment
that looks a brilliant base for ist planking
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
2 hours ago, Theodosius said:
How do you did that? I meant that bending just on top of the corner?
Combination of heat and a plank bender from Amati. You can use ofcourse also water and soak the plank first.
Most important is that you use a plank that is longer then the finisht one. So overextending with a few centimeters/inch will make the bending process
much easier. (same as for edge bending)
And patience....so take your time to get the curve you need....it doesn't have to be in one bend, but a bit further everytime. Otherwise it will just split.
And a bit of CA glue at the tip will hold the plank down. Rest of the plank just PVA.
Thanks everyone for the likes! Much appreciated :)
Link to comment
Finisht with lining off the hull...I actually wanted to take a little longer for this process, but the tape didn't stick that great on the MDF bulkheads, so I rushed a bit through it because it was quite annoying when the tape constantly fell off. I do think it will stick way better on the first layer of wood when that is ready, due to the larger sticking surface and less porous wood. And that being said...lining of the hull for the first layer is just practice, it doesn't have to be perfect and it's more the experience I gain with just doing it. Lining off the hull doesn't look like a exact science and looks more something that you are getting better at through just doing it, and learn from it.
So now I began filling up the first band :)
Edited by mugje
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
