7 minutes ago, CDW said:
That looks great! You are keeping Tamiya tape production workers in business, but it's by far the best tape for our scale model work, at least the best I have found. I'm always open to lower cost alternatives but not at a cut in quality.
Thanks Craig!  I totally agree with what you said.  Masking is definitely not something you want to skimp out on.
5 minutes ago, CDW said:
I order all my Mr Color paints from scalehobbyist.com
His inventory and reliability are second to none.
Good to know.  I like buying paints from Spraygunner too.  Otherwise, in a pinch or on a whim  I'll order paints off of Amazon or even eBay if I'm having trouble finding something.
Great finish on the painting Mike :imNotWorthy: - metals and yellow as well 🫣
Andrew
Completed (Kits):-
Sadly, Spraygunner quit carrying/restocking the Mr Color line. He was my go-to up until then. He's just 10 miles or less from my house.
Great progress, Mike - and like Glen stated, you are a master with paint.  Listing your paint choices at the end of your post is very helpful.
Thanks for the link, Craig!
Gary
Completed Scratch Builds
Great work!  The window must have been frustrating to fix, I'm glad you were able to figure that out in the end.  The paint looks outstanding!
Brad/NavyShooter
Thanks Ken and Brad!  I found the key to reds and yellows is to put down a primer coat of white (or even pink) for an even tone.  It's a pain though when you have to do touchups, as you really need to re-prime and then paint.  I've learned the hard way from my earlier yellow wing builds 🙄
Productive [late] night yesterday.  Got the decals on the underside of the wing, fully assembled the plane minus the antennae on the top of the canopy (which is too fragile to really install at this stage), and sprayed the fuselage and top of the wing with a gloss coat.  Almost to the end finally!  Just need to add decals, a little weathering/shading/highlighting, and then the rigging.  Fingers crossed the tape comes off the windows ok.
This kit fights you all the way, but it's looking like a nice model in the end.  The struts in particular where a pain the posterior to try and fit and glue.
Thanks for looking in!
Finish line is in sight.  Finished adding the decals, did a little shading/weathering, and just sprayed a final semi-gloss coat.  Just need to rig, add the props and canopy antennae, and maybe add some last bits of weathering for things like the wheels.
There is just something about Silver & Black with Yellow, Red and Green details that just work.... They combine to make beautiful looking aircraft...
Well done Mike, and another yellow wing for the collection...
Quote:
Finally finished!  This thing has been fun, but a bit nerve wracking.  There are so many PE and other fragile detail pieces, that I kept breaking things off.  I figured out a way to hold the model, but one time I accidentally held it a little too firm a popped one of the windows into the fuselage - let's just say, I said a few not so nice words 🤬  Somehow, after shaking the fuselage for a few minutes, the window popped back down into the slot.  It took a while, but I managed to get it glued back in.  It's not perfect, but better than terminating the build.
Thanks to everyone for your support and help!
I found a 1/72 scale Navy WW2 pilot from CMK and a picked up a resin concrete tarmac off of eBay the other day, so decided to use them for a simple diorama with the JRS-1.  I like adding figures to help better show scale.  Here, the figure shows how big this plane was.
Fantastic work Mike! :champagne-2:
Andrew
Completed (Kits):-
Excellent work Mike.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Fantastic work - congratulations on finishing!  I love the colors and all the additional detail, especially the landing gear.
Dave
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
