AEG G.IV - Creature of the Night by DocRob - FINISHED - Wingnut Wings - 1/32
1 hour ago, wefalck said:
You have the propeller-makers decals - I was about to ask ;)
Yes wefalck, port is a Behrend prop, starbord is a Wolff prop, the latter rotating counter clockwise.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
Your propellers look terrific too! The overall composition with the rest of the airframe is just spectacular.
Cheers,
Dan
Final steps ahead, luckily. The huge airframe and the delicate details make working on the big bat more and more difficult. The issues fixed to parts torn loose ratio turns worse :D.
I assembled the elevators and the rudder and added steering cables for the rudder. the fittings were made from split brass rod to add some more detail.
Finally, I reassembled the guns, the worst part of the build and installed them into the gun mounts onto the gun rings.
There will be a lot of final touch ups and then the big bat is finished.
Cheers Rob
Done so far, phew. I have to continue to paint the figures and to clean up my bench, which I guess will take longer than the build itself :D.
Cheers Rob
Stubby sucker wasn't she? All wing, no wonder they had a habit of nose diving on landing....
Beautiful model Brother.... Absolutely outstanding....
Quote:
Fantastic model Rob. And a fascinating build log, I learnt a lot! 👍🏻
Cheers,
James.
Current Builds
Microaces Scrappee Liaison Radio Controlled
Occre Polaris 1/50
Hong Kong Models 1/32 B25 J Mitchell
Completed
Airfix Westland Sea King HU.5 1/48
Airfix Supermarine Spitfire Mk.IXc 1/24
Airfix Avro Lancaster B.III (SPECIAL) 'THE DAMBUSTERS' 1/72
Airfix Titanic 1/400
Airfix King Tiger 1/35
In the hangar, dockyard or factory
Airfix Fairey Gannet AS.1/AS.4 1/48, Airfix North American P-51D, Mustang 1/48, Airfix Supermarine Spitfire FR Mk.XIV 1/48, Airfix MGB 1/32, ICM Gloster Gladiator 1/32, 5 Airfix Tanks, Airfix Blackburn Buccaneer S.2 C/D 1/48, Artesania Latina Zuiderzee Botter 1912 1/50, Airfix WWII British Army 30-cwt 4x2 GS Truck 1/35
Thank you Egilman.
He he, indeed, the design is a bit strange. The commander normally left the front cockpit through a crawling tunnel for start and landing, to not get smashed, when nose diving. In general, I read, that the AEG was superior to the more famous Gotha.
I have a soft spot for lozenged planes and consider buying the early day bomber variant as well.
Cheers Rob
16 hours ago, RGL said:
Absolutely marvellous mate!
Thank you James and Greg, I learned a lot too through that build. I really like to replay the work I´ve done and write it down in a halfway structured form. This way, I can think about the used techniques and try to do better next time, when I reference at my build logs.
I learned so many things through build logs, it´s a pleasure to give back in form of some lessons learned posts. I live a bit isolated, so no model shows, hobby shop talk or even fellow modelers around, which leaves the internet as my only connection to the modeling world.
Cheers Rob
Wonderful result!  All the details and minor weathering look great.   But it really is a strange looking bird, or should I say bat.  Long wings, stubby fuselage, big engines, short propellers, cartoonish tires.  I assume it is an accurate representation of the prototype, but it still looks odd.
Thank you Gary, I like the look of the AEG somehow, but I have a soft spot for quirky designs. The really interesting fact is, how advanced this plane was, about a dozen years after the Wright Flyer.
From a modelers standpoint you couldn´t ask for more, the wide fuselage allows for equally wide cockpits, which show a lot of detail. The engines were often flown without the cowlings, again a possibility to show a lot of detail work.
Cheers Rob
Great looking build of an interesting aircraft.  The infant industry really produced some interesting aircraft (and sometimes really bizarre looking) in the early days of flight.
On 5/6/2024 at 9:52 PM, king derelict said:
Absolutely spectacular. Congratulations on a wonderful creation. I thoroughly enjoyed the build log and it has been a great teaching opportunity. I learnt a lot of techniques that I hope I will be brave enough to try in the future.
Thank you Alan, glad you enjoyed the log. I benefitted so much of forum input myself, it´s a pleasure to give back a little. It´s not completely altruistic though, as it helps me to keep track of my builds and enhance learned techniques for myself as well.
If you are about to enter the WWI plane building universe, I can tell you, it´s quite rewarding and not as complicated as it first looks. Kits of WNW quality help a lot due to thorough design. If you haven´t started exploring these kind of builds, it might be best to start with a German WWI fighter. Less rigging and colorful liveries do help.
Cheers Rob
Thank you Mark, quirky as the AEG looks, it was a successful design, meaning, I saw stranger things flying, like pancakes (Chance Vought V-173) or the like. I can only admire the courage it must have taken to fly with these wood/tube/cloth/string crates with relatively unreliable engines in the dark of the night.
Cheers Rob
19 minutes ago, Baker said:
A very beautiful model.
it was great to follow this build.
Thank you Patrick, the ´Finished´ in the header was sneaked in by a moderator, but I have to continue to paint the planned figures, which are only started now. That my take a while, as I´m out of my comfort zone.
Anyway, it was great to have all of you around with likes, encouragement and input.
Cheers Rob
3 hours ago, ccoyle said:
Guilty! I needed to pump up our stats -- at least, that's the excuse I'm going to use! 😳
No harm done, Chris. With my expertise in figure painting you may did me a favor, but I will try anyhow :D.
Cheers Rob
32 minutes ago, Canute said:
Another beautiful job, Rob.Thank you for sharing your techniques. 👍
Thank you Ken, I learned so many things, during my first wooden ship build here on MSW, it is a pleasure to give something back, where I´m in my comfort zone.
Rob - your AEG came out great!  I learned a lot from your log.
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Well, here are my feeble attempts in figure painting. I try to do one or two figures per build, but often shy away, because painting these is always like a burde for me. Nonetheless, i try to improve my skills and sometimes force myself to finish the figures.
The mechanic is painted with acrylic colors from Scale75, except for the skin, which was painted with oil colors.
Cheers Rob
Your mechanic looks great Rob. That moustache is fabulous!
Cheers,
James.
Current Builds
Occre Polaris 1/50
Completed
Thank you James, I still need a lot of experience to develop my figure painting skills. I´m not able to blend the colors to my liking, specially with acrylics. With oils, it´s much easier, but they dry forever, sometimes not at all, that´s why I had to strip my second figure, featured in the next post.
Cheers Rob
The big bat is finished now, that I found the courage to paint the figures. The young boy with the broken toy plane is exclusively painted with Scale 75 acrylics. I had to strip the oil colors off his skin, because they never cured and I couldn´t touch the figure for further painting.
Thank you all again for participating in this log, which helped me a lot in form of encouragement and practical information.
Cheers Rob
One of the most beautiful model airplanes I've ever seen, any era...
Well done....
Quote:
