Licorne by mtaylor - 3/16" scale - POF - TERMINATED LOG
Beautiful work on the Capstan, Mark, I dread making this particular fitting as making several identical whelps seems to be a rather daunting task, but you've handled everything perfectly, I salute you my friend  :)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Link to comment
Share on other sites
Thanks for that information, Mark.
I think I'll get a small quantity of each to have on hand.  Is there something effective for epoxy?  I need to put these info points into my journal so I can begin remembering where to find out when I forget, which I do a LOT.  I love that capstan.  What are the notches around the bottom for?
Walt Biles
Link to comment
have a look at Dafi's build of the Victory......in there {somewhere} he has a very detailed build session of the capstan.   at the bottom, there is a ratchet and pawl set up,  that will lock it into position and won't back off,  should a rest be needed.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks everyone.
Aldo,
Several ways of doing the whelps... use a solid block of wood and cut the whelps to shape then slice them apart.  What I did was put in the timbers and then spun the whole thing on the lathe and shape it.
Walt,
I think only heat might work for epoxy.  You might ask this in the Wood Tips and Tricks section.
Popeye pointed out a great resource for capstan operation.  Dafi's build is great for his exploring not only how things were made, but how they were used.
Link to comment
Mark,
Glad to see you at the tools again. 'though it took some resizing a very lovely job on the capstan.
Carl
Link to comment
Ben,
Short answer:  yes.   PM sent.
Link to comment
Great build Mark. I like Hahn's plans and Licorne is one of them. Beautiful ship!
Past build: BRACERA
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover"
KIND REGARDS!
ELMIR
Link to comment
Hi Mark:
Just took some time to read through your log - very impressive! I'll be following with interest
hamilton
current builds: Corel HMS Bellona (1780)
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch)
under the bench: Admiralty Echo cross-section; MS Emma C Barry; MS USS Constitution; MS Flying Fish; Corel Berlin; a wood supplier Colonial Schooner Hannah; Victory Models H.M.S. Fly; CAF Models HMS Granado; MS USS Confederacy
Link to comment
Thank you, Elmir and Hamilton for looking in.
Sjors, Sorry about the long reply. :)
After much thought about "what next" and much fear and trembling... PLANKING!!!!!!!!!!  post-76-0-14882900-1371431945.gif  So there's fear because I've never single-planked before.  Trembling because I'm looking forward to it...  and maybe too much coffee.   So I gathered the three planking guides from the Articles area and Planking the Built Up Ship Model from ME and studied.  Scratched my head.. said "oh.. nothing to fear".... and got on with it.
First step was I realized I didn't have a suitable clamps.  So I made 5 of these out of some scrap cherry and maple.  No particular reason other than I had a bit <cough> of scrap.
First plank on each side is laid.  I'd doing the planks from just above the wale to the chain wale.   I may go farther up before heading below.  One reason is because the planks between the wales need to be sanded and I don't want to damage the wales.  Also, need some playtime experience with minimal tapering and spiling.  I hope....     I'm using swiss pear for the main planking.
FYI... the hawse holes I already drilled aren't on the same plane.  My bad.  I'll redrill after planking.
Link to comment
good luck Mark....big job ahead.......but it's going to be fun :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hey Mark.......single planking takes 1/2 the time  :D  :D .  With your skills and attitude I can't believe you'll have any real problems.
Looking forward to seeing what the Swiss Pear looks like.  I'm thinking of working some into a future build.
Don't rush it......no matter who starts clamoring for photos!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Indeed it will be a big job, Popeye.
Thanks for the vote of confidence Augie.
I'm taking it one 32-foot plank at a time.  At 9-inches wide... it's going to take a bit.  I'm thinking I'm going to follow Hahn's lead and completely plank the exterior along with all the carvings.   Did I actually say that?  All the carvings... <gringe>  Anyway, so far, so good.   When I get bored with planking, I can jump all over those stoves/fireplaces.
Link to comment
I'm convinced that's the way to go.  Chuck had advised, I believe, about 28 feet / plank and that worked out on Syren .
As for the carvings, if you and Sjors don't mind, I'll move to the back of the bus.  WAY back.
Best of luck!
Augie
Previous Builds :
Link to comment
You don't have to go too far to the back of the bus.  I'm not, normally, one who throws things.   A few years ago, I relief-carved a rose for my wife from swiss pear.  Didn't come out too bad, so I figure anything will be an improvement.
Link to comment
Good luck with the planking - head down, eyes open, bottle to hand (but not too close!)
hamilton
Link to comment
Hi Mark,
I'll be waiting patiently for any answer…….
Augie back in the bus?
What's he doing there?????
He didn't know that the engine is there?
Or is that the reason….
The planking…..I know for sure that you can handle that and I'll be watching closely to see how it goes.
Good luck with it!
Link to comment
I'm not worried about you throwing anything.  I just don't want to be embarrassed by how well it comes out knowing my carving skills are non-existent!
Augie
Previous Builds :
Link to comment
Mark,
I'm sure your planking will be fine, if the rest of the build is anything to by. And if its not, just think of all the extra clamps you'll be able to make! :P:D
Link to comment
Thank guys.  Ah.. the pressure.... the carvings...  YIKES!!!!!
One plank at a time... one strake at a time..  Yup... grunt work followed by liquid refreshment...  I like it!!!! :cheers:
Link to comment
Mark, I think that you're going to find that planking is really kind of fun and not all that difficult. But then you get to the joys of tree nailing.
Bob
Link to comment
Bob,
I'm enjoying this type of planking so far.  Like I said, this is my first single-plank hull.  But so far, so good.  Plan is still... go up to the caprail line with planks, chain wale, and any decorative plank.. I think there's one....  then head south and do the garboard strake, the wales and then fill in the blank area.  :)   Yup... simple.
Uh.. treenails?  I'm not going to as from my view 1:64 is too tiny to see.  Those 9" inch hull planks I'm using are only 1/8" in real life.
Link to comment
Mark:
So far the planking looks good. I found that planking is all about measuring, double checking, thinking about it a bit, measuring again, double checking once more, and then some more thinking. :)
Seriously, it just takes some time and care.
Russ
Link to comment
What a brilliant idea - special tools. As you said in introduction: really model for begginers ...
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
