Echo by Maury S - FINISHED - Cross-Section
Well done, Maury! My only comment would be that the berthing up on the quarter deck and the rail above it look rather wide: I think it is due to the fact that the moulded way of the top timbers are too wide. However, you've a major achievement by completing this fully framed cross-section. Take a bow!
Link to comment
Share on other sites
She looks wonderful, Maury.  So what is the next project?
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
beautiful cross section Maury,
very neat and accurate work,
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Toni,
I still have Chuck's Cheerful to finish...probably a year or so.  I've started collecting some info. on a work boat.
http://modelshipworld.com/index.php/topic/12450-work-boat-research-for-pof-project/
Current thinking is either an Anchor Hoy (fascinating stuff on one of those) or a Stone (or Granite) Sloop.  Pretty lines, centerboard sloops,
something different than warships.  We'll see if I can get actual plans.
Maury
Link to comment
I started on the gun carriages.  The brackets (sides) were taken from TFFM (Vol. I??).  David has them shown in 1:24 as well as 1:48.  Sure makes measuring easier using the 1:24 and dividing by 2.  I used the table saw to rough-cut the brackets...could have been done on the mill, but I'm not as good with that.  Shown on the crosscut sled.   I drilled out the axle holes on the Axle tree blanks using the mill.  Axles were done on the mini-lathe.  I'll cut / sand them to shape and get some more metal work done.
Maury
Link to comment
More work on the axletrees.  The axles are not supposed to be centered in the blocks.  Pretty small, but everything was done on the thickness sander, table saw and the little notches for the brackets with a knife (needs cleaning up).  Looks pretty good 'til you take a picture with the marco lens.
Maury
Link to comment
Very little work done over the weekend.  The brackets were glued together so the drilling of the various holes would line up. (pic. attached)
All the holes drilled, soaked in iso. and split the pieces apart.  Other parts (transoms, bolsters, quoins, etc made (no pics.)
I bought a glass (football)  display box (Hobby Lobby) and cracked the mirrored bottom trying to drill the mounting holes.  I pulled the mirror (pieces) and put in a VERY NICE piece of birdseye maple veneer.  Warning:  do not use water-based glue on veneer!  (The guy at Woodcraft has no clue on installation...telling me to use Tite Bond).  It created 1/4" high waves every inch or so even with a heavy weight on it.  Next attempt will be to put down some more veneer using either CA or rubber cement.
Maury
Link to comment
Best glue for veneer would be Contact Cement in my opinion Maury.
:cheers:  Danny
Cheers, Danny
Link to comment
Titebond is good if used the right way! Coat both the veneer and the substrate with glue. Allow to dry. Then iron the veneer to the substrate. (Careful not to have the iron too hot. A layer of paper will act as a bit of insurance.) Works a treat, and no contact cement fumes or strings!
You could try ironing your wavy veneer down, Maury. Rubber cement is not permanent, BTW/
Link to comment
Further to yesterday's post, here is a photo of a baseboard that was veneered and banded using Titebond. The other advantage is that you can spot-tack the pieces in place: they don't 'grab' like contact cement. A little heat will reverse the bond so that you can reposition a piece if you need to.
Link to comment
Thanks for the input.  I took off the veneer and will start over.  Misc. pieces for the carriages in the picture.  The quoin handles are belaying pins from an old 1:96 model.  The jig holds the brackets at the correct angle (2 degrees) for when the axle trees go on.  A simple wedge in the middle holds them tight against the sides of the the jig.  Flip it over for the transom, etc.  I think the iron work needs to be done before I start any assembly.
Maury
Link to comment
Boy, am I glad I don't have 74 of these things to make!  Assorted eye bolts, half eyes (for where the rings get installed) and rings.    More iron work and the cannons to blacken.
Maury
Link to comment
Carriages done.  The cannon were blackened twice with diluted Caseys Brass Black after a long bath in Acetone, rinsed and bathed in vinegar, rinsed again.  Pretty color, but not the black I was hoping for.  Having read Ed Tosti's frustrations with blackening I can understand, but any suggestions on getting them "Iron Black" would be appreciated.
Maury
Link to comment
Cannon and carriages look very nice, Maury. I now use matte black automotive primer, several lightly sprayed coats, to blacken many of my brass items. It has the advantage of filling in small defects and blending mated parts into one. It also imparts a slight texture to the surface, which is reminiscent of iron.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Thanks Greg.  I'll try that.
Maury
Link to comment
Greg, I am to used that technique once I am getting to the cannon or other metal creating.
Respectfully
Link to comment
I'm re-painting the cannons per Greg's suggestion.  Here's how it looks in the case.  It's a "Football Display case" from Hobby Lobby.  A piece of birds eye maple veneer held in place with Contact Cement (no warping this time).  Just the right size.  The officer in the foreground is cut from Chuck's Cheerful plans and glued to a piece if 1/4" wood...shaped a bit.  No way am I going to try to carve one yet.  It's a good prop to show the scale.
Maury
Link to comment
Maury, blackening metal can be problematic at times.  A few years ago a club member gave a demo/talk on blackening metal at a club meeting that I think would help out a little.  Once the part as been cleaned and degreased it was pickled in a hot Sparex bath.  According to the member this gave the part some tooth and allowed the blackening agent to work.  And he used Caseys Brass Black.  Since the stuff is a mild acid I think a long soak in white vinegar might do the same thing and be a little safer.
David B
Link to comment
Beautifully displayed, Maury.   Congratulations.
Link to comment
Thanks for the comments and all the "likes".  I received a lot of help from people on the site.   I've learned a lot by doing this project.  Skills have improved and patience has grown.
Maury
Link to comment
  • The title was changed to Echo by Maury S - FINISHED - Cross-Section
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
