Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
hope this one's the charm for you Mark  ;)    good your making use of the laser cutter.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Nuthin wrong in a few profanities Mark, I do it all the time, par for the course for me. I generally get "I'm going in the garden" from the boss when I start and as long as the window isn't open there's no problem.
I'm sure you'll get it right this time, looking good so-far mate.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
Thanks for the "likes" and the comments, one and all.
I guess I need to clarify... this is a plug.  I'm planning on adding the frames to the outside and then planking that.  Sorry if I gave the impression it's a bread and butter build.  I just felt this method "looks" better but that's me.  Now to see if I'm up to the challenge.
Jaager,
I have a couple of old leather belts cut into pieces.. I strop a lot.. x-acto knives and now carving tools. :)
Dan,
I have a good selection of micro-burrs and micro-sanding bits.  I've just barely scratched the surface on the next piece I'm carving... ;)
Link to comment
That is a neat way to do the boat Mark.  I especially like the base (top?) piece you have made with the securing points.  Rather than carving out the interior, I thought this was a 'plug' and you would build the boat hull around it?  In the next boat (or version if needed), you could draw and cut the slots where required on each slice and then connect by carving the rest of the slot for the frames?
Sorry not trying to make extra work for you  :)
cheers
Pat
Edited by BANYAN
Link to comment
Pat,
I was on the verge of cutting in grooves but in looking at it I realized that sanding might hide some and maybe all of the grooves. Part of the "problem" is that these frames are so small.  I'll have fiddle some with this one and give it some thought.  I do have 2 more ship's boats to make and they're a lot smaller than this one.   I'm just applying what I've learned so far and still have much to learn.
On those holes, I fit a piece of dowel through each one to lock the pieces into alignment when gluing.  I came up with that as I've found when clamping, sometimes the clamps shift things a bit.
I've been using the other logs for inspiration... Danny's, Archijofo to list two.  And basically everyone else in scratch and kits as there's great ideas and methods.  The hard part is sorting out which ones work for me.
Link to comment
Mark,
    Just catching up on the build.  Looking great.  I wish I'd have seen this latest on the long boat before I started working on the launch for the Santa Maria. I went with the bulkhead method, as you'll see in an upcoming post.  Rough stuff for sure...   This is cool method.  Maybe I'll take a shot at it and see what turns out better.
- Bug
Link to comment
Hi Mark.
Just catching up myself, after a hiatus. Was laughing pretty hard at some of the posts. Yeah, been there, done that. Nice thing about having some other languages is you can cuss a blue streak as loud as you want and the Admiral just says 'ok, I guess that means you want the tuna salad?'. Keep on keeping on.
John
Link to comment
Mark,
Just following you build... I am definitely not ready for something like this.  Your work is marvelous.  Keep on it, it is inspiring.
Link to comment
Link to comment
Thanks for the "likes" and comments everyone.
Life keeps getting in the way of this build right now...  I think we need a blizzard and I need no distractions.  Fat chance of that though.  :P  :P
Just a minor (for ship.. big one for me)...  14 strakes left on the main hull planking and I won't need any drop planks other than the one I've already done at the bow.  Just some careful fitting as I continue working towards the keel.  The last plank will need to be a bit wider than the rest of the planking but not as wide as the garboard plank.   I'm smiling.....
Work also continues on the plug for the ship's boat, albeit even more slowly than on the planking.   Carving is on hold until time frees up a bit.
Link to comment
Hi Jeff,
I've been busier than a one-armed wallpaper hanger in a windstorm.  :)   Dealing with some health issues of the Admiral's, getting the yard winterized... oh Licorne... yeah.. Slow going.  Each plank is being spiled, bent, and fitted.  Three planks per strake and I've done I think 25 strakes on each side.  But the end is in sight for the main hull planking... 6 strakes on each side left.  I'll do an update then. Then another after I sand and gap fill.  The plan is for me to then turn attention to the stern, which should be fun.  On side, I'm working up drawings for the cannon machining, carriages and quarter galleries.   Fiddling with the ship's boat (first of 3) and also attempting, carving stern decoration (The Arms of France).
Link to comment
well  mark  dont you know  details are great but results are greater.  lol   joking  i know alot goes into scratch building  and unlike me  your actually doing it right    sorry to hear about the admiral    hope she gets better soon   cant wait to see your update
Link to comment
ah.. no pressure.. I like that... :rolleyes:
Link to comment
Good Evening Mark It sounds as though you have your hands full all around.
Best wishes for the Admiral,
Getting winterized is something I'm glad we don't have to deal with here.
I have just put 2 first layer planks on my endeavour and can now start to fully understand the
effort required.
Hooroo Chris
Link to comment
Hi Chris.   Thanks for good words and the look-see.  Inspite of the setbacks and slow going right now, it's still fun and relaxing.
Link to comment
I hope your Admiral is well.
There will be time for model
All the best
Edited by Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Link to comment
G'day Mark
My prayers are with you and your Misses. Hope everything will come out ok.
God bless you all
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Link to comment
So you're doing a good job from my point of view.
Best wishes for the Admiral.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Ah Mark, I see you have made the acquaintance of the mate of the one-armed bricklayer :)
cheers
Pat
Link to comment
Thanks for the comments and well-wishes.  Janet is just dealing some deterioration of various bits and pieces in her back and some congenital issues.  Not life-threatening but very painful.  After going through 3 back doctors who said "there's nothing we can do",  she's working with a pain clinic.  We're in the early stages of this so we'll see where it goes.
cheers
Pat
Yes..  I'm also acquainted with the one-legged man in a butt-kicking contest. :P  :P :P
Link to comment
Hi Mark
That doesn't sound good, but I hope Janet is finally able to get the pain relief that she deserves from this new Pain Clinic.
Fingers crossed!
As for MSW and Licorne...we can all take a breather until Janet's better. Just remember to recharge your batteries once in a while, too.
All the best
Patrick
Link to comment
Mark,
Best wishes to Janet.  Hope the docs can make the pain a thing of the past.
Good luck,
Tom
Link to comment
If it's one of those "Pain Management" places Mark, make sure and have her be completely honest about how intense the pain is, because not doing that will mean they won't attack the pain problem aggressively enough.  It's probably a more prevalent problem with men than women since we tend to down-play our pain a little more.
GEORGE
Link to comment
Hi Mark,
I've missed you as well and pray for Janet's speedy recovery. I'm sure you know, but try to be careful if their "pain management" techniques involve a lot of opiates. They can be a lot of trouble in the long run, even the the short run for that matter. Please be careful.
Warmest regards,
John
Ps. George, my wife is a lot more stoic than I......when I'm in pain, I play it up to the hilt.
Edited by Landlocked123
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
