HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
I am sooooooo sorry ...
... not ;-)
XXXDAn
Yes new research shows ...
... willtellyalata ;-)
XXXDan
PS: Yes, no masts - almost - late afternoon October 21st 1805 ;-)
XXXDAn
In March 2012 I did the fore top to try out the first material for the nettings.
And also a small provocation. I placed the lantern not in the main top but in the fore top as indicated by Lavery as Nelson was only Vice Admiral. But by now I have enough contemporary sources that indicate the "classical" version.
By now it was time to do the two missing tops. Also I was using the new netting that I deliver together with my etch parts.
So I did the wire frame, glued the netting onto it, brushed the paint onto the material and sticked it into place.
To get the length of the holding line I used a tooth pick and a cheap thread :-)
And then, the surprise, the new netting appears even thinner than the old material, an effect that I liked a lot.
And yes, that is why the old netting had to go. And in the box with the discarded parts we go :-)
XXXDAn
PS: And yes, the opportunity was taken to bring back the lantern onto the main top :-)
Yes, completely.
I was affarid that you would not model nelsons place of death.
Would be an ommision to this otherwise great build :)
Jan
this is a very interesting thought.   have you given any though to it?   I have something here I thought you might enjoy
http://www.eyewitnesstohistory.com/lordnelson.htm
wonderful bit of progress Daniel.....great way to make belaying pins  ;)    the netting was a scary moment.......I thought to myself  "boy,  Daniel doesn't need little ones or animals around.......he's his own worst enemy!"............but you proved once again,  that there is a method to your madness.  this is why I enjoy watching your build.......you add so much to it  :)     the above entry..........don't read a lot into it.   your such a whiz at dioramas,  when Jan made the comment,  it was the first thing that came to mind.   there is a picture there.......it would be interesting to see your interpretation of it.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
@ Jan
This is material to do with flower decorations, parcels, wedding dresses and this kind of stuff. A forum mate in the german forum found it and I got a whole role for use with my etch parts.
@ Thank you popeye :-)
But I think that would be too emotional for me ;-)
The belaying pins are on base of Phillip Reed, always worth to have a close look at his technics.
XXXDAn
Edited by dafi
Actually ...
... some parts out of this box already ended up on other builders Vics :-)
XXXDAn
One could almost build another complete ship out of the discarded parts!!
As long as your having fun along the way. Good work.
Regards, Scott
Completed builds:
Awaiting construction:
That Avatar of Foxy made me think  - Isnt it about time we had a fresh new series film on Nelson and his life. :) :) :)
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you Sirs!
As a small sign of life, I did some parts that look easier than the way I wanted them to do :-)
The gunwale from fo´castle to waist, the on-molded partners needed to be replaced. In P. they have to rolls for some running rigging incorporated, so that was a "wannahavethat2" ...
...ok, once in the mind, never to leave again.
Made a green master, that far that good, but ...
... to get 2 fitting holes into that thin structure proved quite a task. Some pre drilling in 0,25 mm and finalizing with 0,3 mm and the holes were through ...
... and still fitting a base underneath the circular section that houses the spare spars ...
... and then the exciting moment ...
... of the mock rigging, and it worked, the rope went through.
XXXDAn
Edited by dafi
And following the disaster end of August I proudly declare that Captn Hardy ...
... has the ceiling of his cabin finally repainted  :-)
And the forecastle is done too :-) :-)
... and some more beauty shots from the kitchen  :-) :-) :-)
The pikes are only on one side of the mast as the main stay is passing on starboard.
XXXDAn
this could also be applied to other vessels with multiple railing belayment!  :)   great idea Daniel!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Daniel
Could not hit the Like Button so many times, just phantastic (as ever) :cheers:
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
Thank you Sirs for comments and likes!
After the model makers meeting in march I originally wanted to tidy up the anchor handling presentation, in the meantime stumbled over the top-tackle scutles, so it is time to link the both. For this I need the pendants from the tops, so time to look for that ...
So first step to worm, smart and serve the rope ...
... bound the loop, threw it over the mast top ...
... and let ot a big scream as the binding was on the half round chock and not underneath ...
...AAAAARRRRGGGGHHHHH...
So a longer loop was done and a picture taken for that nobody can say they did not see it properly.
And really this time it fits underneath the chock :-).
Making the cringles is a mostely easy task and already documented some time ago ...
... oup there the 1 mm tube from the old tests, now the slight thicker one of 1,3 mm :-)
But then turning the cringles in, thaaaaat is something different ...
Left the first trial, right the newer one, I think some more 2716 pieces and the result will be fine
And the pendants in place :-) :-)
XXXDAn
Amazing work, Daniel.  Even more amazing when one thinks about the scale.   Yikes..that's tiny.
But he still needs the upper gundeck before the masts can be stepped......
And considering he is only into his fourth (?) year for the lower gundeck, I 'm not sure whether we normal mortals will see this beautiful ship fully rigged.....
Jan
A tad longer my dear Jan, a tad longer :-)
That is how the gun deck looked in 2010!
As my dear wife says: Did not change too much, did it?!?
XXXDAn
Edited by dafi
And then still, the kit was bought on 02 November 2001 and started not too long after, but had a 6 year hiatus due to missing working space.
XXXDAn
considering the road you've taken us on Daniel........I'd say it's been a very informative trip so far  ;)   all roads do lead home sooner or later.  besides,  don't you have one that the gun deck is partly,  {if not fully} filled out?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Not quite right yet, my dear Jan, not quite right. Too two-dimensional.
Much more ups and downs, much more like this :-)
XXXDAn
Edited by dafi
