Blue Ensign
  1. Blimey Ian what a labour of love to produce that chain. I'd have lost the will to live after about 20 links Looks excellent on the stern with the spectacle plate, well done B.E.
  2. Happy Birthday Mark, if it's a modelling day may you achieve a warm feeling of satisfaction from your efforts B.E.
  3. Welcome to the 'Swan' club Mike, looking forward to seeing her develop. B.E.
  4. Hello Louis if I may offer a comment, you seem to be moving very quickly on your build, and you may find it beneficial to step back and familiarise yourself with the basics of hull planking. It is better to treat the first planking as a dress rehearsal for the second layer and time spent getting it right pays dividends in terms of much greater satisfaction. I don't know if you've seen it but here's a link to the main MSW site and pdf downloads including simple hull planking. http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php I know I found it of great benefit when I returned to wooden kits after many years away from the hobby. Regards, B.E.
  5. You mean this sort of thing Nils http://www.maplin.co.uk/p/flexible-snake-scope-camera-n41gw B.E.
  6. A very unique build Nils, love the fascinating insights to life between decks, great imagination and ingenuity. B.E.
  7. A fine bit of Parquetry work there Augie, very nicely done, and a good 'how to' as well. B.E.
  8. Me neither, I find it so much more difficult to maintain a clean line with a spiral. Probably to do with my low skill level, but I manage ok with the standard blades. B.E.
  9. Alerted to your build by your visit to my log Rich, you are making a fine job of your Connie, nice work on those gunports, and the natural finish hull looks great. You have a fine display model in the making. B.E.
  10. Great progress all round mobbsie, I love those bow shots a couple of pages back. You mention the Hardknott pass, I call it scary pass, always manage to meet another 4x4 coming the otherway right at the point with the rock face on the inner side and the unfenced drop on the other. You can guess which side I usually find myself on Cheers, B.E.
  11. That's how I see it Martin, although on my Pegasus the after hatch is battened down and covered by the grating. ps: I have too many senior moments these days not to be patient. Cheers B.E.
  12. I've looked at the plans for Fly Martin, they are essentially the same as Pegasus. As far as I can see the ladder way from the Qd down to the upper deck is forward of the capstan on the QD. The railings just forward of the Capstan can clearly be seen. B.E.
  13. I'm not sure I follow your understanding of the Ladderways Martin. There is a ladderway at the fore end of the Upper deck, and another one behind the Capstan on the Upper deck both leading to the Lower deck. I have fitted the fore hatch ladder, but the aft hatch ladderway is covered by a grating, and I saw little point in fitting a ladder, particularly as the whole set up is covered by the Quarterdeck. The ladderway from the Quarterdeck to the Upper deck is, as on the plans and the kit, forward of the Upper Capstan. Regarding the coamings and head ledges; to finish those off the grating has to be removed, and to get the grating edges flush with the coamings they also have to have careful final shaping out of the framing. When I made up my hatchways I first made the gratings to the closest full segments, and then built the framing around them. This avoids having those niggling little stubs sticking out of the edges. Cheers, B.E.
  14. That's a very fine and appealing model you've produced there Mick, I like it very much. B.E.
  15. Love those overhead shots Nils. To keep the guns steady for rigging, I fixed them with pins thro' the bed of the carriage. I pre-drilled the deck to take the pins and when I was ready to fit the guns they were secured with a spot of ca on the pin end. B.E.
  16. Hi Martin, I used the kit gratings. Once I had got the round in the head ledges I was happy with I inserted the made up grating and and simply sanded it from the centre each side to match. Here's a link to how the finished one for the Fore hatch looked. http://modelshipworld.com/index.php?/topic/332-hms-pegasus-by-blue-ensign-victory-models-enhancing-the-kit-a-build-log-of-sorts/page-2 It doesn't really matter that it is too thick because once in place it doesn't show. Cheers, B.E.
  17. Nice replacement figure Lukas, that winged shield figure on Superbe is a pretty ugly device. When you come to rig the 'show' guns on the upper decks remember the French rigged their breeching ropes thro' the sides of the carriage, not around the cascobal or thro' a breeching ring as on British ships. B.E.
  18. Hi Martin, I used 5mm starting depth for the head ledges and 3mm for the coamings as I recall; it was a conscious decision as I wanted to achieve a visible curve in the gratings without making them too thin on the outer edges which would create problems with them breaking up. The grating sit on a 1mm square ledge glued around the inside of the ledges/coamings; the head ledges were rounded down to meet the coamings and the gratings now in place were carefully sanded down to meet the round in the ledges. I think the head ledges finished up at around 3.5mm at the central point. If you intend to have open hatches it is worthwhile gluing some square stock beneath the deck openings to represent the hatch framings and give a little depth to the hatches. Cheers, B.E.
