Everything posted by dgbot
I remember getting my hand pulled into our slitter. I was leveling out material as it was going through and my hand got caught in a tear. I stopped it but still got banged up. Fortunately for me just banged it up. The blades were not being used at the time I remove them when not in use. Safety first. David B
- 625 replies
- bounty launch
- model shipways
You are doing a real bang up job. Keep up the good work.. Ironic spring is coming up and you can go to a tropical island for awhile. I would have Disappeared in January and stayed through Mar. But that is life. Fantastic model I wish I could see it up close. If possible I will be going to Mystic this year. It all depends on many things. I am sure you will have that beauty on display to show off your tremendous achievement. David B
- 241 replies
- queen annes revenge
- pirate
Great looking model. Too bad I cannot eyeball it. I am sure that some of what you did was part of an educated guess or were you able to get all the info from the museum? Have fun on a tropical paradise. Where you can at least have some warm toes. David B
- 241 replies
- pirate
I have a Paache H that I had for years. And now a Badger 360 Renegade. Both do the job. The Badger takes a little longer to clean out with acrylics but is worth the hassle. Once you get some practice you will never pick up a brush again if you can help it. Great video. And both are perfect for everything we do. David B
When you put out a book it will be fantastic. I am learning more every time I come to this log. David B
- 3,618 replies
- young america
- clipper
I think caulking for deck planking should be a little subtle. That is why I use a pencil of the edge. It all depends on the scale of the build. Plus when using line for the caulking you have to be careful when smoothing the deck. Good luck. David B
- 962 replies
- sovereign of the seas
- ship of the line
Magnificent piece of work Remco. Real clean and neat. What kind of wood did you use? David B
- 1,215 replies
- sloop
- kingfisher
I have always consI deed S.I.B.s magic. You reinforced that belief well done. David B
- 170 replies
- ogallala
- praire schooner
Nice Carving Tools/ Wood Chisels
dgbot replied to Cap'n Rat Fink's topic in Modeling tools and Workshop Equipment
Flex cut makes good chisels that hold an edge well. David B -
Is there a better #11 blade handle
dgbot replied to roach101761's topic in Modeling tools and Workshop Equipment
When I find Excell blades I usually get them as they seem to hold an edge longer. I by both in bulk when I can. For delicate work I prefer a scalpel for agrees I've work a number 11 blade. David B -
I think you are making the caulking to wide for the scale. Nice idea but go thinner. My advice would be use the line as a spacer and after the deck is planked and smoothed put it in. That way you will have a neat look. David B
- 153 replies
- swift
- Artesania Latina
Tapering masts, spars and yards
dgbot replied to bryanc's topic in Modeling tools and Workshop Equipment
Use a small block plane and shape the spar then I put in a mototool and with sandpaper smooth it out this works for me. David B -
I found beech a nice wood for masts and spars. As for the drill method. I have started out with shaving shaving squart stock to the dimension I want then starting with 120 grit sandpaper run it until round then progress to finer grit to get a smooth finish mark the dimension and shave again then start over until the final shaping. About a half hour to do one then on to the next. David B
- 131 replies
- rattlesnake
- model shipways
Mayflower by SawdustDave - Finished
dgbot replied to SawdustDave's topic in - Build logs for subjects built 1751 - 1800
They are indeed works of art. Gold medal winners. David B -
I hope you get better soon Cap't Steve and hopefully you do not become a 6 million dollar man. David B
- 625 replies
- bounty launch
- model shipways
I prefer using Elmer wood filler. A little bit goes along way. David B
- 786 replies
- Royal Louis
- Finished
Your deck is first rate. David B
- 831 replies
- Armed Virginia Sloop
- Model Shipways
Ship Model Restoration
dgbot replied to Old Coasty's topic in Painting, finishing and weathering products and techniques
Be careful when you clean the painted surfaces. The paint may come off from oxidation. David B -
The Endeavor makes into a real beauty. And lends itself to add ons if you feel the need. I hope you have fun. David B
Have you thought about how to rig the bowsprit? It will be under stress and from the way you have it it snap off when you are in the middle of rigging. No support. David B
- 4,152 replies
- cutty sark
- tehnodidakta
