Everything posted by gjdale
Hi Carl, I've been tempted by this little kit on numerous occasions, so it's good to see one being built. I'll follow along with interest.
Hi Kevin, I know that some people like to glue/pin their masts in position, but I have never found it necessary. The Standing Rigging will hold it securely in place, and if ever the ship were to be damaged, it is then an easy matter to remove/replace the mast (which would not be the case were it to be glued/pinned).
- 1,319 replies
- caldercraft
- Victory
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
gjdale replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Congratulations on your new job Doris. I hope you still manage to find enough time to progress your exquisite models.- 883 replies
- royal caroline
- ship of the line
Great work Frank. Your models are always that little bit different with your weathering techniques.
Lovel work, as always, Augie. The stove looks fantastic - hope you managed to finish it in time to cook the crew their Christmas dinner!
- 2,191 replies
- confederacy
- Model Shipways
Wow Sjors, what a great looking rear end! Fabulous work mate, Aggy is looking quite splendiferous. Merry Christmas to you both.
- 1,616 replies
- caldercraft
- agamemnon
Hi Sean, I've just gone and dug out my AOTS book on Victory and it tells me (pg 18) that the gun tackle blocks were all 11" (both side and train tackle). At 1:90 scale that works out at 3mm almost exactly, so your blocks are actually correct. They just "look" too big. At the end of the day, it's your call and you are the one who has to be happy with the results. By the way, the same reference tells us that the breaching rope is 9 1/2 inches (that will be circumference). I'll let you do the math to work out if yours are the correct size (though they look about right to me). Hope this is helpful. Cheers,
Sean, as you asked for "brutal honesty", I would say the guns look pretty good, but I still think that all of the tackle looks over size for the scale. I think I used 2mm blocks for the side tackle. I know that Syren does some in this size. It might not sound like much difference, but a 3mm block is 50% larger than a 2mm block. Sorry, but you did ask.........
I have the Excalibur 21", purchased through Carbatec and have been delighted with it. If you pick your timing right, you can get it for about $200 or so less than their regular retail - they go on sale periodically. The only issue I had with mine was a breakage in the upper drive link assembly. It seems that since I bought mine, they changed the design and "designed out" the part that failed - which is a long way of saying, you won't have the same problem! Carbatec were excellent in their support service and helped me to identify the new parts I needed and then sent them to me very quickly. In short, it is an excellent machine and well worth the money. Best of luck with your shopping!
Very nice work so far Gary. Love the extra detail on the gun deck.
- 85 replies
- finished
- caldercraft
Revised Chock Making Method I wasn’t entirely happy with the chocks in my test frame and decided to try a couple of different methods. In the end, this is what I did. I first marked up some “construction lines” on the frame template, and then cut a cardboard template strip (from a manila folder) to suit the width of each of the chock sizes: Then I held the frame sections in place over the template and traced around the inside of the scarf joint to mark the chock shape onto the template. The shape was then transferred to the chock “stock” and finessed to shape on the Byrnes Disc Sander: This worked reasonably successfully, so will continue with this method for the remaining frames. Here’s a shot of the finally finished frame D1/D2, complete with blackened bolts, in position in the jig. Now to make a few more……..
- 456 replies
- finished
- bomb ketch
Hi Sean, The smaller blocks are definitely an improvement and they look okay with the frapping. The only other thing I could suggest would be to have a look at Dafi's photo etch material that he supplies for a 1:100 scale Victory. I would think that the scale difference would work in your favour here. Might be worth investigating/considering.
Looking terrific there Bob. As Augie said, enjoy the holiday/family time, but as this is to be an "extended" visit, I'm sure "time off for good behaviour" will allow you the occasional visit to the shipyard!
- 1,477 replies
- essex
- model shipways
Congratulations on reaching a major milestone Mark. She looks great and I can't wait to see the planking started. You must be feeling very pleased with yourself - and rightly so too, especially after the brave decision to start over when Ver 1.0 wasn't going to plan.
Lovely little touches of detail to complement your fine build there Gil.
- 755 replies
- finished
- caldercraft
