Everything posted by BANYAN
Harpin
BANYAN replied to piratepete007's topic in Building, Framing, Planking and plating a ships hull and deck
Thanks Pete. As to the S / F - I think it was simply that this was the way they wrote the S which looked like a long F back in those days Good luck with your book. cheers Pat -
Hi folks, I have a follow up to the initial question. Thanasis shows the fairleads that were probably used in HMCSS Victoria in the third option of his post above. Harold Underhill confirms this and also supplies a probable fairlead rigging plan in his book "Masting and Rigging the Clipper Ship and Ocean Carrier". However, while implied in several books, there is not a clear statement made as to whether the bundles of lines leading through these fairleads go to a single belaying pin, or separate pins. The respective rigging plans suggest/imply they belay to a single pin (usually as a group/bundle of three lines, including any combination of the following - 2 x bunt lines plus one other line being either a leech, clew or downhaul). Does this make sense to have these lines (usually of small diameter cordage than other running rigging) belay to a single pin? cheers Pat
Harpin
Another interesting tid-bit Pete - you writing a book with all this research? cheers Pat -
Hi Greg, you don't muck around do you? A guy goes on a short holiday and you finish one and well into another Another interesting build you have selected and it appears you have set this one up for an extended amount of time at sea - will follow with interest. cheers Pat
I am on my way home Carl, a couple of days to go Glad to hear your back is improved - if your doctor is inclined, can he write me one of those prescriptions also cheers Pat
Excellent detail and great workmanship Chuck (as always); she looks good. cheers Pat
- 1,051 replies
- cheerful
- Syren Ship Model Company
You have made some great progress while I have been away on holiday Gerhard; nice work. cheers Pat
She fairly bristles with guns; great effort mate. cheers Pat
- 786 replies
- Royal Louis
- Finished
Some very nice progress there Denis. I have (still am for a few days) on holidays and not checking in too often She is looking grand! cheers Pat
- 453 replies
- thermopylae
- sergal
Welcome back Carl, hope Stockholm was all you hoped and that your back continues to improve. Look forward to your updates. cheers Pat
You can also get paste solder specific to copper I think - may also help. Try a jewellers supply store; AJS in Australia used to stock it. cheers Pat
The trials and tribulations of planking Steven; I am glad to see you persevering with this nice build. cheers Pat
Nice build Gerhard, I have been following a long for a while but not commenting - just enjoying cheers Pat
Nice!!!! Up to your usual very high standards Rusty. cheers Pat
- 310 replies
- cheerful
Nice work Chuck, those anchors sure looklike iron, and the puddening looks very neat! cheers Pat
- 1,051 replies
- cheerful
Sorry to hear of your continued ails OC; I hope some improvement can be found for you soon. This must be very frustrating for you not being able to get to the modelling desk yet alone use the PC. regards Pat
Hi Phillip and Gerhard, I would leave them Phil - I am pretty sure she was fitted with a feathering propeller and the pitch would have been close to zero when not needed (such as in port or when under sail alone) - depends on how you would like to depict her. I had the same problem to contemplate when fitting the prop to 'Victoria" and ended up going for zero pitch as she will no be modelled with sails or underway. This is just a suggestion - your model, so please depict her how you wish. Nice work with the progress you have made, she is really starting to take shape. cheers Pat
