HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. oops Glad you were able to extract and repair it John - Don't you just hate those moments? That is a really nice looking model, will she be going home with you or remain at the museum? cheers Pat
  2. Looking good Carl, a lot of good detail that will make these guns look great in-situ. cheers Pat
  3. I have not worked with boxwood much Vossie, but is it possible that it has natural oils and that this concentrates in some places more than others? As to the counter I think black would contrast quite well with the near white of holly and make the holly really pop - no harm in painting a bit of black on some off cut and use it as a visual reference/comparison? cheers Pat
  4. you've really got a grip of this airbrushing lark now Greg, looks very good. cheers Pat
  5. Unfortunately, I can't say too much due to "Disclosure Limitations" Denis. The movie is fiction and very loosely connected the ship. They needed a model for the final scene and I had the only model available - so not about the model cheers Pat
  6. Will be good to see you back in the shipyard Denis; hopefully you are well and truely on the mend this time. cheers Pat
  7. No progress on the boats as I have been concentrating on researching and building HMCSS Victoria. Just thought I would let folk know that my Endeavour is to be used as a film prop in a forthcoming movie being shot in Melbourne - I can't release details but it will feature prominently at the end of the movie and while the credits roll. A nice little 'return' for all the hours spent. So off to the shoot today. cheers Pat
  8. Looks pretty good Vossie, the second layer has a very good base. It seems you have tamed the beast cheers Pat
  9. She's seen some serious sea-time this one; that is very effective weathering Greg. cheers Pat
  10. ...and slowly she emerges That is really looking like the form of yet another very nice set of lines Russ cheers Pat
  11. Mark, what about taking a bit off the ends of a few of the after runs (the amount equal to a beam separation distance). If done at random, would this not generate the staggered butt pattern? I am assuming the planks are only dry fitted though? cheers Pat
  12. Great progress Dave, your build is looking very good. A very helpful resource in those drawings; wish I could find something like that for my research. cheers Pat
  13. That's great progress Russ with a nice transition for the rabbet. cheers Pat
  14. Hi Sport and Pfalz, If you are interested just contact Michael via a PM; that's what I did. cheers Pat
  15. Nice job Ulises; how did you achieve that? Now the gun production line can begin cheers Pat
  16. The ship and the figure look great, nice renders. Magnus, it was not uncommon for the cook, or his offsider to have a wooden leg or hook arm, as that was one of the few jobs a disabled crew member could sign on for if not fully able to man the yards, or do landlubber tasks. cheers Pat
  17. GemmaJF, i would be concerned with foam as after a while it starts to break down. I used balsa, which I sealed with a diluted PVA - would this cut with the CNC hot wire cutter noting its composition? Then again, I do not know the longevity of balsa either It might also be better to move this as a separate line of discussion rather than clog-up Mark's build log if there is much discussion on it? cheers Pat
  18. Glad the airbrush has turned out to your liking; can't beat good tools that are handled correctly (work or play) You have leap frogged me in application though as I have never tried layering shading etc. After seeing your efforts here I may consider this as an option for Vampire as i have the original resin hull to play with first. cheers Pat
  19. Nice bit of kit bashing Jason, those galleries have come up very nicely and will look even better with the decorations. I found the other trick with the scraper mouldings is the choice of wood. cheers Pat
  20. Thanks Dave, that's great feedback. I really need to get myself to one of these in the future cheers Pat
  21. Nice work Carl; that bling is adding some nice detail. Could always drape a thick chunky gold chain around it also cheers Pat
  22. That is stunning Greg, really good work with the airbrush. Weathering; looks like you have started - there appears to be some nice grime effect in the gun tubs at least. and the looks of some rust on the leading oblique plates of the rangefinder extensions? cheers Pat
  23. Hi again folks, as promised some initial thoughts on some of the clamps Michael is developing for the third arm. The flexibility of having clamp options is one of the greatest assets of this design as you can select the clamp best suited to the task at hand. I will explain each clamp style/type with photos (as required) and accompanying text. For the initial testing, I used some PE flat strips, some hard wire brass eyes, soft copper wire eyes and offcut wood (soft and hard) - note to oneself, don't over pressure when clamping softer woods First up is the toolmaker style. I find this one very useful for many tasks both metal and wood as even with hard edges to the metal of the clamp, the parallel action allows an even clamping pressure. It is the best overall design for soldering tasks. Further flexibility can be achieved with the use of sacrificial wood/plastic jaw inserts for non-soldering tasks if marking of the material is a concern. however, the parallel action of these jaws minimises this risk and I have successfully held all materials mentioned above in the jaws with sufficient pressure that it would not move in the jaw, and without marking the materials. Second, the two metal finger style clamps. I found the one, with the O ring, the most versatile as it opens wider and applies sufficient pressure to hold most things; but I don't know how that O ring might cope when using it to solder things - the mechanism copes well and seems better/easier to control the pressure than the other type, and provided better clamping effect/pressure overall than the type 2. It held the wire eyes easily and did not crush/marr the copper one. I did not try wood in these as I do not see a purpose for doing so. The second of the finger types is better in principle for soldering (no parts to melt), but does not open as much and I found that it did not grip the flat PE very well as I think the gripping pressure is only applied at the tip of the clamp (the PE strip shown in the photos rotated very easily even with extra tension on the thumbscrew). Which of these would I use? I prefer the O ring style (type 1) for function and gripping, but I am worried about using an O ring which would probably melt/deteriorate with heat during soldering? Michael has explained that it is really not designed for soldering and the toolmakers style clamp is the better option. Now for the wood style Clamps. These are designed primarily for rigging/use with soft materials. Again, these function beautifully and I can see a lot of use being made of this pair . These are constructed from boxwood which provides a soft mouth (jaws) but retains sufficient density that they will not wear too quickly. Michael provided this pair with two grooves made by crushing a needle of the required size (to suit the scale rope) between the jaws. the user can do this to suit the tasks and other sizes of rope, but may need a additional clamps. That said, for one of the tasks I had in mind I prefer to run the rope between two clamps longitudinally (see out of focus photo - sorry) when doing some rigging tasks. This is where I still think a collet style clamp may be more flexible, but have yet to be convinced, as you would not want to have a myriad of crossing grooves in the wood jaws for different sized threads and directions of holding them. I have yet to try wire rope as I have not made any up yet. I am also concerned that wire rope would mar the jaws of the wooden ones, and that the metal jaws would crush the wire strands out of shape permanently? All to be investigated/tested later. A couple of ideas I am investigating which may assist in rigging blocks, soft or hard eyes in rope etc. A rod, of the same size as the other clamps, with a 90 degree thin hardened wire bend soldered on the end, upon which you can slip a made eye, a block etc to assist with rigging? The photo below shows the concept. Another way of achieving the same functionality, and much easier for the user to do themselves, would be to put a pin (old micro-drill shank of appropriate shank sizes) in the top of the wood clamps. See the second photo of simulated pin in wood clamp concept. That is all for today, I hope you all find this feedback useful. cheers Pat
  24. Hi again folks, To say I am impressed with Michael's third hand tool is a gross understatement - the versatility of this third hand with interchangeable clamps makes working with rigging and small metal parts a breeze. Before proceeding, I must state that I have no financial or pecuniary involvement with Michal and offer the following for the benefit of MSW members. I must also declare that Michael has provided several clamps for me to trial and comment on, but I have purchased the third arm and initial set of clamps at the advised price. I have received some additional clamps from Michael today. I have completed some very quick tests and offer the following initial comments; I will provide further feedback after further use of them over the next few days. Within my feedback I will also include comments on the build and test materials, the sizes and locations of the tightening screws, and on the types of clamps and modification to them. I hope to also complete a comparative test on soldering various items with the clamps in Michael's design against the GRS soldering station. The tool itself, and the clamps are all very well made with only quality materials used. Using it, you get the 'feel' that this is a quality tool and gain some confidence the tool is not going to wear out or break like some of those cheap third hands. The only small problem might be that some of the springs may need to be replaced later in a clamp's life (depending on usage and clamping pressures used). I opted for the rectangular base which has proven very useful. The weight is just right for stability and the aluminium is strong but light, reducing postage costs; and the shape also lends to easy clamping of the base to the bench for additional stability. First up I will address the tool itself. The design at this point has met tasks I have tried. The height of the cross bar is low enough to create good stability, but high enough to get under and around anything I have tried clamping. The height of the arms seems sufficient for the task also with enough room for wrapping seizing around the object without getting caught up in the arms or having to poke the stock through. The length of the main crossbar is of a good length, and if more is required, this design would allow easy replacement. The functionality/flexibility of the tool is very good with an extensive range of positioning and clamping options to suit the task (and Michael is working on additional clamp options). I found it much easier to position the arms on Michael's third hand, for most jobs, than with any of the other versions I have, including the GRS Workstation mentioned/shown in my first post. The arms can be positioned in almost any position required without the minute tweaking required from the ball and pressure plate with wingnut type joints. I find tweaking the GRS problematic for those minute adjustments to get the position of the parts to be soldered 'just right' - I found the thumbwheel control on rotating joints so much easier with this design by just slackening off a tiny bit of the pressure while adjusting. Once the arms have been positioned, the clamps themselves can be readjusted quite easily if required, and just the right amount of pressure can be applied using the thumbscrew, rather than a one pressure suits all approach using the spring clamp options or alligator clips. The increasing range of clamp styles will also allow selection of a 'fit-for-purpose' clamp for the job. While I could not achieve the same direct angling of the arms in some positions (as with the GRS - see photo for difference), the design of the clamps still allows me to get the required angle. A possible design tweak might be to provide an articulated elbow in the vertical riser arms; however, the more complexity added the greater the risk of something slipping? That said, applying the right amount of pressure with thumbwheels on some of the rotating joints takes some exertion occasionally. I believe Michael is aware of this issue and thinking of replacing some of these tightening screws with the ball lever style. My collection of clamps (Happy Days) I have now tried several clamp options which I will comment on in the next post. As always, comments and feedback are most welcomed. Cheers Pat
  25. Per, I simply hook up a cheap workshop vac to my Byrnes Thicknesser and use it indoors with no issues. A little dust is lost when you feed and extract the wood through the mouth but not a lot I find. the biggest bugbear is having to clean the filter in the Vac a lot - seriously looking at a cyclune system (if they separate such fine particle - still investigating). cheers Pat
