Everything posted by druxey
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
I don't believe that fids were ever made of wood.- 1,013 replies
- gun dispatch vessel
- victoria
Willkommen! Yes, the rabbit hole of fine tools is one that one can dive deep down into, as well as that of ship models. Each is a great excuse for the other.
I suspect that the fid would have a beveled bottom surface. To make the slot for the fid other than vertical would invite a split in the wood. Mast stops would probably have been at right angles to the spar. The eyes of the stays would be able to bend sufficiently, as in other vessels.- 1,013 replies
- victoria
18th Century Harbour Crane by Ekis - Shipyard - 1/72 - CARD
druxey replied to Ekis's topic in Completed non-ship models
Very nice result.I like that you showed the interior mechanism as you have. It would make a great item to show in a full diorama! -
No of course it isn't, Rob! I'm sorry if I gave the impression that it was. These are representative vessel types to illustrate various points of practical shipbuilding. They are all generic; titled 'Brig', 'Ship', 'Pilot Boat', etc. However, all have relatively vertical stems.
- 3,560 replies
- clipper
- hull model
It's funny how, sometimes, the things we look forward to with dread turn out to be not such a big deal after all. It's the pieces that one thinks will be easy that trip one up!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
- 3,560 replies
- clipper
- hull model
If it's of any help, the draughts in McKay's book all show almost vertical stems.
- 3,560 replies
- clipper
- hull model
The extension lines (the ones between the ends of a measured dimension) at the right end of the drawing are not separated from the drawing itself. That is the origin of the confusion.
Cutter Grace 1763
druxey replied to tabycz's topic in CAD and 3D Modelling/Drafting Plans with Software
On a side note, can anyone identify the item forward of the tiller (photo above) that appears like a diagonal crest? Another oddity is the wheel almost against the bulkhead. How was it connected to the rudder? One would need to steer the wheel facing aft! Was this a later addition? -
A real milestone, Steven! Well done at sticking to it until all the oarsmen were complete. You just crossed the finish line of the marathon... or am I mixing my metaph-oars - I mean metaphors?
Cutter Grace 1763
Craig: Your schematic sketch is about right. Open so that the tall rudderhead can pass through (which is unusual), but perhaps there is a rudder coat around to prevent water coming up or going down and a hinged lid on the aft part, like the one just above in post #12. -
Beautifully executed. I think what is bugging you is the size of the ball on the end of the anchor stock. It only needs to be large enough so that the stock won't slip through the shank. Otherwise, it looks very, very convincing.
Stealers
druxey replied to Sheerline's topic in Building, Framing, Planking and plating a ships hull and deck
You have a great attitude! Part of the problem you have is that the hull form is a very full one with round bow. This is the most tricky shape to cover neatly, but it can be done. As you've discovered, there's lots of advice available here.- 23 replies
- hms victory
- corel
Stealers
Do also read one of the planking tutorials on this site. It will help you get this planking business in perspective!- 23 replies
- hms victory
- corel
