Everything posted by druxey
Can i live without a BYRNES TABLE SAW
druxey replied to shihawk's topic in Modeling tools and Workshop Equipment
Never buy a cheapie. It's a snare and delusion. You'll never regret getting a quality tool, be it machine or hand tool. -
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
druxey replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Best wishes as you seek a new job, Doris. The model(s) look lovely.- 883 replies
- royal caroline
- ship of the line
I wonder how many tons of iron were used in the real ship for all those bolts? Beautifully executed as usual, Ed.
- 3,618 replies
- young america
- clipper
Impressive record, Garward. Congratulations and well done!
- 50 replies
- cannon
- le fleuron
Usually a little more: 12" to 15" is the range.
Keel taper
druxey replied to Redshirt's topic in Building, Framing, Planking and plating a ships hull and deck
Most modern texts don't deal with this issue at all, and it is not well described in primary sources. -
Keel taper
There has been much discussion on where the taper begins. In a large scale model it will be apparent if the keel is not tapered: the stern post will be too wide at the bottom, and the fore end of the gripe (lowest part of the stem timbers) will appear too 'fat'. I taper my models' keels starting where the cant frames (those that are placed at varying angles to the keel) commence fore and aft. May I recommend you read some books on the ships of the era you are interested in? -
ebonizing boxwood
druxey replied to Kurt Johnson's topic in Painting, finishing and weathering products and techniques
This has been discussed many times before on MSW. My take is that ebony is a beautiful specie to use - on furniture, not models. As mentioned by many, it doesn't bend easily, does not glue well, dust is nasty and toxic to some folk... need I go on? Ebonising is most easily accomplished by wood or leather dye. I find the latter works well for me. After painting the shaped and sanded piece with dye, I buff the finish with a paper towel and I'm done. Pear, holly or Costello all take dye well. -
The laser cutter Cheerful? Have fun getting this project launched, Chuck!
- 1,051 replies
- cheerful
- Syren Ship Model Company
Part of the problem both of you gentlemen may be facing is relying too much on station sections so far aft. You can'r assume their accuracy here. The contours change very rapidly as seen in vertical section. I'd rely far more on waterlines (aka transom shapes), buttock lines and proof diagonals to fair things up.
ancre La Salamandre by tadheus - 1:24
druxey replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
That is an interesting question! Would the three planks have been put together with tongue-and-groove joints? If not, then your suggestion makes sense. It would make more sense if the battens ran next to the frame. Then the scuttle would run smoothly without twisting. -
Hmm. More anomalies.... Well, no-one is perfect!
