Everything posted by mtaylor
Welcome to MSW. I hope you'll start a log for the kit bash.
That's probably a good thing then. I couldn't begin to imagine how much detail you would add to the monster Victory.
Greetings from Southern California
mtaylor replied to Allamagoosa's topic in New member Introductions
What's a local club? I've heard of them. MSW has been my club since way back when, even before the Great Crash. -
Like the others, I wasn't sure what I was seeing.. real or model. Your work boggles the mind.
Micromark cutoff saw?
mtaylor replied to Brewerpaul's topic in Modeling tools and Workshop Equipment
I had one once. But found out I could just as well on my modeling table saw. -
Hull building
mtaylor replied to mauryd824's topic in Building, Framing, Planking and plating a ships hull and deck
Maury, See if this helps: http://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf it's in the Database seems to have been missed as far as links the tutorials. -
Converting a Backyard Shed into a Model Workshop
mtaylor replied to Hank's topic in Modeling tools and Workshop Equipment
I think that old saying "mother nature abhors a vacuum" applies to workshops. Seems that one day, you turn around and suddenly... stuff. Everywhere with no room for more stuff. -
hi, this is Medy lin, I am ship model bulider
mtaylor replied to Medy lin's topic in New member Introductions
I've asked for one of the admins to contact you (via PM) to help get your name change.
An Introduction to Model Ship Building “Dockyard Style” Adrian Sorolla ANCRE – French Naval Archeology Collection, 2020 21X30 cm format, softback, 232 pages Fully illustrated with color photographs and drawings on heavy gloss paper 46 Euros – Available in English, French, Spanish, Italian ISBN: 979-10-96873-92-0 Available from ancre.fr What’s inside (from the author): It is obvious that building a plank on frame model has always generated a certain amount of respect within the model ship building community: even from experienced builders. Taking on the construction of a first planked on frame model from a set of plans seems daunting. No box of pre-cut pieces, no pre-milled to size lumber in required quantity, no pre-made parts: evidently, all this may seem somewhat intimidating. If being already familiar in building from kits, the concept of building from plans may be considered as the next logical step. Even if this work may bring us some apprehension, it should not scare us away, as we have already acquired knowledge in model ship building: this is knowledge we can apply through all phases of the construction. This guide was written to help the modeler through the various stages of construction. As the title indicates, “An introduction to planked on frame model ship building”, this guide will show us through the process of building our first framed model from plans. A fairly easy model to build while having fun and being supported by the numerous photos and extensive captions provided to analyze and explain each step. This guide will introduce the modeler to ship building from plans. From the first look into the plans, to the completion of the model, which will be a remarkable piece in your collection, this guide covers all phases of the construction. Although a fairly easy monograph was chosen, the information contained in this guide is such that the explanations can be applied to any other monograph by adapting the advice given and the dimension of the parts needed to whatever project you may take on. The chapter sequence guides us through the logical construction stages. The different steps are presented while taking into account the fact that not all modelers are equipped with the same tools to fabricate the parts: varying from hand to highly mechanized power tools. The choice of lumber, the interpretation of the plans, the use of templates to cut parts, wood working techniques, the use of cutting tools, the choice and purpose of different material (brass, ebony, boxwood, lead, tin, etc.) including the steps to follows, everything to build your model is explained in this guide. Table of Contents: Ch. I Choosing the lumber – First look at the plans, axial timbers Ch. II The frames Ch. III Axial structure Ch. IV Frame installation Ch. V Closing the front and back Ch. VI Planking the hold Ch. VII Fitting the hold Ch. VIII Deck construction -1 Ch. IX Deck construction -2 Ch. X Planking the hull -1, preparation Ch. XI Planking the hull -2 Ch. XII Deck furnishings and building the forecastle deck Ch. XIII The quarterdeck and stern Ch. XIV Notes on masting, ropes and rigging A few notes from the reviewer: There are a few things that do need some explanation. Some of the drawings/photos are in French such as “modelisme d’arsenal” translates literally to "Arsenal modelism" or Dockyard Style. When you run into that, a few minutes with Google Translate should give you the meaning. You will also find he refers to things pretty generally except for examples but they’re not hard to follow and sort out how you want to do it for your specific set of plans. The Review: Since you’ve read this far, you know the philosophy and a bit of the contents. It does fulfill everything it says it is. This book is about as good as it gets on how-to build a ship using the ANCRE monographs. I really can’t praise it enough. I started reading it about an hour after it showed up and literally could not put it down. It now resides in my workshop for handy reference. I really wish this book had been around when I started my first POF ship which was French many years ago. It will take you through selecting the wood, what to expect on the plans, to making and assembling almost everything from start to finish. For starters, every page has 4 or 5 color photos accompanying the text to illustrate exactly what’s being done. To say it is more detailed than any build log I’ve seen is an understatement. The written text is crisp and clear which makes understanding a given step easy. While the book is based on the plans of Le Rochfort by Gerard Delacroix at 1:32 scale, where your model might a different scale or different plans, it’s not too hard to covert the information as the basics apply no matter the plans. One nice touch is that it’s pointed out that exotic tools aren’t needed. For example, he shows a coping saw, a scroll saw and a band saw. He continues the practice with such things as sanding tools, etc. Also shown and described are the various building boards/jigs. The setup and use of the basic tools for cutting and shaping the various pieces are there. Even how to make trunnels simply and quickly with a model table saw. While the audience is intended for French ships using ANCRE monographs, the information is useful for making a ship from plans of any other nation but there are major and minor differences in the way various countries did things so take that under consideration. Also, if you’re using a POB set of frames such as those for La Belle Poule, once you have the backbone built up start with Chapter 4 but do read Chapters 1 through 3 as there is a lot of great information that applies. I should add that not everything is covered in detail such as the many fittings and rigging details which are in the individual ship’s monograph. However, if you’re interested in building French ships, I recommend as an additional reference Frolich’s “The Art of Shipmodeling” (also from ANCRE) which goes into the bits and pieces in more depth. After all, we can’t have too many sources can we? The more we have, the more we know.
Looking good. Pretty soon you'll have them singing "Row, row, row your boat" in 4 part harmony.
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
mtaylor replied to Bitao's topic in - Build logs for subjects built 1851 - 1900
Even with a 10 hour day in the shop, you're still moving along quickly.- 257 replies
- young america
- Finished
Ron, Have another model on standby to break up the monotony. Ratlines are tedious and one needs breaks.
kit review USS Missouri (or any Iowa class) 1/350 by Joy Yard
mtaylor replied to Tigerdvr's topic in REVIEWS: Model kits
I think that anyone reading this and giving thought to buying the model will ultimately appreciate your honesty.- 51 replies
Welcome to MSW, Lyle.
I'd like to offer a suggestion. Rather than make those all one piece, make 3 separate windows of 9 panes each. I fear that when you go to bend them around the gallery they will snap. Here'a photo of one of my Licorne's gallery. Once the window(s) have been made they can be fitted and the wood between the windows set into place.
