mtaylor
Moderators
Everything posted by mtaylor
  1. Candice, Have you tried Googling for it? I would hope there's someplace near you that could ship it.
  2. It seems to be a matter of choice. The advantage to working from top down and bottom up is being able to fit drop plank or stealers easier.
  3. Welcome to MSW, HakeZou. Just remember, it's not a race but a hobby so enjoy the process.
  4. Once the ribs are in the places they need to be, and glued, you'll need to "fair" it. Use a long sanding stick or block and a have a piece of the planking handy. Sand lightly, not aggressively, such that the plank lies well on each bulkhead. Also, open a build log so others can follow along and offer advice when needed.
  5. Which way is it "doubling"? Is it the keel being glued to the false keel?
  6. I'm surprised they didn't give you an extra bit track to hang off the bow as was common.
  7. Congratulations on a beautiful build. Looks quite at home in the case.
  8. You have been busy. Very busy. Looking great. If your wife understands you, she is a keeper. Stay well.
  9. The dots aren't nail heads are they? This period may be too early but I recall reading of shields with nails in them for resistance to sword slashes.
  10. I've found the best way is to make my own inserts. A piece of wood cut to match the opening and fitted. The blade is put on and retracted completely. The new insert is installed and the saw turned on. Then just raise the blade through the wood. If needed, holes can be drilled through the wood to allow dust to sucked by the vacuum.
  11. A 700 lb shot boggles the mind.
  12. They are, but there's still a lot on Fleabay, etc.
  13. Looks like you'll have a lot of stuff to hang on the outside of the tank, Jack.
  14. The delay is starting the next ship will be worth it. You're going to make a girl very happy.
  15. Well, it's all explained in that icon of military operations: "Catch-22". There's also a nice bit in "Glory Road" about the "Dirty Tricks Department" and the "Fairy Godmother Department".
  16. Welcome to MSW, Shepard. If you'll go here: http://modelshipworldforum.com/ship-modeling-articles-and-downloads.php, the first couple of posts in the Marterials and Tools portion, the first few posts are on tools to have, advanced tools and the "important" one, IMO, "tools not to bother with". Oh.. when you decide on what to build, start a build log as that's a tool also. As for a model, start simply with either no masts or one mast. Then build from your experience.
  17. Welcome to MSW, Tony. If you haven't already, start a build log in the kit area. Also, there's an index in the pinned posts on the first page. Have a look at it and you should see other builds of the same model which will help you.
  18. Love it. Looking super. I was worried for a bit that with the ladders that you were doing the "Starirway to Heaven"...
  19. Stuglo is right. I had the same issue with Licorne, so I ended up gluing the whole sheet to the blanks and then when the glue dried, cutting away the excess.
