mtaylor
Moderators
Everything posted by mtaylor
  1. John, That way is reasonable. About every 5 strake, I stopped and rechecked for tolerance build up and adjusted accordingly.
  2. For elk, possibly try the local custom butcher shop who does game for the hunters.
  3. I'm thinking you're both right, Druxey and Gaetan. Because of the drawing on Licorne, When I first read some time ago what Druxey reminded me of was that it only applied to 74's. Belle-Poule is the same way and Mr. Delacroix did tell me to reference Belle-Poule for many things. There is the inside height of the gallery which means the officer would be bent over the entire time they're in there... except for sitting. But that sort of fits in with the cramped quarters of the frigates. Merde, back to the drawing board to figure out how to do it. I've got a couple of options I think... either a rail only or the inside of the rail lined. Either way, the roof will need to stop just above the upper molding.
  4. John, The front ends (bow) actually taper on the garboard almost to a point. Here's mine.. I have a sharper bow than yours and mine also has some other differences... I also think you may have went a bit too far forward with the garboard. What was suggested to me is run the garboard from aft forward. When you get to the point where the plank it out over the stem, put a another plank next to it and keeping it in a straight line, trim the garboard into the stem... It looks like yours is bit too wide.. maybe too long... as it shouldn't curve up. What Doc said... don't lose any sleep over it.
  5. I never heard of that either until Cabrapente's post. Then again, I don't have a bandsaw.
  6. I use just a scrap of waxed paper for PVA and CA. And a toothpick.
  7. From Google Translate: Hi Taylor. fantastic job. I like the invention. I use sandpaper on the band saw. It also works wonders
  8. I've got the MM... If I were buying again, it would be the Byrnes. The MM is fiddly to use, in my opinion and does require slow feeds.... very slow feeds or very light "cuts". It's not a production unit but a hobbyist unit so read into that as you may.
  9. Silver maple also works well. Almost as white as holly.
  10. No problem, Pat. I've gathered my thoughts together and took another look at my references. Somewhere around 1765, all the frigates ended up with this look for the quarter galleries. Prior to that, their galleries looked something like this: http://modelshipworld.com/index.php/topic/4023-lamarante-by-giampieroricci-1749-french-corvette-scale-130/?p=408269(see the second photo down). While that is more of a quarterbadge being flat against the hull, the galleries were of similar design but rounded outward for the facilities. Both the English and French did seem to engage in forms of subterfuge to fool an enemy ship. For example, HMS Roebuck, a 44 two gundeck frigate has a second set of dummy stern windows and (if I recall correctly, a double set of windows in the quarter galleries)such that from a distance she would look like a 74. When the quarter galleries for the frigates changed, they all look similar. There's some differences other than size between a 8-pdr frigate and a 12-pdr frigate... but the appearance from a distance is the same. The stern windows on Licorne start at the quarter deck beams and come down. They sit high which makes the ship appear larger than she is. In Licorne's case, you'll see when I do the interior, the door to the galleries is only about 4-1/2 feet high. The roof of the gallery would have to be hollow to give the officer some room to stand up. The gallery itself is barely wide enough for an officer to sit. There was also a ruling that galleries should not be visible from astern but Licorne violates this rule. Belle Poule. Hermione, and Le Venus had the headroom but also had the decorative rail. I haven't studied all the ship's plans in depth on this but they appear to be like Druxey mentioned and what John showed. Maybe not a cistern but the area inside the rail appears to be open and some items kept there. The reasoning just seems to boil down to appearance. But I've run into a couple of things like this that make me say "Huh?" and so I follow the drawings, do a bit of research to see if this matches and sadly, I don't always rationalize it by connecting the dots like I just did. One other tidbit I found interesting is that due to the hull shape differences between French and English frigates, the French ships were crowded. The space between decks wasn't as great as the English ships as they moved the lower deck up for carrying capacity in the hold. What this caused was that the sailors basically slept where ever they could find space as hammocks wouldn't have worked. They would sleep on the lower deck forward of officer's country, on the hawse cable, in the hold on the barrels even between the guns on the gundeck. Literally where ever they could find the space. Footnote... basic differences between an 8-pdr frigate and 12-pdr... the quarterdeck extends in front of the main mast, the 8-pdr, it stops behind it. On the 12-pdr, the fireplace for cooking is on the centerline just aft of the main bitts. On the 8-pdr, it's divided into two fireplaces and they are outboard on the deck between the first and second gunport. Only 12-pdrs seem to have the bridle ports which are the only ports to have permanent lids.Hatchways/gratings are in different locations and numbers but that's due to what needed to be accessed below the deck. Hmm... I've rambled on enough for now. I admit, it's been a steep learning curve.
  11. I'd think you would still want the glue, even bent under the plank.
  12. Nils, I suspect that camera isn't able to fully use the 8Mb on the new card. I ran into that as mine uses a 4Mb card. The 8Mb card creates problems like what you're having.
  13. Thanks for the likes and comments. Pure decoration, Pat. Although on at least one French ship, this area inside translated as "the garden" and actually has usage for what appeared to be some sort of man-overboard equipment. I'll have to find that reference again. I noted that also as the NMM plans don't show that line either. But on the NMM it's not very clear as are most of the "carvings" are just scribbles that need interpreting. I wasn't aware of the cistern, Druxey. I'll file that away for future reference. I'm changing the "design" as I go on this. There were some aspects of it I wasn't happy with after seeing it in wood. Nothing major, just some tweaking to get the model in sync with the perspectives of the drawing.
  14. Spectacular, Nenad. The rework was worth it.
  15. Looking super nice, Nils. And that's a great fix on the shroud. Regarding the camera, is is the problem the built in memory chip or the removable card? I've had my SIM card fail and just replaced it.
  16. John, I can't tell from this angle, maybe a side photo would help? Here's what I see from here... If you follow this line, your planking is going to run up too high in the bow compare to the rest of the planks. The first two planks should look more like the black lines in the photo I attached. Usually, the bow planks get narrower the more forward you go and they get wider at the stern. I'm assuming this is double-planked? If it is, keep going the way you are and you'll see when done and then you can rework on the second layer. If you're like me, I'm very visual and usually need to see and do to sort things out.
  17. Greg, You got it mate. It's actually a railing attached to a solid roof and not a free-standing railing. Although, I admit I'm guessing as the reference materials are a bit vague on this and even contradictory.
  18. Piet, Are you using the thin CA? I'm not sure there's a solvent that will work as a thinner like with paint. Edit.. it just hit me... clear matte finish paint... thinned. Or clear fingernail polish.. but I don't know if it comes in matte finish.
  19. It looks like someone put a guitar pick in the rigging... I'm wondering it's just not a mistake in the drawing like someone forgot to fill in that area.
  20. Thanks for the likes, comments and good wishes. I've passed those along my lady. I'm now working on the roofs. They have the traditional "top hat" look with a decorative railing around them. So.. I did some drawings in Corel and sorting out the look I want. Then I grabbed some pear (not Swiss) stock and cut it to size and put in the Death Star. I was surprised as I forgot to change the settings but that beast almost cut them out completely. A few more watts or a bit slower on the cutting speed... It might have done it. I'm now starting to shape these pieces as shown in the photo. Once I'm happy with the shape, I'll do the decorative railing around the top in Euro Boxwood. This railing will be really a first leap into the carving arena as the rail has a lute type of shape for the uprights. I'm figuring I'll have to make each bit separately due to the curves and the shape of each. If you look back a few posts of mine to the plan, you'll see what I mean.. but while being a challenge to move my skills up a notch or two, they should be fun. I'm already having fun shaping them once I figured out how to the drops, this should be easier.
  21. Glenn, Depending on how much weathering you want, you might take a look here: http://modelshipworld.com/index.php/topic/13233-black-sea-coaster-%C3%A7ektirme-by-mhmtyrl/ Mehmet goes a bit to the "well-weathered look but he's good at it. I'm not sure how they get there... some put something on the wood, paint and when dry, wipe it off and leaves a peeling paint effect. Others use weathering powders like the model railroad guys use. I've seen a bunch of topics on this here: http://modelshipworld.com/index.php/forum/21-painting-finishing-and-weathering-products-and-techniques/ I hope it helps and you find the look you want.
  22. You should be pleased, OC. Looking great, IMO. RE: The dreaded Carpet Monster. Grab the vacuum and put an old stocking over the hose end, then vacuum the floor. The lost bit, if it gets sucked in will be captured by the stocking. Don't use a fishnet stocking... the holes are too big and it looks rather kinky.
