Everything posted by mtaylor
Feel free to name names... you got quality, let everyone know. Nice work on the guns.
- 188 replies
- surprise
- artesania latina
Meredith, There in is a big problem, especially when we talk power tools on a world wide forum. Shipping, customs, even ability to pay via credit card, etc. are just the surface issues. Power conversion is often not thought about. Some use 50 Hz, other use 60 Hz. The mains voltages are different. A transformer might work, but ultimately it can cause problems with the frequency is different. A US designed motor is for 60 Hz. At 50 Hz it will run slower and often hotter due to loading, etc. Go the other way, and the motor runs faster and can have mechanical issues as it will spin above the design rating.
Richard, At best, whatever you do below decks would have to be considered an educated guess or a reconstruction. As I recall, there wasn't much available when these plans were laid out. I think you're on the right track using the TFFM books. Other sources might be some of the AOTS books for frigates of the period. At least you'll have a good idea of where put the cabins, storerooms, etc.
As I recall, Peter was on MSW 1.0 and did some build log work on one of their models to get some feedback. I wonder if he's here on MSW 2.0?
Love it!!!! We'll clean this part up later so the links have prominence.
Post the links here... if we get more than few, we'll pin the topic. Plastic hints and tips only please. Might just remove the "painting" from the title however.
Dr. Per, What Russ said would be the way to go. When double planking, putting the keel on after sanding (and carefull grooving, etc.) simulates the rabbet and not very well either. I've done two AL kits and wasn't real happy with that result. Luckily, I realized the problem after the garboard plank and was able to fix it.
Piet, Your picture where it has the "K' designation. You said the "K"s were changed to "O"s in 1938. In my mind, that says that cutters were there from the beginning.
Very well said, Augie. I hope everyone will read this.
- 2,191 replies
- confederacy
- Model Shipways
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
sudomekh, http://translate.google.com/- 4,152 replies
- cutty sark
- tehnodidakta
sudomekh, Please use English only as this an English Only forum. Пожалуйста, используйте только на английском языке, так как это только на английском форуме.- 4,152 replies
- cutty sark
- tehnodidakta
Rob, Not worry about where the log ends up every few days. It's the nature of this forum and the number of logs being updated. There's times when I don't read MSW for days at a time and the unread list is 6-7 pages long. When you update, it will rise to the top.
- 44 replies
- cutty sark
- revell
ebonizing boxwood
mtaylor replied to Kurt Johnson's topic in Painting, finishing and weathering products and techniques
By the way, there's also this topic which has info about ebonizing: http://modelshipworld.com/index.php?/topic/3696-what-woods-do-you-prefer-to-use/ -
ebonizing boxwood
If you've ever seen a piano that's more than about 25 years old, the black keys were probably ebony. Also, many guitars have it on the fretboard. (I think that's the term for it) It's a beautiful wood when finished but a real pain to work with. -
Bob, Just curious here... we buy our wood usually from "local" sources. By that, I mean places that sell the wood to consumers such as Woodcraft, Hobby Mill, The Lumberyard, etc. We generally have no way of knowing where this wood came from. In the Gibson case, they were directly importing it. I guess I'm not sure how this would apply to those of us at the end of the food chain since I'm not a lawyer.
I'm going to pause this log while I clean it up. If you lose some post count, I apologize. I'm basically only removing the off-topic stuff that I generated and the responses to it as well as some of the early stuff when we came back on line. I hope you understand.
Sam, I like the way you are approaching this. Your last pic looks good on the seizing/knotting. As for the fuzzies... beeswax: run the line through the wax and then either work it with your fingers into the thread or move it over a light bulb to melt the wax into the line. OR Diluted PVA.. paint it with a 50-50 mix of PVA and water. Run your fingers to get it into the line to soak it in.
