Everything posted by mtaylor
Frank, I hope all went well and you can return and finish Supply soon. This is benchmark build, sir. Above and beyond.
- 389 replies
- supply
- caldercraft
Great looking boats and there's a cake to boot!!!! For a moment there I had scroll to the top of the page as I thought I'd wandered into one of Sjors's builds. Here's some popcorn from one of his builds...
- 552 replies
- maine lobster boat
- Midwest Products
Nah... I'll be running interference to keep them away... Carry on Mobbsie.
- 1,279 replies
- agamemnon
- caldercraft
Rick, Save yourself some aggravation... put it all in one log as the parts work together. This area is typically for discussion of say servos, usage, types, how-to's, etc.
Jan, That finished up to be a stunning model. I hope you'll keep it somewhere safe as it's a masterpiece.
- 37 replies
- la couronne
- card
- 1,215 replies
- sloop
- kingfisher
Kevin, Over here: http://modelshipworld.com/index.php?/topic/1520-timber-help-for-a-newcomer/ Cornwall was mentioned: http://www.cornwallmodelboats.co.uk/acatalog/timber.html I don't know if they do bespoke timber or not.
Rick, It looks big enough that you could do some amazing detailing. Feel free to open a build log in the kit area. I think a lot of us would like to see her being built.
I'm not a lawyer so this info has been picked up over the years doing software, commercial photography and technical writing. Basically you are correct. You can play it at home or lend it to a neighbor but not charge admission. You can display or use extracts (fair use) in reviews and articles but somewhere the thin line of plagerism is waiting... You can sell the original DVD/CD but not copies of it. At least in the USA. Not sure that all countries have the same rules.
David, The others have offered excellent suggestions but I'd like to step backward and address the Mamoli Surprise. If it doesn't have a full length gundeck, consider a serious bash. You'll start with a kit and then scratchbuild your way out of it. I did the AL Constellation that way. Ended up with an almost one of a kind ship. (Almost as there's another builder scratchbuilding her ). There's another builder doing the same thing to the MS Constitution. Takes some thinking through to do and it would be a challenge. No matter which way you decide to go, have fun with it.
I'm just catching up with your Le Mirage, Sjors. She looks really great with all the guns and ornamentation.
Just catching up Augie... the yards are shaping up nicely. Blisters go with the territory... And for the next build, think about the darkside. You can build whatever you want. No need to find a kit that's been built a zillion times.. like Confed. <ducks><runs for cover> Seriously, the "one of" is one of the things that got me hooked on scratchbuilding.
- 1,668 replies
- syren
- model shipways
Wow, for a bit there I thought you were going to try to make a working pump. I don't think we've seen the saucers added before on any build.
USF Confederacy by Rustyj - FINISHED
mtaylor replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
Just as amazingly beautiful as the first time around, Rusty.- 149 replies
- confederacy
- frigate
Piet, Looks like you're off to a great start towards a great finish. I know you'll do her well and have a fitting memorial to your father.
ancre Le Fleuron 1729 by rekon54 - 1:24
mtaylor replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Hi Giorgio, Excellent work. I guess you'll be adding sheaves? By the way, I added the scale (1:24) to the title of your log. -
Ron, If you haven't put in the treenails into the limber boards, leave the holes and score a line from port to starboard to cross the middle of the hole. The limberboards were about 3 to 5 feet long with drainage holes. Any water that found it's way down there would then runoff through the holes and into the limber channel so it could be scavaged by the pumps. The boards were removable so the channels could be cleaned of debris.
Posting etiquette
mtaylor replied to dvm27's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Greg, It was done on the old MSW (pre-crash) so I don't see why it can't be done here. Come to think of it, I've seen several logs where that's happened and everyone has profited.
