mtaylor
Moderators
Everything posted by mtaylor
  1. Nice work on the ship, Maso. I think those of us not retired feel your pain about not enough building time.
  2. Popeye, I include the following as a public service... the recipe for a Pangalactic Gargleblaster. It's possible that Sjors can make one for you. Recipe Take the juice from one bottle of that Ol' Janx Spirit. Pour into it one measure of water from the seas of Santraginus V. Allow three cubes of Arcturan Mega-gin to melt into the mixture (it must be properly iced or the benzene is lost). Allow four litres of Fallian marsh gas to bubble through it. Over the back of a silver spoon float a measure of Qalactin Hypermint extract. Drop in the tooth of an Algolian Suntiger. Sprinkle Zamphuor. Add an olive. Drink . . . but . . . very carefully . . .
  3. Here's mine: There's no problem so big that it can't be solved with high explosives.
  4. Augie, On the thread issue... the white glue and water mix work. You might have to play with the percentages so maybe 60% glue/40% water? There's a couple of other tricks.. water-based matte poly lacquer, hairspray. They will all stiffen the thread. If it's to get the "curve" right on the hanging part, brush it on in place and let it dry. The curve should form when it's wet and stay there after it dries. See... I can be non-frivolous...
  5. Hi Robbyn, Catdavits = catheads. BTW, the beak and head timbers are always one of the tougher bits to get right. Sleeping on it is a good idea.
  6. Clare, Great to see this one coming back. I'm looking forward to seeing it.
  7. That one looks to be the same as the one Harbor Freight sells. I bought the HF one. The biggest issue I've found is that the angles on the vise aren't dead on. I spent about 30 minutes setting it to 0 degrees to get an honest cut. Just a note.. any power tool should be checked for squareness before using. And then again during use. I keep a protractor and some small drafting triangles handy. I even check the blade on my scroll saw periodically during use to ensure a good 90 degrees from the table. I failed to do that once and cut several frames out that had the cut not at 90 degrees.
  8. Gaps? What gaps? I even zoomed in... It might be better (by some people's definition) to cut the notches off ship, but you do what's right for you. I tried it both ways on mine and found I preferred to do them "on ship" also.
  9. Nice progress, Pete. Use the sanding stick idea for working up the inside and the outside of the hull before you start planking. Putting the keelson on will help with rigidity before sanding.
  10. Looks like you're off to a great start. We can read your English just fine.
  11. A fascinating build, Jaro, and very well done. I hope you can find some time to finish her.
  12. Hmm... places like Cornwall won't ship to SA? Though I'm sure the shipping would be an arm and a leg....
  13. Crap! I hope they aren't otherwise we're all in trouble. I gotta' find out if MSW has a brig and are the rations bread and water? Or Brie and wine?
  14. I'm going to have to dig though things to find the cutters. They're buried around here somewhere. Take a look at page 18 of the PDF I referenced. It talks about grinding the cutter. I'm trying to remember who else modifies their tools and had or has pics. One of our scratchbuilders made a duplicator for his lathe and again... brain fart. I'm almost to the point of re-setting up the lathe for cannons.
  15. Robbyn, SF is looking great. I'm sure you'll have no problem with any ship you decide to build. I think there is a common thought around here: "so many ships, so little time". Are you doing any kind of therapy for your hand? Like gently squeezing modeling clay or a tennis ball?
  16. <fingers crossed for you> Life is stressful enough and then when the hammer falls, it's our hobbies and those who care about us that give us hope and relief from the stress. Looking forward to seeing the guns all put together.
  17. Nice looking yards, Augie. Hopefully the snow has passed you by so you can work on the yards instead of in the yard.
  18. I'm wondering about the "normal" comment also. You've done a fantastic job on both of these Denis. Think about how they would have come out if you were anyone but you? The details make them look like two totally different boats from different kits. Wonderful work... just wonderful.
  19. Mobbsie, you are flying along at warp speed and doing a super job. I too await your next update.
  20. Hi Frank, Good to see you back. Don't rush things. When the time it right, you'll get everything tied off.
  21. Hi Anja, I'm very happy to hear that your job situation settled down. Hopefully your blood pressure and stress level have calmed also.
  22. Gil, Your excellent work on the rigging continues. Just wonderful to see. I hope all went well (or will go well) with your wife's surgery. I'm playing catch up on MSW as my wife just had a shoulder replacement.
