6 hours ago, michael mott said:
Johann would it be possible to include a picture of the other side of the spool traveler. I am interested in how it is supported on the steel rod.
Beautiful work on the worming and serving.
Michael
Sorry to intrude into your conversation, but the server (spool traveler - as you called it) isn't supposed to be supported in any way by this steel rod below. At least in my instance, mine hungs freely under the rope being served, suspended only by the serving thread. The gravity alone provides enough torsion and tension for serving. If the server tries to rotate around the rope, it means that there is too much tension on the thread, and you have to very slightly loosen up the screw on the bobbin so that it moves a bit easier.
Perhaps the pics from Johann were taken from up and showed erroneously in perspective that the bobbin somewhat rests on the rod?
Or maybe his does rest on the rod?
I would like however to know, how he did the worming on that rope.
Edited by Dziadeczek
@michael mott
Hello Micheal,
today I took a picture of the spool traveler.
This runs on the lower axis.
I hope that your question has been answered.
@Dziadeczek
Hello Dziadeczek,
in fact, the spool traveler rests on the axis.
In the following picture you can see how I worming the rope.
This works very well with the serving machine.
Edited by archjofo
Thank you Johann that is very helpful.
Michael
Johann, it has been said here and elsewhere already very often. The way you are planning your work, the way you are performing it and especially the way you are able to reflect yourself and change things if necessary is simply astonishing. If you were a bridge builder, a car constructor, a rocket scientist: Be sure I would love to jump on your bridge, perform a speed run in your car and fly to Mars in your space ship. I dare to say: You are a shining example of German engineering. It is a pleasure to watch your build log and especially its constancy over the years. Thank you for posting it here for all of us!
Hi Johann -
Beautiful work on the servings and turning in the thimbles in the pendants.  Are you going to tar (blacken) them or leave them the tan color?
One suggestion, if I may - I found that when I seized the head of the pendants and shrouds too closely to the masthead, the total bulk of the seizings of all of the shrouds would not go through the lubber's hole in the tops.  I had to redo them so the seizing was below the top so I had some flexibility.  I do not know if this problem will arise for you, but you should be aware of it early.
Best of success on the project.  I will continue to follow along with interest.
Dan
12 hours ago, vossiewulf said:
That line has been SERVED with a 140mph ace to the backhand side :) Beautiful work.
@vossiewulf
Hello,
of course you are right.
Looks really not special.
I noticed only after your notice.
Will pay attention in the future ... 😡
2 hours ago, shipmodel said:
Hi Johann -
Dan
@shipmodel
Hello Dan,
thank you for the interest.
I will leave the pendants like this.
Your note, I will consider when it comes time.
Thanks for that.
Edited by archjofo
1 hour ago, archjofo said:
@vossiewulf
Hello,
Johann,
You misinterpreted or mistranslated his comment. He was referring to a Tennis shot. Your work is superb.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
@albert
Hello,
Thank you for the interest and the nice comment.
Thank you also for all the LIKES.
Here is a little update:
The gun tackles consist of a single and a double block. The length amounts to the original 234 mm and 4.875 mm in the scale 1:48.
Johann, the tackle looks wonderful. How did you make the hooks?  They look very scale with the thicker hook body and pointed turned tip.
beautiful work johann, and  thank you for showing your work , i learned a lott
After reading you work, i have still a question.
After you used birchwood for making the brass parts black, do you use a glue (like CA) for attaching them definitly into the wood.
regards Luc
On 2/24/2019 at 9:15 PM, vossiewulf said:
I will use less slang this time to say the guns look great. What is the finish on the guns themselves?
Again sorry, for the misunderstanding on my part.
Thank you for your recognition.
For the final finish of the guns, I have to give me some thoughts.
@Dowmer
Thanks for the nice comment.
The hooks I've done so:
I hope the picture show that.
Edited by archjofo
regards Luc
@luc
Hi Luc,
I would also like to thank you for the compliment.
Yes, I use instant glue (cyanoacrylate).
    These hooks are outstanding, too bad I work with 1:96 scale and these would really be tough to duplicate.
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
On 4/16/2018 at 7:59 PM, archjofo said:
Hello friends of model making,
thanks for the interest, especially thanks to Carl for
the last nice comment.
At the moment my job takes me a lot.
Therefore, there is little time for the hobby.
In that respect, I can only show a little.
The iron fittings of the blocks for the backstays
Other fittings are for the double blocks for the boat davits.
These blocks are equipped with hooks.
For this my first attempt. This is not optimal yet.
Johann,
another question where did you commissioned the etched parts. (I am from Belgium)
regards Luc
On 11/12/2017 at 10:34 AM, archjofo said:
The last details on the masts are made.
These are hoops around the lower masts with holders for pins,
so-called spider bands.
The holder was made of brass investment casting.
and a last question : brass casting, how do you do that?? I never seen this before. Do you have a tutorial ???
Edited by luc
