Really nice work Erik.  I can not wait to see the rest of the hull planked.
Ryland
               - Nautical Research Guild
I cut away the framing at the stern with a small Dremel drum sander.  I then cleaned the area up with sanding sticks.  I thinned the frames to 1/16" using a .060" thick piece of styrene as a guide.  With the planking at the stern still unattached, I sanded the hull bulkhead tops/stern frame tops to get the correct deck curvature.  I figured this was easier to do now, than when the stern area is planked.
Erik
I planked the counter.  Since this area will be painted red, I didn't bother running a pencil between the planks to make them stand out.  The result being, the 8 planks look like a solid sheet!  Since I've gotten pretty good at getting the planks snug against one another, I'm curious if once painted, this area will look solid, or if we'll be able to see the plank edges.  I guess I could have worse problems than smooth planking with no gaps.  :)
Erik
Heh, sounds like a good problem to deal with!
Saw some build logs where plank seams were made more visible by scribing them with some sharp tool, on an already planked hull (not before the planks are glued, but after). It was looking quite good! But must be tested first, of course.
Mike,
I've thought of doing something like that.  I'll leave it as it is though.  Once the ship is complete the counter is not really visible anyway.  I'd rather have it look smooth, than overdo any attempt to more clearly define the plank edges.
Erik
You're right, you could easily have fooled me into thinking that was a solid sheet! Nicely done.
Erik,
That is very nice displaying your work,
Even though the Cheerful is not on my list I am following this one of yours to the bone.
Very nice!
Respectfully
I planked the transom.  This was much more of a challenge than the photos indicate.  Though the transom looks flat, it actually has a pretty good curve to it, so the edge bending is quite severe.  I reduced the plank width by .010" on each plank, so the 4 planks are a uniform width going down the center of the transom.  One of the gun port lower sills is a bit crooked.  I figured this doesn't matter since the ports will be closed.  I am more concerned with making sure both ports are the same size, and true and level.  The transom and counter have both been given a first preliminary sanding.
Erik
That is some very fine planking Erik!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
I took these photos a few days ago.  I cut the trim pieces to shape using the plans . . . only to realize since my wales are a touch lower at the stern, the trim pieces were too short.  So, I cut them again.  I glued them on tonight . . . after snapping one while bending it to shape.  I managed to glue it together again with no noticeable seam.  My progress and motivation are slowing down as we get into warm weather and outdoor season.  Once I add the second layer of planking to the wales, I'll most likely take a break until the weather is more conducive to sitting inside.  :)
Erik
Always such a pleasure to look in on your work Eric. There'll be plenty of rainy shipyard days to keep that cutter moving ahead I hope.
Best, Ian
Erik,
This build log is probably the cleanest I ever seen.
The pictures are great too.
Looking forward to more.
Respectfully
lovely work on that cutter Erik,
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for all the kind words guys!  I won't be setting the Cheerful aside.  I'll still work on it when I have time.  I just acknowledge that here in Colorado, it's best to take advantage of any warm weather we get.  BBQing, hiking, biking, etc. are calling.  :)
Erik
Heh, you definitely live in Colorado if summer is outdoors time. Here in Missouri, heat and humidity are quite conducive to quiet indoor model work. Excellent work as always, I look forward to more when you get around to it!
  • 4 months later...
Steve,
Thanks for checking in, and the kind words!  Life has kind of gotten in the way of my build these last months.  I spent some time traveling around Iceland and Norway for a while . . . er, call it research for future projects.  Also, my father passed away last month after a long and painful battle with cancer.  Lots to try to wrap my mind around lately.  So, I've been working on getting my feet under me again.  That said, I'm still on here regularly following everyone's progress, particularly the other Cheerful builders.  One things I was able to share with my father in his last year, when he was very ill and house bound, was my longboat build, and the progress on my Cheerful.  Ultimately, I think it fitting that this build is dedicated to him.
Erik
I am very sorry to hear about your Dad.  But I am glad you will be back at it soon.  Hang in there!!
