As I suspected.  Do you glue them wet/damp, or let them dry in place first?
Ed
Druxey, the frames for my dromon will be a bit over double the thickness in both dimensions compared with yours. Do you think your 'wet bending' technique would work for them as well, or should I use heat as well?
Steven
Edited by Louie da fly
I totally missed the start of this beautiful build. On the upside I had a lot of catching up to do so Druxey you you made my day extra special :)
Your choice of subject is great and your execution out of this world. I will stick to workboats as this barge is out of my league ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
A week ...!!! That will be hard on my patience ... this build takes away the dread for the day ...have been looking forward to it's development ... such a stunning execution of technique ... marvelous result ...
Carl
I can only repeat what the others have said.   Have a good week and hopefully we can be patient here in the gallery.
Thanks so much, everyone.
A footnote: I fully expected the shell and frames to have spread until the internal members such as thwarts are fitted. This has proved not to be the case so far: the hull is 'on spec', with an overall beam of 6' 1½" (6' 0" moulded, plus 1½" for the planking). We'll see if this is stable when I come back to the model.
The hull is a fine piece of art as it is.  Just like a lovely leaf floating on the water.
Bob
Current build:  SS_ Mariefred
Hi druxey
This is a great little ship, thanx for showing! Could be a model to build for me too, I`m following. I love all that gold, and the way you build the hull gives me some advise.
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
I have had the pleasure of holding and examining this little jewel of a model today and it is even more impressive in person. It is surprisingly small, light and translucent. It's quite perfect! I believe Druxey is building it on spec so perhaps some lucky MSW member will end up with it.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Druxey talked me through a yawl in 1:64 a few years ago using a similar method.  Even with my unskilled efforts, it is astounding how egg shell-like the hull is.  Of course he finished his four boats he was doing far before I finished my one.  :-)
Hi druxey
Maybe I did overread this, what measure do the hulls planks have? This looks so incredible thin but strong too.
Great work.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Thanks for the comments, gentlemen. Now I'm back, it's time to begin fitting out. The first item will be the footwaling (the floorboards). These were laid athwartships  rather than longitudinally, according to the specifications for a different ceremonial barge of this period (ZAZ7154).
Gerhard: the planking is 1/64" thick, or a scale ¾".
welcome back, I was looking at the plan for the mayors ceremonial barge and saw it said floors athwartships, I was wondering how you were going to do that
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Hi Druxey
Thank you for this info! Is saved for "further use" :)
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Paul: I have found a useful photograph of the inside of Prince Frederick's barge (copyright, so cannot show it here) that confirms athwartship boards. These appear to be about 8" to 10" wide and painted red. There are also moveable vertical footboards for the rowers - a detail I've never seen or noticed before in small boat models. I was wondering if there were turned supporting pillars under the thwarts and indeed there are. All these will keep me busy for a while!
