Definitely NOT hitting the "like" button on that one Bob! Hope your repairs go smoothly.
Thanks guys for all of the encouragement and confidence. I needed it and appreciate it. I was more than a little depressed when it happened.
After three days of work, I can see the proverbial light at the end of the tunnel, and hope to be done with repairs tomorrow. BTW, there will be no photos of the damage, as I couldn't get myself to take them.
Bob
Bob:
I am sure the repairs will come out fine and all will be well. This is a really nice looking model.
Russ
I'm sorry to hear that Bob......glad your getting her sorted out
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good luck Bob.
We've all been there.
Cheers.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Thanks again to all for the good words. Repairs are now complete. The stern is somewhat fragile (glue is not as strong as solid wood), but will be OK after the planking there is done. I may just move that up in my sequence to avoid any further problems.
Bob
good, good, green lights ahead again Bob,
looking forward to your further progress...
Nils
Current builds
-Lightship Elbe 1
Completed
Now we can hit the "like" button again:) , and you deserve it, Bob
Just like your previous build, your endeavour to get the maximum result out of an already decent kit is an example for us all.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
yea!!!!  emoticones_dibujos_popeye-el-marino1_en.PlanetaEmoticon_com.gif.75254844648ffc2f9fb95e89e46eb8d3.gif
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Glad to be back into progress mode again. I've completed the first part of the interior work that I will do. This consists of the framing and planking of the aft lower deck.
The framing was done with boxwood strip and includes framing for what appears to be a scuttle, and also some supports for the beams. The beam supports, like much of the other interior work, will never be seen. The planking was done with holly strip, as will all of the other deck planking. The caulking is done with a carpenters pencil and the drill and fill treenails are done with golden oak filler. The holes in the forward part of the deck are for the pumps. The deck planking that looks ragged at the edges will all be covered by cabinetry.
My current intention is to do all of the aft lower  deck partitions and cabinetry, the fore lower deck framing and planking, full interior hull planking in the hold on the port side and partial on the starboard side, and full interior planking above the lower decks, including the stern. I'm not entirely sure in what order I'll proceed.
Bob
Terrific work, Bob.  I couldn't see any sign of damage or repair, and wouldn't have even guessed (or tried to find it) if you hadn't spilled the beans.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks so much Russ, Martin and the "likes".
Russ, I've been using holly for the deck planking for quite a while now and really like it. It works easily and provides a nice contrast with the boxwood without looking harsh.
Martin, unfortunately, almost none of the damaged and repaired areas show up in these photos (intentionally). For the most part, they won't get to be seen until they're covered up with further work.
Bob
I've done two areas in the past week: the interior planking of the hold and the forward platform.
The platform framing was done with boxwood strip, in the same manner as the aft lower deck. The fitting of the beams was tricky, but there are only three of them. The holly deck planking was done in the same way as the aft deck planking. Again, I wasn't as careful as I might have been with the forward most part of the deck, since it will be covered by a breasthook. The framed opening is for the foremast.
The hold planking was done with boxwood strip. I chose to plank the entire port side (up as far as the fore platform level so far), but to only do a few planks on the starboard side. I intend to leave an open space in that planking on that side and to not resume it until the level of the exterior hull planking.The planking extends just beyond the start of the decks, fore and aft. I finished with a coat of Wipe-on Poly.
I'm now working on the interior stern planking and the work in the stern cabin.
Bob
