Hi B.E.,
that pinnace looks lovely, and so is also "George" in his outfit and the rowing position...
did you find the figurine in 1:24, or any "surgery" involved and perhaps custom made period clothing, wunderbar !
Nils
Current builds
-Lightship Elbe 1
Completed
On 8/14/2017 at 11:57 AM, Landlubber Mike said:
Beautiful, the profile moulding is a really nice touch.
I agree, its really in these details that impress!     Also very much enjoyed your brief bit about the treenailing, Ive found that much of the treenails Ive seen look somewhat out of scale, but your's looks well suited. I also appreciate that they aren't overly dark as some tend to be as well.
1 hour ago, Blue Ensign said:
Thank you Sailor and Nils.
@ Nils -  George is a Dean's Marine 1.24 scale figure, but he underwent some serious surgery. originally he was a Vietnam War period American soldier in Jungle gear. His arms were broken in two places, his uniform and jungle hat cut away and he was given some clothes from the slop chest. I was pleased that at a given 1:24 scale he fitted the boat spot on. :D
B.E.
Smart solution B.E.
Nils
Current builds
-Lightship Elbe 1
Completed
A small diversion to play with the boat equipment.
The Grapnel
The grapnel as provided by the kit seems to have been rigged without the benefit of a ring, the line secured directly thro' the eye in the shank where the ring should be.
A grapnel as illustrated by Steel shows a ring fitted thro' the eye.
Steel gives a grapnel rope circ for ships boats as 3" - 3½" which equates to around 1mm diameter line at scale.
0946
This alone would not be possible without a ring, particularly as the classic hitch for small anchors is a Fisherman's Bend where the line passes twice thro' the ring.
 He also gives 35 fathoms as the length of the grapnel rope. which scales to 2667mm. This is 8.75ft at scale, where would all that fit in the boat!
0967(2)
I satisfied myself with a rope length of around 30' - 300mm which I figured would be long enough for what is essentially a harbour boat.
Boat Hook
This is shown on the plan but the makings are not included with the kit.
0950
Not too difficult an item to reproduce, I use a soft white metal strip (the arm from one of Mrs W's hair clips, cut and shaped with files, and inserted into a length of thin Walnut dowel.
0948
0964
0956
The Thole pins and chocks are also shown on these shots. Nothing much to say about the tholes except they are fiddly little things to make, parts very small, fingers too big.
I changed the style slightly from the plans, and left them unpainted as a contrast to the predominantly red  scheme.
0961
Just the Splashguards left to do now.
B.E.
Edited by Blue Ensign
Beautiful work, B.E.! And thank you for all the research you are doing . . . this will come in very handy when I have to do the longboat of the Syren :) Did you carve George the oarsman? He looks very good!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Wow, BE!  You just keep doing it, and better and better!  And I'm always impressed at your ability to find materials ready to hand.
(Does Mrs W know you nicked one of her hairpins?  Did William forgive you for pulling out the bristle on his brush?)
Cheers,
Martin
PS -- As for those figures, I looked at various places and couldn't find any that would fit 1/64 scale -- are they still available somewhere?
Edited by Martin W
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks Martin, both Mrs W and William are quite forgiving of my raiding of their respective possessions to serve in the shipyard.:D
Both Amati and Mantua do a range of period figures for 1:64 scale at around 25mm high. Artesania do a range of 27mm figures one of which I used to represent the ill fated Captain; Cmdr John Hamilton Gore on my Pegasus.
In the UK I use either Cornwall Model Boats, or the Model Dockyard, (both in Cornwall) but my 1:24 scale Pinnace figure I purchased from Dean's Marine.
Regards,
B.E.
Splashguards
I toyed with the idea of making replacements out of Boxwood, but on reflection  I think the kit provided items are just fine, particularly as they are painted.
I did some preparatory painting before gluing the two elements together, the panel faces, and inner moulding edges. The guards were then sanded down to around 0.9mm in thickness.
Before fitting, the seat back needed some very careful paring back using a scalpel and light sanding. I also needed to shape down the backrest top to fall just below the splashguard top edges.
This all needs to be done with soft hands and by fine degrees, any slips at this point could prove problematic in restoration.
The guards require the water /heat treatment to impart some curve to follow the line of the rail. This is another exercise that requires some care.
It was good to have a spare unit in the kit as I did break one.
I was a little concerned that the water would weaken the pva, but immersion was only for a few seconds before  pegging around a jar top to apply the heat.
On my Pinnace at least, two curves were required, a short one where the guard passed around the seat back, and a more gentle curve forward.
0968
Forming the aft curve.
0970
and the forward curve.
Getting the curve right is necessary for the guard to sit on the rail without tension, otherwise gluing it will be a difficult task.
0974
Once I was happy with the fit I painted the exterior face of the guard.
0975
To get a good grip it was necessary to scrape a paint free line along the top of the rail. This was carefully done with a scalpel point.
0981
The actual fitting of the guards was problem free with quick grab using full strength pva. The inside faces of the guards were painted once in place.
0982
0983
0984
So the Pinnace is effectively finished, some fettlin' to do, and a base to make which I don't think will take too long.
B.E.
B.E.,
Just catching up - as usual brilliant work in such a small scale.
That hook tip is superb as well.
Your colors also work so well together.
Cheers,
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Finished!  So soon that I've barely gotten used to the project.  Congratulations  :dancetl6: !!!
What's up next?
Martin
Thank you Bob, Grant, Michael, Martin, Steve, and Christian. :)
So this build is completed after a leisurely five month exercise.
The final item to make the base board and hull supports.
1034
For the base I have used a plain piece of Boxwood sheet of 3mm thickness with slightly chamfered edges.
1036
 You may recognise what I enlisted into service for the supports.
1037
For a change I made a greater effort for the final photo shoot.
and here are the results.
0444
0448
0465
0475
0496
0497
1029
1038
1040
1044
1045
1046
1048
1049
1050
1053
1054
1056.
Thoughts on the Pinnace kit.
My thanks go to Chuck for designing this fine kit and giving us modellers the opportunity to build a nicely scaled model of an iconic 18th c boat.
This is a fine little model but a sod to plank, although I did use rather thin Boxwood strip which allowed a very small margin for sanding corrections .
The supplied basswood is not really suitable for a model of this single planked type being too soft and feathery to get clean edges. I did replace much of the wood with my stock Boxwood and were I to do it again I would use Boxwood overall albeit of a somewhat thicker strip for the exterior planking, allowing me a little more leeway for my planking deficiencies.
I wasn't too happy with my work at the outset but as the build progressed and I got into the detail I eased up on myself somewhat, a model is more than the sum of its parts, and although I don't rate it as one of my best efforts, I do rather like the look of it outside of the prying eye of the macro lens.
This has been a nice little five month summer project, not entirely relaxing, but with a satisfying result, and it has wetted my appetite for Chuck's forthcoming Barge kit.
Regards,
B.E.
Congratulatios B.E.,
This is an awesome model, a real gem, and very well built...
Nils
Current builds
-Lightship Elbe 1
Completed
Congrats and nicely done. This is a difficult kit. I don't know how the results would be with basswood. I think the long runs and severe curves make it especially difficult. Cheers to moving forward!
Steve
Edited by Tigersteve
Great job B.E. :dancetl6:
You built a beautiful boat !
Derek C
Quote
A man without a goal is like a ship without a rudder --Thomas Carlyle
Current Build
18th Century Whaling Vessel "Lagoda"
Finished Builds
Triton Cross Section by Derek C 1/48
18th century longboat by Slideways - FINISHED - Model Shipways
18th century longboat by sideways from MS plans
Beautiful work as always BE, very nice job!  Thank you for sharing your build with us.  I know I speak for many that we learn a ton from your modeling techniques and are always inspired by your work.
I was going to ask what was next, but saw you already started the Longboat.  I really need to log on here more often :)
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
  • 4 months later...
I just discovered this build and enjoyed reading it.  I’m also very impressed with the excellent result.  A great looking model.
I do have one question - what does your wife’s soft metal hairpin look like?  Nne of my wife’s hair pins are made of soft metal.  Maybe it is a British/American thing.
Great work - now I have to look up your Cheerful log.
Cheers
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
