Bismarck by Semorebutts - FINISHED - Trumpeter - 1/200 scale - PLASTIC - with MK1 detail set
SEMOR
Is that the missing brass laying next to her left front paw? :)
Lou
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Share on other sites
sweet little fella Danny!  ;)    yours too.....you've shown pictures.   Gibbs isn't little anymore........about 22 - 25 LBS  our other Esky was around 39 LBS and every bit as loyal {we miss him}.   I do apologize for foddering your log......you mentioned carpet monsters,  and that's mine,  aside from a pair of tweezers.  one thing that binds us together is man's best friend...it's an awesome thing  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
did you need to drill them out as well?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Ugh. Just when I think I will get alot of progress done I get called into work! Again! 4 saturdays in a row!
Heres what I got done before he called me. I laid it out as square as possible. Then touched a drop of thin CA to each joint.
IMG_1746.thumb.JPG.80dda3a7b3900d5f71beeac22b4d64de.JPGIMG_1748.thumb.JPG.2ce6c63bb57d0fc3e707592f15bd7f37.JPGIMG_1749.thumb.JPG.03e6ef36e983301188029991f3e02318.JPG
the bottle of CA is leaking. Theres a gluey mess!
Link to comment
Link to comment
take a sowing needle.  Cut the eye in half so you end up with a u-shape.
use this to pick up some Iliquid) superglue (caterpillar capilliary action).
carefully line up both pieces and let the caterpillar do its work from above.  use little glue, then quickly spray with activator = instant bonding.
edit:  perhaps place first on surface that does not glue well (teflon sheet, https://www.ebay.co.uk/itm/1pcs-10mm-x-10m-PTFE-Teflon-Adhesive-Tape-Nonstick-Sealing-Machine-Tape/302526316786?epid=546897656&hash=item466ff940f2:g:rSMAAOSwO7haCVlp, perhaps)
Edited by Landrotten Highlander
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
Link to comment
7 minutes ago, semorebutts said:
So with out that tape it will just get glued to the table huh
I think the danger does exist.  Mind you, I never tried the tape in combination with superglue, but that sort of stuff is used in many industries....
Slainte gu mhath
L.H.
Link to comment
9 minutes ago, semorebutts said:
But wont it all just get glued to the table?
Not if you use LH's suggestion about the Teflon sheet - there's not much that will stick to Teflon :). Use the end of a toothpick to soak up any excess before the CA sets.
BTW - I use the half-eyed needle trick almost exclusively for applying CA. When the needle eventually gets clogged I drop it inot a jar of Acetone for a couple of minutes to clean it.
:cheers:  Danny
Cheers, Danny
Link to comment
I use a tile glossy. CA doesn't stick to the glaze.
"BTW - I use the half-eyed needle trick almost exclusively for applying CA. When the needle eventually gets clogged I drop it inot a jar of Acetone for a couple of minutes to clean it."
Dan a lighter cleans is off rather nicely too and a lot quicker
Carl
Link to comment
The little ones don't have to be all white.DSC_0035.thumb.JPG.39ee88b86c281b4b7c03cdacc2b54023.JPG
Cheers, Harley<p
Under Construction:       USS Curtis Wilbur DDG-54 1/200 by ILoveKit
Completed:                     F-35A 1/48 by Tamiya
                                        USS Atlanta CL-51 1/350 by Very Fire
                                    Liberty Ship John W. Brown 1/350 by Trumpeter
                                    HMS Spiraea K-08 1/350
                                    USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                  USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                  USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                  USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                  USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                          Brig Syren 1/64 Model Shipways, Wood
Started,On Hold:     Frigate Confederacy 1/64 Model Shipways, Wood
Link to comment
Link to comment
CDW  I Asked myself the same question so I checked. Rigging line and a flag attaches to it. Here is a picture.
I continue with the mast. First I finish up the piece I've been working on.
IMG_1765.thumb.JPG.6dc7585ac08878d3b88be003cd261bb5.JPGIMG_1766.thumb.JPG.561a19d6be26f3181f14252409a56753.JPG
now I lay out the 2 pieces together and adjust them till it's perfect. Then without dislodging it I just touch a drop of thin glue to the joints.
IMG_1791.thumb.JPG.dd151f85416b4b74488438cd01355b84.JPGIMG_1792.thumb.JPG.d63d6323871cc7d470f76e7c3b262aec.JPGIMG_1794.thumb.JPG.13c86b69c585bdecd4e480320c6fe1b6.JPG
Link to comment
22 hours ago, semorebutts said:
Any Ideas on how the hell I'm suposed to glue that donut shaped piece to the end of the other piece?? The only way I can think of is just to not do it!
Can you file a "V" into the tip of the yard? Otherwise use a tiny spot of PVA glue to temporarily stick it on, wait until it dries, and then hit it with CA.
If all else fails leave it off. Just tie the rigging line around the yard.
:cheers:  Danny
Cheers, Danny
Link to comment
It's a gluey mess Cog! trust me, Glue everywhere!
 Danny I actually slid the yard into the hole of the donuts shaped piece and glued it like that.  I figure it's better than nothing and will provide somthing for me to wrap rigging EZ line around. but there's no way I'm good enough to do it like the directions call for.
Link to comment
Fair enough :).
I thought you might be interested in THIS old movie about the Bismarck. Not bad for it's time :).
:cheers:  Danny
Cheers, Danny
Link to comment
For "behind the scenes" type thing for the movie Danny linked to, have a look here:
http://modelshipsinthecinema.com/wp/archives/823
http://modelshipsinthecinema.com/wp/archives/8422
This site is pretty interesting and you might want to explore it a bit.
Link to comment
now....that's ingenious!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
