RKR Varyag by RGL - FINISHED - Trumpeter - 1/350
Moving forward in the later 20th century, my next build, the Soviet (now Russian Navy) Varyag.
I found this on ebay along with a cruiser and a Chinese set of PE for the Varyag for a hell of a lot cheaper than anywhere in OZ.
You can see from the 1904 version, she got a bit bigger and I think was primarily an aircraft carrier killer.
There are a LOT of photos online for her him and his brothers (Russian ships are boys apparently), and I have as usual ordered up some more extras. The Gold Medal Models PE is just lovely and incredibly detailed.
The hull is very smooth and I will be doing a fair bit of work to etch in some panel lines, scuppers, dents, all to aid in weathering it.
Greg
Link to comment
Share on other sites
Looking forward to following something a bit different and seeing what you come up with.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Link to comment
Count me in.  I'm finding these steel navy models fascinating to watch even if my eyes won't let me build one.
 La Belle Poule 1765 - French Frigate from ANCRE plans                             Triton Cross-Section
        USS Constellaton (kit bashed to 1854 Sloop of War  _(Gallery) Build Log
        Wasa (Gallery)
        HMS Sphinx 1775 - Vanguard Models - 1:64
Link to comment
cool looking ship Greg........count me in as well!    really nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Greg, another interesting build. I vaguely remember studying this beast because of those missiles, while work for my Uncle Sam. I'm pulling up a chair, too.
Ken
Started: MS Bounty Longboat,
Link to comment
Darn, missed the start and front row seating :o Nice bit a PE ... interesting build too ... not much weathering as far as I can see from the "live" images
Edited by cog
Carl
Link to comment
We could pull that bench up that greg keeps outside, sit at the back but hope greg puts some screens up so we can see.;)
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
10 minutes ago, RGL said:
There will be weathering and some modulation of colour otherwise it will be very boring.
Dont foreget the bottles of vodka on the deck - that will cheer it up.;)
OC.
Current builds
Completed works.
Link to comment
OC.
Thanks I like the big screen addition, as my eyesight does deteriorate !
A little weathering ... and in the end it is a heap of rust and chipped paint, ready for the scrap yard
Carl
Link to comment
believe me Carl........if that's not the correct anti foil paint color........ paint it  ;)    I would!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Main hull joined up and rudder/ shafts and stabilisers added. As you can see there is a massive gap in the deck, it has to be amidships or the gap at the bow or stern would just be messy to fix. It won’t matter or be visible when the deck housings go on.i have also filed off the molded anchor chain (really, is this the 1960’s?).
I intend to give her multiple layers of primer (after a quick sponge bath with metho to clean her) to I can scribe in hull plates.
Greg
Link to comment
you could probably get away with adding 1/16 or 1/8 strip to one of the deck edges and sand down to fit.  the other problem is those two raised areas....if something is to fit on them,  they are not going to fit very well.  I'm sure that if any of those problems arise......your more than apt to handle them  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Well I haven’t posted for a while as I’ve been slowly working on the funnel section which will be one of the 3 main superstructures.
Like a wooden ship, I’m trying to plan ahead as much as possible but unlike a tall ship, I have to preplan what gets painted in situ or painted off ship then placed on after.
The Gold Medal Models PE is dated, expensive compared to what comes out of Asia and presumes a LOT of knowledge with PE. That being said it’s lovely and no one else makes it for this kit.
The plastic Trumpeter pieces are nice enough but just not  Tamiya standard for accuracy and fit.
After the last 5 days of nightshift I have researched all I could for what extra needs to be done and there is a lot of small  not in the kit or explained by GMM.
It’s going to be a bastard to paint.
Anyways, I drilled out all the vents and placed the covers provided by GMM, small railings and ladders that will go into vet the radar thingys. This has been a surprisingly large amount of work with still a lot to go. Railings everywhere and belaying points for cage antanne and big gaps to be filled.
Greg
Link to comment
The garage for the helicopter. I’ve added a few cables than run to the ECm and spotlights out of stretched spruce. There was a molded ladder on top which I’ll replace later. Lots more detail to add to the piece yet but after painting. Someone flew a drone over her in HK earlier this year and posted it on U tube so there is a HD reference which also confirms from the still photos that the Top Done fire controller is very very wrong, requiring some filing and a bit of scratch building and added some doors from spares.
It also includes some clear pieces which I have seen from other forums are universally hated.
Off to the front of the bus next.
Question; does anyone have any clue how to make 1/350 speakers/Pa’s?
Edited by RGL
Greg
Link to comment
The SS-N-12 launchers. The kit provides a little bit of PE that sirlts at this he front which is supposed to be a platform. I used these and added some platforms and railings from the Ise spares. There are also exhaust railings on the side and some offcuts of brass thingys to make up some hinges which are fairly non existent
Greg
Link to comment
The last main superstructure, this clear stuff is such a pain, you cannot see gaps, so after I glued it I used some Mr Surfacer on the edges to see where the gaps where. I sanded in the small box es and used some plastic strip on the big ones.
There is a LOT of small details to add to this. I found some speakers in 1/350 (coming from France) and have ordered some Accupuncture needles to uses as the multiple whip aerials. Apart from the GMM set there are a lot of cables and handholds to add all over.
Dry fit;
Greg
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
