HMS Winchelsea 1764 by Stuntflyer (Mike) - FINISHED - 1/4" scale
That really looks good Mike.  Cant wait to see it right side up and in person.   That certainly sets the standard for the group.   Its proof that slow and steady is the way to go.  Did you have many planks that were discarded into the scrap box?   I know I did and it is typical for such an outstanding planking job.
Chuck
Link to comment
Share on other sites
Chuck
Thank you! Yup, quite a few throwaways. Funny thing though, it always seems to go faster and better the second time around.
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
Excellent planking job Mike. Your workmanship is always an inspiration.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
On 12/31/2019 at 1:54 PM, Stuntflyer said:
Hello and a Happy New year to everyone!
I've been making some progress on the hull planking. The last two belts on the starboard side minus one strake are done. As tempting as it was to add the last strake I knew that I would still need a clamping area to adhere to when I start again on the port side. Clamping against the keel doesn't work since the angle of the clamp would pull the plank up and away from the bulkhead. Moving the clamp down five strakes changes the angle of the clamp just enough to hold the plank tight against the bulkhead.
I've added a few photos showing the planking detail both fore and aft.
All of the sanding so far has been done with Soft Sanders. They are hard foam shapes that you wrap with adhesive backed sandpaper which is supplied by the company. The sandpaper lasts forever it seems. I am using 180 and 320 grit. http://www.softsanders.com/products/wood. I find that these two shapes work well. I cut them into 3" to 5" lengths. They conform to the hull shape allowing for a smooth transition when sanding.
Mike
I bought a set of these. Best sanding solution I've seen. Thanks for the link, you're work is inspiring . These different build threads are really useful in avoiding traps and scraps...
Link to comment
It was seven months ago that I first started to plank the hull below the wales. I'm happy to say that it is now all done. The last few days were spent sanding out the hull planking. I find that I can see dips, rises and other types of fluctuations better when the lights are off and I just use the daylight coming through the window. Sounds crazy, but it really accentuates things better than my indoor lighting. I added the stern post as well. No finish has been applied though that will be done as soon as I re-paint any scuffed areas on the wales and cleanup the keel and knee with a light sanding.
Winchelsea_9438.thumb.jpg.1c83f86e2af454ebf8669cdb0fcbc920.jpgWinchelsea_9436.thumb.jpg.e3546ac2dbfea5086acebad4a1c00858.jpg
Mike
Link to comment
Beautiful work Mike...  Looks flawless...   😀
Great job....
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Link to comment
Simply stunning work! Congratulations on a beautiful planking job.
Bob
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Wonderful job planking Mike. Well done. Hope to see it in person again some day.
Rusty
Link to comment
Mike ....all that time was so well spent.   Your hull looks great.   Taking your time always pays off in the end.   Can you post a photo of the entire hull as well?
Chuck
Link to comment
Here you go. . .
Mike
Edited by Stuntflyer
Link to comment
Wonderful planking job ! Taking the time always pays ! A beauty !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
I managed to get a coat of Wipe-on-Poly on the hull.
winchelsea_9440.thumb.jpg.63254391a6da92edff4d768cd01ae12c.jpgI did not have the friezes, that are now available, when I originally planked the lower counter. After adding the transom template I placed the friezes to see how they would align with the upper and lower counters. The lower counter frieze didn't align well at all. There was just too much wood showing below the frieze. The fix was rather easy to do, however. I used the frieze to guide me in reshaping the upper plank on the lower counter. So, my suggestion is to use the provided friezes and check things out earlier rather than later.
Here is the result and as you can see there was quite a bit of wood that had to be removed, about 3/32". Once that was done I added the upper counter planking.
I added the outer window doubler to the inside of the transom template. This is a very, very tricky piece to make. I spent a lot of time finessing the angles for it to fit properly. You want the inside lip for the window to be very close to equal all around. Next, I added the 1/16" doublers to the inside of the upper counter. I then angled the upper counter planking, but not before first checking to make sure that the upper counter frieze was aligning properly with the angle. You can do this by drawing a line on the other side of the counter which mirrors the line on the inside.
Mike
Link to comment
Great advice Mike. She's looking splendid!
Rusty
Link to comment
Looking great Mike.   Yes the friezes for the lower and upper counter are a great way to check the curves.  They will also help you get a consistent width for the upper counter.  In Mike's photo below....the space between the two friezes is where the 1/8" wide molding will go.  So align the upper counter frieze with the bottom of the transom and that should leave 1/8" between the lower counter frieze.  Perfect!!!!
Link to comment
Hi Mike,
I could be seeing things, but it appears to me that you planked your whales in one layer? Model is looking absolutely fantastic!
JJ
Current Builds: HMS Winchelsea 1764 1:48 - 5th rate 32 gun frigate (on hold for now)
Link to comment
I think Mike used two layers  for the wales (see post #121 - page 5).
It seems to me in 2 stages: first the upper 3 strakes then finally the last strake once the first strake below the wale was in (the strake which included the drop plank) - post #133
But Mike can confirm my answer.
Edited by JpR62
Jean-Paul
Current builds :
Finished build :
Next on list :
Link to comment
The wales are done in two layers., exactly as described in chapter two.
Mike
Link to comment
Over the weekend I added the 1/64" x 3/16"  boxwood  strips to the top edge of the transom. This hides the seam created by the transom fillers and the transom template. The arrow shows the area where I filed away about 1/64" from the top edge of the transom before adding the strip. This helps to maintain the same profile after the strip was added.
A while back I did a google search looking for a way to remove laser char and found that GOJO is a product that is often used. On larger wood pieces where the char layer is thicker, I found that a very light scraping or sanding before using the cleaner with a pipe brush gives a good result. With some trepidation, I tried using it on a gallery window for the Winnie. Using a soft tooth brush, I just kept massaging the wood gently for a few minutes. The windows was then rinsed in cold water and placed between layers of paper towel on a flat surface and weighted until dry. The result isn't perfect, but overall certainly better than before. I would imagine that those building with softer wood products like Yellow Cedar wouln't need to go though the process of removing char at all.
Mike
Link to comment
