Thanks for the dimensions. I don't use a scale ruler but a conversion table to quickly get from feet/inch to mm
Work continued on the bowsprit step. To accurately determine the step (square hole) in the chock (the vertical plank between the bitts) I had to make the bowsprit itself too. I find it very satisfying to make a mast just with hand tools, it takes time but the result is very accurate.
While cutting the step the rabbet between the two planks very nicely
The bowsprit was cut from square to octagonal to round using a hand plane, well honed chisels and sandpaper.
The base going from round to square
And the tip
The step is also rebated into the upright bitts
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
beautiful Fitting work Remco,
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work, Remco.  Hopefully as relaxing to do as it is rewarding.
Fantastic work Remco, bravo!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Magnificent piece of work Remco.  Real clean and neat.  What kind of wood did you use?
David B
Thanks all for your kind words. And yes Mark it's relaxing.
David B, 99% is Castello Boxwood and deck planking is Holly
Just a minor update, the mast step finished with lots of bolts and 4 shaves.
Remco
A minor update (?) for a major piece of work (!) Looks marvelous
Edited by cog
Carl
  • 2 months later...
Jaw droppingly good Remco, beautiful workmanship.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Finally a long overdue update. My KF got little attention lately as work and other (fun) projects got in the way.
I cut all the mortices for the carlings in the upper deck beams and started to make the first of the knee's and hanging knees. These are not one of my favourite parts to make and unfortunately every beam has a hanging knee. This is due to the heavy load on the deck with all the canons. I'll stick to my mantra and go step by step or part by part in this case :)
Remco
Johann is right... beautifuly done, Remco.
marvelous job, Remco. Surely Piet distracted you ;)
Carl
Fantastic work, Remco
Regards Christian
Nice to see you back at it Remco. Lovely work, as always!
Edited by gjdale
Hi Remco,
fine work, looks amazing!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hello Remco
     While I might be new to the MSW forum and don't follow too many build logs yet this is one I do look at.  I'm always excited when there's a new post from you.    It is masterful craftsmanship and such a delight to see!
Tom
Edited by wyzwyk
Thank you all for your kind words and likes.
Work is progressing and more knees, hanging knees, carlings and ledges are added.
I also forgot to install a pillar in front of the fore mast , but that was taken care of.
The last opportunity to take a look at the sail room before its permanently installed in the hull
Some of the knees with mortices cut
The state of the upper deck to date
The next weeks will be more of the same... with the addition of installing hammock battens as I work my way across the deck
Remco
