Hi all, I'm starting my build log for the new and improved Winchelsea. I'm looking forward to building her here with everyone.
I have yet to decide what woods I will build her in but most likely it will be pear or boxwood. I won't be able to start any
real work on her until late September as work intrudes on my shop time this time of year. What little free time I will have
I'll be printing and reviewing the plans and monograph and ordering up what supplies I may need.
I'll also have the pleasure of living vicariously through all the builds that start before me.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Alright now the overtime is done, a short R&R vacation is over so now it's time to get back into the shop!
Here's a comparison of the 1:64 vs the new 1:48 version of the Winnie. She's a big one alright!
First up I made the build board. 3/4" 7 ply 14" x 36" plywood was used. I added two 1" x 2" "stiffeners" to the back side to ensure the build board didn't warp.
I then made up four sets of brackets from some cherry stock I had available. I made four sets because that's how much wood I had and more is always better right?
Now that the build board is complete I can start cutting out bulkheads, stem and keel.
Rusty
You are off and running!!!  I am so glad to see you dive in the deep end Rusty.  I am looking forward to seeing your progress.
Chuck
I can't wait to start ripping wood. You know it's been killing me these last two months having to wait
to get started and only being able to follow along watching everyone else make so much progress!
Rusty
You’re still getting in on the ground floor, Rusty.  As far as I can tell, no one is done with chapter one yet and several of us have had to back up a step or two.  I think you’re starting at a perfect time.  I really like that there are so many of us to share this build with.  Welcome aboard, mate!
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
Hi Ben. I know we talked about another project earlier but when the Winnie came around I had to build her!
Thanks for the welcome Matt. I look forward to building alongside everyone.
Thanks for all the like too!
For printing the bulkheads I purchased a ream of 28lb paper instead the normal 20lb paper. I felt that the extra
thickness would help keep the paper from stretching/distorting when the glue was applied and then pressing
them onto the plywood. Probably overkill but it made me feel better.  I use rubber paper cement from Elmer's
to glue the bulkheads to the lite ply.
To help keep tear out on the back side to a minimum I use a very fine scroll saw blade from Saw Bird. Someone
from here turned me onto them years ago but I don't remember who so I can't give credit where it's due.
I used a double tooth 24 TPI blade that is 5" long and .031"wide x .013" thick. Much finer than a regular blade.
Here is the backside of one bulkhead. It is just as it came off the scroll saw.
One down and a whole bunch more to go!
Rusty
I've completed cutting out all of the bulkheads. Nothing to difficult. Just slow going and as you know there's a lot of them.
Next I'll cut out the three sections for the former. Something I do while I'm cutting out the former and while I'm not working
on the bulkheads I always keep a weight on them. Though the humidity is a fairly constant 50% I still don't want to take any chances.
Rusty
Good idea Rusty on weighting them down. My environment is a bit more humid and I have even got in the habit of covering the work in progress with plastic sheeting. Those scroll saw blades do a great job by the way!
Question: I believe you said you were using Birch ply is that correct. Is it Baltic Birch?
Joe
Thanks Joe,
I'm really happy with the blades too. I used the lite ply from national balsa.
Rusty
Progress continues,
The former has been cut out and the rabbet strip attached.
Next is to cut out and assemble the stem knee assembly and keel.
Here are the parts laid out on swiss pear.
Here is the  stem knee cut out and ready for fitting all of the pieces together.
The fun is just beginning!!!!!
Rusty
Hi Chris. So far pear it is. I thought about Cherry but I had more pear on hand. Thanks for all the likes too!
Rusty
Hey Rusty,
looks like Ike we have the same thing in mind, if I build her I will use Pear for the Stem, Knee, Keel, sternpost and rudder, ebony for the false keel, and Cedar for most of the rest - a la my Pegasus build, I love that color combination.
look forward to seeing your progress to give me inspiration
Ben
Hi Ben,
That sounds like a really nice way to do it. Right now I'm thinking stem and planking all in pear.
Rusty
Thanks shihawk. I know there are two camps on this. One is the same color above and below the wales and the other is using two different woods. I'm in favor of whatever you think looks good.
Rusty
Hi All,
I've assembled the stem, keel and bulkheads. Now you're probably wondering where the pictures of the assembled stem is.
Well that makes two of us. Somewhere in cyber space I would assume. Seeing that the stem and keel are now covered with
blue painters tape I can't take another picture. Sorry we'll just have to wait until the hull has been faired.
Limbering up the shoulders and hands for the numerous hours of sanding. :)
Rusty
After several days of sanding, numerous sheets of sand paper and sanding sticks later the hull is roughly faired.
I estimate I have 12-15 hours of sanding and more than a few Aleve tablets into the hull so far.
After the port framing is completed more fairing will be needed.
Here I've started to place the port framing. I would cut and fit several at a time and then leave them next to the former
until I glued them in place. This way I could make several at a time and then glue several in place.
This method helps me not mix them up and keep them in the correct order.
I'll work to the bow and then to the stern. No real reason why just the way I'm doing it.
Rusty
Superb work. This frigate really has beautiful lines. Thank You for sharing.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Have you thought about what kind of stand you are going to set her on? If pedestals now would be the time to put extra wood in to screw into. What frames would you set them in if you were to use pedestals?
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Thank you Jean-Paul. Yes she is a beauty.
Thanks Jeff, Tigersteve and Chris and all the likes too.
Jim I really haven't given any thought about using a stand or pedestals or whatever way I'm going to mount her.
Thank you for bring that up as it would be smart to reinforce for pedestals before planking the hull.
I think I would locate them somewhere between bulkheads G, I, K and 9, 11, 13. No real reason other than
it looks like a nice distance from the bow and stern.
Thanks Bob. Yes I do remember how much "fun" sanding the interior of the Confederacy was so this
will be even more fun. My shoulders hurt already. :D
Rusty
11 hours ago, Chuck said:
Its great exercise!!!!😏
My right arm will look like Popeye's when I get done! ;)
Rusty
