HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Thanks for the comments once again George, Robin, Mark, Greg, David, Russell, Maury, H, Jihn, Mark and Carl :) .
Robin, I don't have any more pics other than what I have in this build log - sorry.
Topsail Yard Tyes
Before going into the construction of the Topsail Yard Tyes a warning to others building from TFFM - there is an error in their rigging, pointed out to me by none other than the author David Antscherl. Unfortunately this error was pointed out just as I had completed them :( . No biggie, I just pulled the whole lot apart and re-did them. At least this gave me an extra couple of days working on the model :D .
TFFM has you rigging the topsail tyes in similar fashion to the lower yards, whereas they use a DOUBLE block on the yard. The standing end of the Tye, one each side, circles the topmast and lashes back to itself via an eye. It then goes through one of the sheaves in the double block on the yard, up to the tye block under the top, and down to a double block for the tackle. The other side does the same.
The tye block has two buntline blocks lashed to it's top :
An overall view of the tye rigging :
The blocks under the top :
The double blocks on the ends of the tye falls :
The lower end of the tackle has a single block on a pendant which hooks into a ringbolt in the channels on either side. The fall of the tackle belays to a convenient timberhead. This is the main topsail tackle :
And the fore one :
:cheers:  Danny
Cheers, Danny
Sort of a bummer TFFM let you down, but a good thing David let you know about the error. Looks great!
Cheers
GEORGE
Nice catch Danny, and beautifully executed. Glad to hear you enjoyed your "bonus" couple of days on the model. ;)
Thank you very much for the note about the error in TFFM
(even the masters are due their one misteak)
Printed out your correction description and inserted it between the pages of my volume copy for future reference!
Alan O'Neill
Some very impressive rigging there Danny - a pleasure to view.  Hopefully one day I might get back up to the Port Mac show and catch sight of this beauty in all its glory.
cheers
Pat
G'day Danny
Another display of excellence, what more can I say!
Robin, Danny's log as I can see has the most step by step photos anywhere. I know what you mean I think, you would like more because you don't want it to stop! Who does, NO ONE!
Cheers
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Hi Dan,
I can nothing add to have been said, only echo other comments: impressive rigging!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Thanks again for the kind comments George, Grant, Allan, Pat, Greg, Kees and Alex :) .
Parrels
The Parrels act as bearings to enable the yard to be raised and lowered more easily.
Construction of these starts by PVA gluing together the Ribs in two stacks. This way they can be very accurately drilled and shaped symmetrically. The ones on the right have been finished :
Once shaped Isopropyl Alcohol is used to separate the individual pieces :
The Trucks are turned on the lathe. They are more barrel shaped than round :
Next an eye is "spliced" into one end of two lines, and the ribs and trucks are fed onto them :
The two eyes are lashed together around the port side of the yard. The trickiest part of the operation is lashing the lines around the mast. They go over the parrels 3 times and tie around each other. Lots of care needed not to damage anything, like breaking off yards etc   :huh:  :
:cheers:  Danny
Cheers, Danny
Just want to say, Dan, that I've used this method of yours for cleats (after your posting on cleats) and it's such an elegant solution for consistent width and height of small pieces. Thanks a lot!
Tony
Glad to be of help Tony :) .
Topsail Yard Lifts
As with the lower yard lifts these are used to square the yard. They attach a little differently to the lower ones.
A Span fitted with a thimble at each end is clove-hitched around the topmast cap :
The thimbles at the ends of the span are lashed to thimbles in the standing ends of the lifts :
Then the lifts go through the lift blocks on the ends of the yard, up through the lower sheaves of the sister blocks lashed to the shrouds, and belay to the aftmost cleats on the lower part of the shrouds :
:cheers:  Danny
Cheers, Danny
I can see by the quality of your work Danny, that you really do love this part of the build. Very nice.
Cheers
GEORGE
Thanks George and Greg :) .
Topgallant Yard Parrels
The topgallant yard parrels are smaller versions of the topsail yard ones. MUCH smaller. Here are some of the pieces with a topgallant yard truck and rib for comparison :
The parrel attached to the fore yard ready for crossing the yard :
The topgallant yard lift is seized around the end of the yard rather than to the upper block. There is no lower block. The halyard belays to the aftmost cleat on the topsail shrouds :
:cheers:  Danny
Cheers, Danny
Looks great Danny, but I wouldn't have expected any thing else.  Like we used to say in the building trades, " If you do a really good job once, they'll expect it all the time".  :D  :D
GEORGE
G'day Danny
When you said smaller, you mean smaller. The scale wasn't apparent until you place the 5c piece. Don't sneeze when you are handling them or they will be blown away.
Cheers and Havagooday
Greg
Thanks George, Dave, Greg (that happened :D and Christian. Robin, I think Druxey explained how they fitted in the post you put up - I don't know any more about them.
The Cat came back  :huh:  :huh:  :huh:  !!!
Below are some pics of the damage caused by Pud on his most recent (and hopefully LAST) excursion through my ship. All damage has been repaired, and wasn't quite as bad as it first appeared. The Crowsfoot Euphroe block lashing was the most difficult piece to repair. The whole repair job took me a full morning, but Pud is still alive and well :D
:cheers:  Danny
Cheers, Danny
Dan,
Sorry to hear about the damage ... glad it was quickly repaired... maybe be prepared and have a ball of wool ready ...
Edited by cog
Carl
Thank heavens I only have a small dog who can't jump up on the bench.   Although anything that hits the floor is hers.... :huh:
That's a very good repair.  Looks like it's never been damaged.
Nice job on the repairs Danny!  Pud's rigging ability currently leaves something to be desired, but he's learning. Remember, practice makes perfect.   :D  :D
GEORGE
Thanks guys, but the pics above only show the damage, not the repairs (there was damage on TWO masts). Here are the repairs :
:cheers:  Danny
Cheers, Danny
That's a good recovery job Danny - Pud must have a short life expectancy as that a few lives expended on this build alone ;) (kidding of course - I hope you have many happy years with Pud and the Vulture!)
cheers
Pat
I might have been a little premature in my "nice job on the repairs" statement Danny, but I already knew you'd have her back ship-shape in no time. But we have to remember Pud's in training and mistakes are inevitable. He's going to be a great helper, specializing in rigging.  :D  :D
GEORGE
Nice repair but as for Bud he thought it was a natural enemy Vultures and cats do not get along :)
David B
Oh... I thought the last picture showed the repair..... :blush:
