YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
  • 2 months later...
Amazing...
Current build:
Finished build:
Current build(On hold):
Link to comment
Share on other sites
Hi HYW,
it is masterful modeling all the way to date....
I also love the way you make your boats, the windless and the bilge pump, and the metal fitting out, let alone the wonderful corpus of the clippers hull....
Wunderbar !!
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hyw,
Your workshop was incredible before, be interesting to see how it is improved with redecoration.
Finished builds are
1/35 Endeavour's Longboat by Artesania Latina
1/36 scratch built Philadelphia Gunboat from the Smithsonian Plans
Current build is
Scratch build Boudroit's Monograph for La Jacinthe at 1/36
Link to comment
I can’t believe I just found this log... your work is incredible, maybe the best I have ever seen, and your work station is one the most professional work places I have seen for model ships. your work is truly an inspiration for someone like me who hopes to scratch build a clipper one day.
I don’t have words for some of the things you have created like the windlass and pump. I want to say your work is unreal but that’s the exact opposite!
It’s also crazy to think things like your two incredible boats will be secondary details compared to the final product!
Bravo!
Bradley
Current Builds:
Flying Fish - Model Shipways - 1:96
Future Builds:
Young America 1853 - Scratch Build - 1:72
Completed Builds:
HMS Racehorse - Mantua - 1:47 (No pictures unfortunately)
Providence Whale Boat - Artesania Latina - 1:25 (Also no pictures)
Lowell Grand Banks Dory - Model Shipways - 1:24
Shelved Builds:
Pride of Baltimore 2 - Model Shipways - 1:64 (Also no pictures)
Link to comment
On the occasion of the coming New Year, I wish you all A happy new year! Thank you for your attention and encouragement. I will continue to work on the project as planned and try to finish it in the new year.
Link to comment
You are giving Ed T a run for his money on your build!!!  Beautiful work.
allan
Link to comment
Truly exceptional workmanship and an astonishing model.
I think what we are witnessing here is the true difference between The Master and The Apprentice in that the Master has failed more times than the apprentice has tried.
I mean that in a positive way bitao7967, since you mentioned in an earlier post that only the piece that passes your high standard gets pictured.
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Link to comment
Hello, Håkan. Like you said, I'm a serious man. Trying to do everything right. If it's not good enough, it's because of my limited abilities.
Link to comment
2 hours ago, GuntherMT said:
Very nice update, thanks.
Why the name change?
Thank you for your attention. In fact, I was introduced to this great forum by a friend. I like the work and the atmosphere. Also hope to be able to show their work, for everyone to exchange. Due to the registration restrictions, I entrusted a friend in the United States to register an account, the name is written casually, at that time because the permissions can not be changed, now the changed name is my network has been using the real name (no number) .
Link to comment
Gorgeous work as always.
Lovely work on the brass water tanks, what did you use to make the rivet lines in the water tanks?  The pictures aren't real clear on that final detail that it appears you added.
Thanks,
Link to comment
Hello, just found your log.
Thank you for posting, seems to set the standard for how this is done!
All the best in the new year.
-Rich
Link to comment
Stunning work as we have come to expect from you; I very much look forward to further updates.
cheers
Pat
Link to comment
Thanks,
Thanks for the heads-up. Because in my computer can be enlarged to see, but the forum has the picture limitation, retake under add. All 2,000 or so rivet holes with 0.3 mm drill bits took two days to complete.
Link to comment
-Rich
Thank you for asking. I just want to do the best I can with every part. But I believe that many people here if they have enough patience and perseverance, will be able to!
Link to comment
cheers
Pat
Thank you for keeping an eye on me. I'm  keep going until I'm done. Estimated about half a month or so I will update in time. I don't have the third volume, so I'll probably have to cancel the rope part, but I'll try to finish the hull part within the year.
Edited by bitao7697
Link to comment
Very nice.  Do you plan to fill the holes with rivets or simulated rivets or just leave it like this since this is all belowdecks?
Link to comment
Hi Gunther MT.  Because without the rivet holes, it's hard to see the assembled modules. Its function is only to reflect the split structure, water tanks hidden below the deck, do not need too much energy to pursue the above rivets, after all, its cap diameter is only 0.3, the maximum size of the raised plate must not be greater than 0.05-0.08, must be round head. It's a hard job, and I think it's a pyrrhic victory. So I cut a hole in it to show it. Of course, if it's above deck, I'll try to be as specific as possible.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
