Sweet work G. You're doing a great job keeping all those sweep and port sills in alignment. I thought of using brass pins to transfix the frames to the keel but with the keelson and temporary blocking they were amazingly rigid during fairing. As well if you plan on installing the fillers between the lower frames this creates additional rigidity.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Wonderful work, doesn't appear to need much fairing at all! I see you decided to do the hawse holes at a later point. After ruining a few hawse pieces I opted to cut them in later as well.
I note on my 15 year old Swan class model I've had no gaps appear between the filling pieces between the floors of the frames. Perhaps that's because it's in a case in a temperature controlled environment. I did have gaps appear in my current Speedwell model but I think that's because she's been moved frequently to areas of different temperature and humidity.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Beautiful work and that's going to be large and impressive model when done.
