Very good recovery, Bug.   Isn't part of the fun of a bash is figuring out how to fix the 'oops' followed by bad language moments?
Thanks fellas - much appreciated.  And Mark- you're definitely right, it is part of the fun.  However - there is also that moment where I think to myself... "Well, I COULD just cover it up with a grate..."   heh.
  Proceeding with the aft deck planking now that the 'fix is in'.  Nothing earth-shattering here - your typical staggered planking with a margin plank.
A03D4115.thumb.jpg.4be53a34e3d48158a10b215124bfec5b.jpg A03D4116.thumb.jpg.387066cc7f593379a0f3c04ac72ca33f.jpg
  Then I am bending and mounting a couple of strips to heighten the bulwarks.
Peg_xx5.thumb.jpg.39008d16ee08d37822dcafd27560c78b.jpg A03D4119.thumb.jpg.d48f731fef932494236b580b4682b911.jpg
   Here are the results of my bulwark boosting.  Added inner and outer planking, then sanded it down to provide the proper height both fore and aft.  Then I sanded everything flush, and then repainted. For the bow I used one continuous plank bent all the way around rather than butting it at the bowsprit hole. Once again, this is primarily the result of using deck planking that is much thicker than supplied by the kit.
 Peg_339.thumb.jpg.19063790b9e06ee9ec49546ef08a291c.jpg Peg_340.thumb.jpg.c338a54605d05e467f382b508f1991a2.jpg
Peg_341.thumb.jpg.0939b9e0232209332bab1707b5c62447.jpg Peg_342.thumb.jpg.dd42e86c9cebf58030df4bc088031370.jpg
  Also - an update to the aft hatchway / stair situation.  Turned out to be a successful fix.  You'll notice my scuttle lids are flush planking as opposed to grates.  I got this idea from @Blue Ensign's build and prefer it.  Partly because it's probably more likely how the scuttle lids were - but also because as I noticed with the smaller stove vent grates on the foc'sle - I can't get the grating thin enough to look the way I want.  It just looks a little thick and chunky when the grates are smaller.  This is all still pretty rough also, and will look much smoother once I finish sanding and give it a coat of tung oil.
Peg_337.thumb.jpg.c47df80d256db84230fa233e21387f46.jpg Peg_338.thumb.jpg.323f0bdacb0241a1f1cd8a70a890a4e2.jpg
Edited by Moonbug
6 hours ago, Blue Ensign said:
Those  gratings over the scuttles made no sense to me
   Thanks B.E. - these are the kinds of small items where one appreciates the research from those who've done the build before; that way I'm not duplicating effort. Definitely appreciate all your notes along the way, which at the least gives me the opportunity to decide if I want to take the same route.
      Though I've clearly been negligent with posting, I've been working on a few things simultaneously over the holiday break.  I'll have more updates soon on the rudder and transom.  But I've also been catching up on some of the miscellany of bitts and rails and other items. As always, everything ties together - so using a thicker deck and increasing the bulwarks affected the roll of top rail that sweeps into the waist.  Instead of trying to match it to the plans, or even match it identically to the FFM or other sources, I instead took what the build gave me and worked with that.
    I used a solid piece of cedar scrap to draw out what the rail would look like, then carved/sanded the pieces to fit. Admittedly, I'm not much of a wood carver, so my little bit of saving grace is that it'll all be painted black so my inevitable flaws will hopefully be covered.
Peg_343.thumb.jpg.cda75b7d65b1fd23c8d8862846eec28d.jpg Peg_344.thumb.jpg.4494723c45ba051f745ddf1edf2ce439.jpg
Peg_345.thumb.jpg.0bc1f0a31e08bfdb572fed8bb39d899a.jpg Peg_346.thumb.jpg.75c82f8143801137b239d6b398f99317.jpg
  For the strips along the side I sanded down some make-shift scrapers. The strips themselves are boxwood, split and sanded to match.  I sanded them thinner then painted them before they were mounted.
Peg_348.thumb.jpg.284d4e173491c8fca851a5a0ee599c96.jpg Peg_349.thumb.jpg.6adc123836b39fbcc5a2b2836eb7cd90.jpg
Peg_350.thumb.jpg.b94caea740c64c8fe1864466773ec156.jpg Peg_351.thumb.jpg.002f6a3b642e1b38c742aa320ed80640.jpg
  After all the bitts are added along the top rail, I filled in all the little gaps before painting.
Peg_352.thumb.jpg.8d86c7a6b5bd92f54774fd7164db9220.jpg Peg_353.thumb.jpg.1a5b9fefd575fa0a98e9ca47c2fa255b.jpg
  During this process I've been keeping the decorative etchings in the back of my head, as I know I'll have to work with those.  I realize I painted myself (no pun intended) into a corner by using a full size main wale as per the FFM, etc - which gives me much less space for decorations and other elements.  So - I'll likely finish up as much of the sides including the swivel mounts, side ladders and other ornaments (and maybe even the channels) before attempting to decorate the sides.
Edited by Moonbug
   I also did some work on the rudder over the holidays.  One of my faults as a builder is that I'm a bit erratic. I keep pretty good notes because of course skipping around means one has a tendency to miss things along the way.  The rudder's up next so I can finish off the wheel, rudder housing and the rest of the deck fittings.
    Anyway - on to the rudder. I tapered the insides and then plated the copper.  It was a bit trickier than I anticipated, but I stuck with my desire to stagger the plates nonetheless. Then mounted the pintles with a center pin that would bend 90 degrees and serve as the mount to the gudgeons using tape to maintain an even offset and align the pintles and gudgeons along the rudder and hull.
A03D4130.thumb.jpg.5fc943aa7703cfa4638972fc8b5118d6.jpg A03D4137.thumb.jpg.970f919c3078b808aed80d04fb8ef914.jpg
A03D4139.thumb.jpg.097413f4632e543b97bc65982bcd498e.jpg A03D4142.thumb.jpg.3219ab4d6f72e9c49871a4fb4b7883b9.jpg
      I created the spectacle plate out of a square piece of brass bent at a couple 90 degree angles then sanded thin to fit a complimentary slot cut out of the rudder. I then soldered a couple of brass rings to the corners. Everything is "bolted" with pins from Micro-mark - they're the .020 inch miniature nails. I like them for these applications because they have a round head that looks great for bolts.
A03D4144.thumb.jpg.34f9db495309d771518b21932dd6c43d.jpg A03D4147.thumb.jpg.69be25a01829e93b08b92da48262cc09.jpg
A03D4145.thumb.jpg.840ae8ec4832b7d0cb2a237924a78729.jpg A03D4150.thumb.jpg.64a0cc3a52088c8f5dd9d866dcc9d1b0.jpg
  The rudder coat is made from an old piece of simulated 'leather' that I had left over from my Artesania Latina stagecoach kit. I think it looks pretty close to the tarred canvas that was used. I glued one side at a time then stuffed it up into the rudder hole. Finally, I painted the pintles and gudgeons copper from "Army Painter" copper paint.  These paints are typically used for medieval action figures, etc - so do a great job of simulating metal. I appreciate that the hinge coating is just a slightly different color of copper as the plating.
A03D4162.thumb.jpg.fc1a3fb46a54583e2d70646954f70f8e.jpg A03D4163.thumb.jpg.203bc2932379a0903067be13ad163e2c.jpg
A03D4170.thumb.jpg.86ad66e099ac5e9defba5378a6f3008e.jpg A03D4198.thumb.jpg.1d41528c22c51935af29c36a817ddc70.jpg
Edited by Moonbug
Bug -- Pegasus is looking super. I went through your log again looking for something but didn't find it. What kind of wood are the decks planked with and how did you treat it? Stain? WOP? Tung oil?
Pete
Pete
Current Build: Charles W. Morgan - Model Expo
Completed Builds: Santa Maria, Cutty Sark, HMS Bounty - Marine Model Co.
On The Shelf: Flying Fish, HMS Endeavor, USF Confederacy
   Hey Pete - thanks for the nice comment and asking about the wood. I have to go back and make sure it's in there somewhere.  But the decks are planked with Swiss Pear.  Long story short - my project just prior to this one was finishing the USF Confederacy - a build started by a wonderful previous member @augie who passed away. Augie used Swiss Pear on the Confed, and I really just loved the way it looked, so I used the leftover for the Peg. I have treated it with a light layer of Tung oil - rub on with an applicator then immediately wiped clean from excess. I'm selective with Tung oil and WOP, but I like what the Tung does with the Swiss Pear as well as the Walnut that often comes with the kits.
Btw - I grew in Lebanon, Oregon - not too terribly far from your and @mtaylor's neck of the woods.
Thanks for the info, bug. Yes, Lebanon is just a quick jaunt down I-5 from me. I appreciate information and will remember the combo of tung oil over Swiss Pear. Love the look of your deck. I have certainly read through Augie's and your log of the Confed. It's a beautiful model. Too bad about Augie. He (and you) are very talented. I wonder how old he was and what happened.
Pete
Short version of what happened...... Augie was retired and had a cancer.   He was good guy and friend to many of us.
Too bad. He was a talented man. I expect he's in a better place now.
Pete
Pete
    It's definitely worth mentioning that that last couple/few posts represent work that was done simultaneously mostly over the holiday break from work and the last week or so.  It's not like I knocked all the stuff out one after another. I'd been thinking about how to handle the transom for quite some time - since like everyone else who's done this built I realized there's a pretty notable design flaw in that the sides of the transom just just out into nothingness with sharp edges.  Very strange. The other noticeable different from the NMM plans was the way the stern curved whereas almost every reference (and build) showed it as being straight. So these two things needed to be sorted.  First, I straightened up Peg's rear end.
1055739310_PegPlansNMMStern.jpg.7321734bb768b7c3e5dd93c185e8d0d1.jpg  387684059_PegPlansNMMTransom.jpg.8886bbeafc80dd5a7f3f3dd4b4d8b02a.jpg
Peg_366.thumb.jpg.d1338c8b07614c774c525f87aa5278bd.jpg Peg_367.thumb.jpg.1285be1de9173c88a82038811010830d.jpg
   Next up, I addressed the weird jutting edges. I've seen a few different methods in builds - mostly adding a piece to fill in the gap. I decided my best bet would be to reshape the sides to more reflect the plans above. After sanding down and reshaping, I filled in the gaps and angles to smooth it all out.  Then I added the moulding to separate the lower stern areas to get an idea of how this would all play out.
Peg_368.thumb.jpg.f2129a31d16a591e7c32f94fee8c244b.jpg Peg_369.thumb.jpg.73248ea28d7e72a20d2537f296a222af.jpg
Peg_370.thumb.jpg.d70160c8ac25827e8cec9af55522fd4b.jpg Peg_371.thumb.jpg.b271949f002c53f4f6438f14047cb069.jpg
 Though the reshaping of the transom looks much better, it does create a subsequent problem that needs to be addressed - the fitting of all the carvings and decorations. Obviously, the kit provided photo-etched decorations are made to specifically fit the kit shaped transom. So - how to fit the decorations into a smaller, differently shaped area?
   First, I painted them with a few different layers and shades of yellow and yellow ochre to try and create a more three dimensional look - the same technique as I used for the quarter galleries.  Then, I installed the windows - because I know that the window locations are fixed and will serve as my benchmark for placing the rest of the decorations.  Once again as with the quarter galleries, I am using the thin microscope cover glass as 'real window panes' in my windows.
Peg_374.thumb.jpg.4944bd6f93bcd711857c9c85024cdfb4.jpg Peg_375.thumb.jpg.51ea0e4cc80949a0359ca6761bb62e20.jpg
Peg_373.thumb.jpg.861a86d65e841f9a4e642ab872b8d99c.jpg Peg_372.thumb.jpg.76b22b5ed3e3a66031f67e506a1180f3.jpg
  Although the decorations themselves come in layers to facilitate somewhat of a 3D 'carved' look, I used the same technique as with the quarter galleries to to add to that after they were mounted - adding some thicker acrylic paint to bring out the texture. But first I had to get them to fit, so I cut apart each decoration so that it is a separate piece which allowed me to place them individually. I started withe the Pegasus centerpiece, then added the two soldiers on the outsides (the poor soldiers had to be 'trimmed' to fit the different shaped transom) and then individually placed elements to fill in the gaps in between. I even pulled a couple decorations that were intended for other areas of the ship.
Then, to further enhance the 'carved' effect, I filled in a small syringe with relatively thick yellow ochre acrylic paint and attached the tiny nozzle used for silver soldering. I added the painted to raised areas of the carvings to raise them even further. This took a lot of time and patience and some scraping off of extra painted when my fat-fingers splooged out too much paint on occasion.
Peg_377.thumb.jpg.26e364de67f9b5136b14c3d1bad14bd4.jpg Peg_378.thumb.jpg.0e9a4f56cb51ede2038aa7c94b4f95cb.jpg
Peg_379.thumb.jpg.219e679e2bc7c19486f3def887a421c1.jpg Peg_380.thumb.jpg.b56187e478a57b183082b196700ed7ba.jpg
  Finally, lining up the letters was an incredible pain in the a**.  First, the laser cut letters are TINY, and very difficult to remove without damaging or bending them. Then - they were very challenging to paint, and finally- SUPER challenging to line up straight and with proper spacing. It took me almost as long to get the letters on the ship as it did to do the rest of the decorations.  Unfortunately, I'm pretty terrible at painting letters or I'd have probably just abandoned the laser cut stuff and painted.
   However, at the end of the day (though they're not perfect) I think they're pretty darn close. Of course the macro-lens shots show all the flaws, and I overall, I think it looks better to the naked eye than represented here with the super macro lens.
   Next step was to create a cap rail along the transom so it would match the rest of the ship.  I'd seen builds with and without this rail, and although I knew it'd be a bit of a challenge to get right I wanted to give it a shot.  I started by thinning out a 5 x 2 mm strip of basswood and soaking it, then using a hair dryer to bend and mold it along the curves. I used the gel gorilla glue CA to glue it down as I went along.
Peg_382.thumb.jpg.502fd33ae690225a9156c12f882731dd.jpg Peg_383.thumb.jpg.3bc30cdf1eca80d5d6c4a376f06c38f2.jpg
   It was a pretty slow delicate process not to dry it too quickly and snap the wood, but it was worth it in the end.  After some trimming of the edges toward the bottom where it meets the wales, a little bit of filler in some gaps, and sanding it was ready to paint.  After it's all said and done, I am pretty pleased with the overall results.
Peg_384.thumb.jpg.35238038e638edf79d54d68ec7e0e4c1.jpg Peg_385.thumb.jpg.9e5cf111b2e7db9905701bfc2f4522f2.jpg
Edited by Moonbug
Really neat finish Bug, that cap rail worth the effort I think, finishes it off well. 👍
Andrew
Completed (Kits):-
Thanks for the comments gents, and the likes from everyone.  Definitely didn’t know how that was going to go.
   Short post on the stanchions and guard rails around the open hatches. The long eye bolts weren't going to cut it after seeing some of the cool things other folks have done on their builds.  So I fabricated my stanchions out of these T-Pins that I snapped off.  I wanted something with a pointy end that would facilitate mounting.  I then soldered some rings to them.
Peg_386.thumb.jpg.2536f247e52111599302412eff3d6fe1.jpg Peg_387.thumb.jpg.77c1652b7cb2cdd01a8687b33e61d2e3.jpg
   After running around trying to find tiny little beads or something to serve as railing toppers (including raiding my teenage daughter's stash of beading supplies) - I onIy came up with about half of what I needed.  So - I made the rest on my own by using half-dried clumps of acrylic paint, rolling them into tiny balls, and then letting them dry.  Then painting over them with Model Master enamel paint.  The toughest part was getting all the little balls perfectly round and the same size. Pretty hard to tell the difference if you ask me...
Peg_389.thumb.jpg.f68c3c7181cf179c4be5c8c70333dc72.jpg Peg_390.thumb.jpg.f68b7d810fbe6159ea8a37a2c87d9871.jpg
   For the railings themselves, I've seen metal/wire used and I've seen rope.  I decided to split the difference and use this pretty cool little cable wrapped wire I had lying around.  Yup - I get this probably isn't accurate; but it definitely falls into category #2 of my aforementioned rating system:  "probably not completely accurate but looks cool."
  Peg_391.thumb.jpg.28f9a9b3dd854bd5d2068670b2405883.jpgPeg_392.thumb.jpg.4c67e47f5e96f4cc5e673dca599dae82.jpg
     It's been said before - we all strive for a certain degree of accuracy, but sometimes it's also important to remember that these are our pieces of art, and that often calls for some deviation for our own benefit.  Anyway - we all also seem to have our own "Mr. To-Scale Guy" with whom we test our sizes, etc.  My guy comes from an old S-scale (also 1.64) Train set.  He looks like that cuz he was pushing a lawnmower at one point.
  On another note - these macro shots remind me that I'm going to have a lot of dusting and cleaning up do do.  Sheesh.  Either that or I need to just start using a crappier lens.  😆
Beautiful model you have going here Bug.  Your approach to the various enhancement definitely adds to the period authenticity and well worth the extra time and effort.  Your observation is spot on about always needing to think ahead is rule #1, rule #2 being (for me at least), don't permanently attach something unless you absolutely need to...which help mitigate #1 above
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
  Thanks Jason.  And man... I am SO bad at #2...
Really quality work here, Bug! A real joy following along in your log.
Pete
Pete
      Thanks so much Pete - appreciate the encouragement.
      The ship's wheel is @Chuck's kit from Syren which I've worked with before on the Confederacy and is a real joy to put together.
Peg_394.thumb.jpg.a7cd1ecd4e09b7827d9350988b349f70.jpg Peg_395.thumb.jpg.b954680097e38f56e9e0a17beb35202d.jpg
Peg_396.thumb.jpg.57f76f5f97da1977a20ce28812862c51.jpg Peg_397.thumb.jpg.ee1010e2bf1968e23baf74988eb2bc6e.jpg
      I tapered both ends of the spokes using a variety of needle files and sanding sticks and I cut off a toothpick to run through the center of the jig which held the hub and helped hold everything steady when I put it all together.  The toothpick also helped quite a bit when sanding down the sides as thin as possible. I cut the outer circle pieces into several pieces to more mirror the look of the wheel from the FFM.  Finally, I added some simulated treenails (as Chuck suggests in the directions) for an additional detailed look by using the drill/fill method with pva and sawdust.
Peg_399.thumb.jpg.456436edcf17e22bda09f5c001c63ac2.jpg Peg_400.thumb.jpg.d4584b61343e7dbc967a137f2c979b22.jpg
Peg_401.thumb.jpg.dbb600c85e32460fc7148642ef5c570a.jpg Peg_402.thumb.jpg.a5e7efdbdbac7d3a0610a44070f307dc.jpg
Edited by Moonbug
Hi Bug,
Crazy good work! I’m new to the site and just found your log. Question for you. Way back when you got started, why did you do so much deck work etc. instead of moving right into the hull planking? Was it the instructions or your experience that motivated the direction you took? Like your work and am going to watch, especially when you get into the rigging. I have contemplated this ship for a future endeavor.
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
43 minutes ago, glbarlow said:
I like your hold down brackets for the mill. Where did you get those?
   Thanks everyone for the comments. Glenn - They came as an addition option along with the "X-Y Table Attachment" when I ordered the drill press from Mico-Mark.  They're pretty darn handy.
   Hey Dave - I wish I had a better answer than this, but - I get bored. Hull planking is super challenging and tedious for me, and I much prefer doing deck work and fixtures.  So I basically bounce back and forth between the two to keep me occupied. Especially since when I plank, I soak and shape the planks against the hull to let them dry (as opposed to using a bender or heat source).  The deck work gives me something to do while I'm waiting for hull planks to dry.
57 minutes ago, Landlubber Mike said:
That wheel looks a lot nicer (and more in scale) than a lot of the pre-fab wooden wheels out there.
   I agree Mike - Chuck does a great job and the boxwood lets you work with it a bit to shape it the way you want.  He has two different scales - one that's pretty dead on for 1/64 and a slightly larger one that I haven't seen in person yet.  The only challenge for me is getting the laser-cut char off without reshaping it too much in the process.
Edited by Moonbug
  Thanks BE - I think you'll find the Syren ship wheel kit very user friendly, particularly for a builder of your skill.
     Continuing work on the wheel - the barrel is turned on the Proxxon lathe to form the base, a small ridge, and two ends that will fit into the wheel and the stanchions. The stanchions are carved boxwood - sanded and shaped, then given some texture down the center for a decorative flair. The funky looking "V" shaped piece in the picture below was the stanchion provided in the kit which does not conform to what I've seen in the Swan class documentation, however I used it to ensure proper scale. The assembled wheel is initially positioned on the deck to check size and fit.
Peg_404.thumb.jpg.fd5101b02260011e7b35bdc9fa32bbc3.jpg Peg_405.thumb.jpg.4f413cc5aecc6c991ef9996cde6ec2db.jpg
Peg_406.thumb.jpg.80ec7f278ef09e50eeddbb2f4f9be6a4.jpg Peg_407.thumb.jpg.36a1c40ebb36ec4532cf2a4b249f0476.jpg
 I ditched the kit tiller as I've ditched most of the plywood-esque pre-fab stuff because it's quite thin and delicate.  My tiller is a pretty basic piece cut and shaped from 5mm x 5mm piece of walnut and notched at the base to fit the rudder and eyelets on each side of a metal band at the head.  I shortened my tiller a bit to facilitate the space between the wheel and the binnacle (more on that later) and gave it a little curve for no specific reason other than aesthetics.
Peg_408.thumb.jpg.31f5eba696fd5339206860dfc1a632c1.jpg Peg_409.thumb.jpg.5fbf5e0212c7ec80f04a20d0b87994a8.jpg
  For the rigging I used .6 mm rope (since I imagined it needed to be pretty hefty stuff) attached to boxwood blocks from Dry-docks Models - they looked interesting so I wanted to give them a shot.  Honestly - I'm not thrilled with them, but they served their purpose here. The rope is wrapped around the wheel barrel five times then through the corresponding set of blocks on the other bulwark. The wrap is attached to the barrel with a bolt stopper - another TINY (.020") bolt from micromark that I used on the rudder.  Very difficult to get into place without getting glue all over the rope and discoloring it.
Peg_410.thumb.jpg.e73aff4dca09e6664a33451f9e980adf.jpg Peg_413.thumb.jpg.49a63de2fbb41dc05e105ca3bd69a108.jpg
Peg_412.thumb.jpg.44c6672ade9a8839e09232deaa7ed8e9.jpg Peg_411.thumb.jpg.2ec71093d57373ad34523f7685a182e0.jpg
    The wheel is permanently fixed into position along with the binnacle that was finished earlier.  One thing I wanted to ensure was that there would be sufficient space between the binnacle and the wheel for the helmsman to stand and maneuver.  I've noticed that this little spacing detail is something that is often overlooked (or poorly accounted for) in many plans and builds.
    Finally, the rudder head housing it put together with boxwood and veneer strips to match the look/feel of the carriage house just on the other side of the mizzen. I shorted and reshaped the housing to account for my wheel / binnacle spacing as well as to ensure I had enough room between the rudder housing and the stern to put an ensign staff clamp.
Peg_415.thumb.jpg.a97a1e46a7c27210480326e60ab9594d.jpg Peg_414.thumb.jpg.29a0abc2c755377aa47610d7f54e2d05.jpg
