The only problem is that the ring size is fixed.  The 1.5 mm looper makes ringbolts with a 1/16" ID.  That's 3 scale inches at 1:48 scale.  Almost perfect for rigging cannons etc.
https://www.amazon.com/Beadsmith-Millimeter-Consistent-Bracelets-Necklaces/dp/B00BOZ79UO?th=1
 I decided to use a single treenail at each joint on the grating because I thought the two diagonally placed ones might be too busy looking.  These are not actual treenail…just marks in the wood made with an awl.  The effect is subtle, which is what I was going for.  The hatch coaming is bloodwood.  I added the capstan step bolts and made up the step brakes and installed them.  I decided to add some deck planking.  The wood is hornbeam.  Pale like holly but with a slight gray cast.  I kind of like it.  The only thing left is to finish up the drumhead on the capstan and add the bars.
Looks great!
Toni
Member IPMS
                           Utrecht-1742
Superb realization! A new little gem! Thank you for sharing this beautiful build log.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Nicely done. I particularly like the deck planking as a personal touch, and it also helps the casual viewer understand the context a bit more. Wish I'd thought of that!
I just returned from Manitowoc WI where I attended the The 45th annual Model Ships and Boats Contest. I entered two models: The British Capstan circa 1777 and the HMS Blandford cross section.  I'm pleased to report that each model won a Gold Award! Thanks to Mike Rohrer (Mike41) for his excellent plans for Blandford and to Toni Levine et.al. and the NRG for the Capstan project.
Congratulations.  From everything I've ever heard,  Manitowoc has some stiff competition at their show.  And you did a double win.   Even more impressive.
