spoken like a true pack rat!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The brick platform for the stove has been completed.
I decided to create a base for the (individual) bricks inside the coaming.  The base is 1/32" balsa sheet, painted grey:
3/32 x 1/32" planks were then painted two colors and cut into 'bricks' as seen below:
The ends of the faux bricks were touched up and then laid individually:
It's not perfect,  but I'm pleased.  About 60% of the platform will be covered by the stove itself.
Next on the agenda is the checkerboard floor for the Great Cabin....as per Ben's 'suggestion'.  Though this may require Divine Intervention, I'll give it a shot.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Nice work Augie, the bricks look great
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Wow! super job on the brick work Augie, great way to do them ... they look real !
Frank
Thanks all for the comments.  But Frank ...... I'm Italian.  My birthstone is concrete.
Augie
Previous Builds :
   NO wonder it came out so good......... I forgot about  the heritage thing... I should've know  :D
Edited by riverboat
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Fantastic job on the brickwork Augie - but then again, should we expect anything less from you? ;) Well done Sir!
nice job on the brick work Augie........thin enough so that you wouldn't need to add mortar around them ;)   I really like the pattern....sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nicely done Augie, could you send some of those bricks to Rome mate, most of the building are falling down over there.
Keep that high quality coming mate.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Very nice Augie! Isn't amazing how we create something like that and then cover most if it?  :o
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Well done on the bricks and great tutorial for doing those.   I can't wait to see how your checkerboard deck will turn out.  Probably somewhere between great and fantastic?
Yes, we must be a bit daft spending inordinate amounts of time on things that will later be mostly concealed.....but we know they're there.
Now, where do I sign for the exchange of bricks for gun carraiges  ?   :)
Augie
Previous Builds :
Great job on the bricks Augie. A little sanding dust in the joints for mortar will really make it pop. As for the checkerboard pattern in the great cabin....I used some glossy finished card stock with good results.
Nice job mate.
Dave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
Psst.. how many bricks?  I know a guy who knows a guy....  post-76-0-71594300-1403756888.gif
com'on Augie.........you can do the individual tiles.........I did it for the dance floor on the M&M build :)   cutting all those tiles........making sure that they are square.......the painting.  you only have two colors......piece of cake!   :)
I still have some of the tiles........I can send them to ya!  ;)
if your going to use the open concept in there,   as well as clear windows,    you should be able to see them to some degree :)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Your bricks look very realistic! Excellent job!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
After considering several methods of creating the Great Cabin floor, I decided to use Chuck's method.  In my experience, doing so is never a bad idea!
The floor will be made from walnut and boxwood 3/16 x 1/32" strips.  A paper template of the area to be covered was made and a piece of 6 x 6 x 1/32" plywood was used as the base.  First, the strips were cut to approximate length and glued to the plywood base:
The curvature you see is created by the camera.  Next, a jig was made in order to create 3/16" strips to be cut with an Exacto blade:
The individual strips were then cut:
The strips were offset and then edge glued together to create the pattern:
The paper pattern was then used to cut and sand the floor for a tight fit.  Here's what we got:
Finally, just some overall shots.  The floor was finished with natural stain, WOP for protection and Dullcoat to give a flat finish:
Although most of the floor will be covered by the (open) upper decking and deck beams, I think we have a nice overall detail.  I'm pleased  :)
Will be closing the shop for the upcoming Holiday festivities (Happy Independence Day to all of my fellow Americans).  When we return, the strains of DECK PLANKING music will be heard in the Rockies.
Oh, we have just passed 600 hours into the build.
Edited by Augie
Augie
Previous Builds :
