9 hours ago, Danstream said:
As said, not much to show. However, I finished another model I was working on and OC showed some interest in it, so, if you don't mind, I would like to propose few pictures of it. The subject is the small Italian tactical jet Fiat G.91 R and the kit is the very old Italeri/ESCI kit in 1:48 scale. This is a moody picture of it quickly taken on the sill of my window in a rainy day:
That photo is, IMHO, fantastic.   Looks to be the real thing sitting on the apron just after the rain has stopped.
That is dedication to re-scribe all the raised panel lines, but I has paid off, great looking model.
Andrew
Completed (Kits):-
Thanks Mark! That's the reason I took that pictures. I had momentarily put the model on the sill and it looked so cool that I quickly took a picture of it.
Thanks Andrew, I spent an awful lot of time with that model, I also riveted it, enlarged the diameter of the rear fuselage, added new vortex vanes, etc., etc.
Practically there wasn't a single piece of the kit that I didn't not scratched or modified. But at the end of the day, I was quite satisfied with the results.
Dan
Edited by Danstream
Back to my Tempest, I finished the office which took some time because composed by many small parts and photoetched included in the kit. Cradle made of tubes, typical of Hawker of that period (stressed skin, frames and stringers from the tail to the cockpit rear bulkhead, tubular truss for the cockpit to firewall and engine bearer made also with a tubular truss).
Unfortunately, I forgot to thin the edges of the seat which are obviously too thick. Now it is too late and I will have to live with that. Then, the nice photoetched IP made of five parts:
(excuse my big fingers dirty of paint). The cockpit posed inside the fuselage:
Probably, not much will be seen once the fuselage is closed up. This is a dry fit:
That is all for now, preparing the chin radiator that needs to be included when closing the halves.
Cheers,
Dan
On 3/3/2023 at 9:13 AM, ccoyle said:
I'm really trying hard to resist adding this kit to my already overburdened card model stash -- your build log isn't helping! 😆
Hawker Tempest V (Halinski MM 1/2013), 1:33 paper model, maybe good for RC  1:16 conversion. | Бумажная модель, Военный самолет, Бумажные модели
I may have caved in to temptation on this kit -- plus a few others. 🤫
Seems reasonable as I remember an old saying about "it may not come your way again".
15 hours ago, ccoyle said:
Yes. I might have purchased this kit -- and a P-47D-11, Curtiss SB2C, and Fw-190 Sturmbock. Maybe. Possibly. 😬
Can't wait not to see your logs you won't be doing😁
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Dear all, I am not very responsive in these days, because I am busy with my 'other' work and I will be also busy with repainting the rooms of the house (which FS no. I am going to use, you might wonder). Hence, my modeling output rate, which was anyway very slow, will go down to zero for the next couple of weeks.
I will continue to read about your progress though.
Best regards,
Dan
Hi, I resumed my Tempest and made some little progress. I bought the Eduard resin for central circular radiator which really is a fine addition to this nice kit.
Cockpit completed and all the necessary elements were painted and added to the half fuselage.
Finally the halves went together with no problems:
That's all for now, wing will come next.
Cheers,
Dan
13 hours ago, Javlin said:
Looking good Dan these crates look like the English version of the P-47 ...Brutes!!;)
Thanks Javlin. Indeed, lot of power, lot of striking weapons.
I went on with assembling the upper halves to the lower part. Note the nice details of the landing gear wells. The trailing edge of each wing is part of the upper half. While this solution gives a neat trailing edge, the junction line, which is now on the lower surface, needs some care.
Here, the right half is still untreated, while the left received some Tamiya putty to conceal the junction line. After sanding, this is the result:
I restored the rivet lines that were obliterated with the tool shown above. Other minor filling were required on the forward parts of the fuselage, while the rear part is just fine with the glue oozed from the junction which will require only some sanding.
Inside the air intake of the chin radiator, there was a tiny gap left which I filled with water based Vallejo filler. This is ideal for these small corrections which are in areas difficult to access. In fact, you can simply clean off the excess with a wet cotton swab without the need of any sanding.
Once the wing was finished, I glued it on the fuselage. However, there is a problem with the junction on its lower surface, close to my thumb in the picture below:
The problem is with the surface of the split flap which should be an uninterrupted rectangular part. Instead it is crossed by the fuselage-wing junction lines. I will address this detail next, by filling the gaps with stretched sprue wires.
To the next instalment,
kind regards,
Dan
@CDW, yes the molding of the kit is really good, it is a pleasure to look at. Perhaps, the tri-dimensionality of the details might be a tad overdone, but it looks extremely good. The riveting tool is a 'RB Production - RB-T010' (https://www.aviationmegastore.com/en/modelling/rivet-r-mini-rivet-tool-rb-productions-rb-t010-90405.html)
It is quite cheap and works reasonably well. You have to use the tool head with a normal blade holder.
Kind regards,
Dan
I wonder why they did it that way, most kits make the full flaps integral with the bottom wing, easy fix I know, but it shouldn't be a fix at all.... Sure would complicate things if you wanted dropped flaps...
Not only the fill, you have to rescribe the rivet details.....
Sometimes I just don't understand the engineers that design the molds like this.... Makes no sense...
Edited by Egilman
Quote:
1 hour ago, Egilman said:
I wonder why they did it that way, most kits make the full flaps intergral with the bottom wing, easy fix I know, but it shouldn't be a fix at all.... Sure would complicate things if you wanted dropped flaps...
Possibly some sort of management decision due to budget constraints on the design team?
@Egilman, @mtaylor, I don't know the reason for splitting the parts like that. I could think that that might easy the design of the molds or avoid problems of production. Anyway, in one of their aftermarket lines, Eduard offers a flap replacement for those who wants to pose the flap deployed. This flap is a metallic, rectangular panel and the molded parts on the kit parts need to be cut and removed. I might consider that for the next Tempest (I have also a Tempest mk II to build, which I would like to finish with a High Speed Silver livery).
Kind regards,
Dan
Edited by Danstream
Looking really great Dan!
I think Barracuda makes some replacement parts that specifically addresses some of the odder design choices.  For example, if I remember correctly, they made some replacement flaps because the way Eduard designed theirs, a lot of the detail had to be sanded off.  Same thing with the Eduard Spitfire - Barracuda makes a bunch of parts to avoid things like seams and other things.
The better/best  way to fill a seam
You mean they fired the A-Team :D
That would be saasweeet I almost traveled that road with the Tigercat on the table now just because I have never seen one before and the excuse would be "it has hit the paint booth yet".Nice work all around Dan I have the Revell/SpecialHobby 1/32 in the stash.
Hi, just to show you my progress on the split flap repair. This is how it looks after filling with sprue, filler, engraving new lines and rivets:
Actually, it is not easy to see the result, hence I sprayed some Surfacer to get a grey, uniform finish:
Getting there, but the picture close up revealed few blemishes that I still need to address (I also made an incorrect rivet line).
Best regards,
Dan
Geese, I'm going to have to up my game when I return to the bench.... Simple plastic hacking ain't gonna cut it anymore....
Beautiful work Brother... Beautiful work...
Quote:
Hi all,
life keeps me away from the hobby room, hence I have only few progress to show. I have completed the assembly of the airframe and glued the last left fishplate. Here, the wing root junction filled with a very thin sprue wire.
The nice interior cockpit will be practically invisible when the last closing part will be glued on. The tail surfaces were completed with the controls in their neutral position. I moved only the trim tabs slightly.
Finally, masking with the provided masks for the transparent parts and with kleenex tissues for the rest in preparation of the primer was also completed.
After spraying a black primer, a black beauty emerged:
IMG_0061.thumb.jpg.773f555f017f68fbe6dfbab47a4613ed.jpgIMG_0063.thumb.jpg.86c11c966802d3b9329b245349b1b15a.jpg
I will have to fix few blemishes before progressing with the paint, but the paneling and riveting is very noticeably good.
I am progressing slow because of my work that after about twenty years will bring me again in the States, in Florida, on the second half of June. I am very excited about that.
best regards,
Dan
On 5/14/2023 at 7:16 AM, Danstream said:
Hi all,
best regards,
Dan
She looks real nice in primer, Dan.
Where will you be in Florida, what city?
Hi all,
few more steps with the Tempest. I started to lay down the first layer of sea medium gray on the bottom in a semi-random pattern to create tonal variations.
I realized that it is better to put on the various lights at this stage (actually, perhaps it would have been better to install them before closing the wings). I sanded them flushed with the wing surface and polished them to restore their transparency.
After that, I switched to the white areas that will be required for the invasion stripes. I chose one of the scheme with the full invasion stripes which, although more complex to paint, is in my view more spectacular.
I wanted a slight off-white hue, so I added a bit of grey to the white paint and I kept the layer transparent so to let some of the black to be seen through (although the effect is not very noticeable in the pictures).
As said earlier, the surface details of this kit are very good and this can be noticed on the painted surfaces:
However, the kit has also some small drawback that I discovered during the assembly, but overall I am quite pleased with it.
On 5/19/2023 at 2:11 AM, Javlin said:
Looks good Dan I have this kit coming tomorrow.;)
Great, you will enjoy it, when you start with the cockpit, pay attention with the truss structure of the cockpit, it can break just looking at it.
Hi Craig, I will be located at (or close to) Cape Canaveral.
Cheers,
Dan
On 5/20/2023 at 7:24 AM, Danstream said:
Hi all,
Very nice!
