Mitsubishi A6M5a Rei-sen by ccoyle - FINISHED - Halinski/Kartonowy Arsenal - 1/33 - CARD - Allied code name "Zeke"
Milestone Reached
The cockpit sides are complete! The only cockpit element left to install is the gunsight, which is a ridiculously delicate 3D-printed piece and will therefore be added much later. I wrestled with whether to add some more details that are not included in the kit, e.g., the elevator trim contol cable on the left side and the mass of cables and tubing on the floor along the right side (plastic kits typically have these elements molded in). I'm leaning toward not adding these details because:
  • They would require a lot of extra work.
  • There are no templates for making them.
  • To see them, a viewer would have to pick up the model in order to peer into the cockpit's inky depths.
  •  Anyone who dares to pick up one of my models risks being on the receiving end of bodily harm.
That last one clinches the decision, I think. Here are some final interior photos -- the next step is to glue the sides to the cockpit framing. 😮
What a gorgeous model, Chris. You really have the card models building down to a science. It's amazing to me how realistic the card models you build turn out. In my opinion, they look better that 99% of traditional, injection molded kits. Maybe in part that's due to the precise and beautiful color of the printed card, but mostly due to your skill in building it.
Thanks, Craig! I've gone bright red! It's interesting to compare building in card to building in plastic. The best plastic modelers are the folks who are skilled at airbrushing and weathering. A good card model has those effects already printed on the kit parts, and the hard part is cutting, shaping, and making tidy seams. I'm still nowhere near the talent of the best card modelers from Europe, but I keep trying!
Beautiful work Chris!  I've probably said it a dozen times before on your logs, but it's impressive how you can manage the complicated compound curves.  This is looking really great!  The aftermarket will really kick it up a notch!  It's nice that the AM is from 3D printing, as resin parts can add considerable weight.
I'm realizing that the nice thing about these card kits is that you can horde them and have a stash 5% of the size of a similarly numbered plastic/resin/ printed kits.  On top of that, you don't necessarily need to outfit yourself with an airbrush, compressor, spray booth, etc. - things that take up a lot of space.
Too modest Sir, you're great! Love following your builds ☺️
Walter.
Current build: HMS Ariadne 1776
Finished build: HMS Flirt
I disagree totally with that statement.  Your work is stunning.
Moving on to the wings. The wing framing is built around a single main spar. Wicking CA into it seemed sensible.
And here is the finished framing.
The kit includes optional parts to show the model with flaps deployed, but since flaps typically aren't deployed while an aircraft is on the ground, I will be displaying them raised. And besides, adding the flaps adds a large number of fiddly parts.
Here, the main wing skins have been shaped and trial-fitted. Still work to do before they get glued on.
12 minutes ago, CDW said:
By now, I have collected a large number of Halinski kits and have yet to try a start on a single one.
Craig, I don't remember you having built any card models? Attempting a Halinski build as a first effort would be a real challenge. Some of the newer WAK skill level 2 kits look like very good models for newcomers, and they typically have excellent artwork. I keep thinking about doing one of them -- I probably should, just to see how they go together and evaluate their suitability for beginners.
The first Halinski kit I built successfully was their Polikarpov I-16, and I don't recall having any issues with it.
No, I have only started one (a brand I do not recall) and it was a disaster. I will look it up and try a WAK skill 2 kit as a first try. Thanks!
Craig, I have the following WAK Skill Level 2 kits in my stash. Check them out, and if you want to do a "group build" of one of them, I'd be happy to model the process for you using that kit -- modeling how to build a model, hah! I'm probably not the first person to think of that. The kits are all designed by Lech Kolodziejski -- I've built five of his designs.
SBLim-2
Moran-Saulnier 406C1
Bloch MB.152C1
I order directly from WAK using PayPal and have always been happy with their service and shipping rates.
SBLim-2
Bloch MB.152C1
Agreed! I just ordered this one: SBLim-2
I will let you know when it arrives.
OK you two, now you've got me involved as well 😁😁😖. Just ordered the kit plus canopy plus laser cut pieces. I may be slow as I'm part way through building Harpy. Cheers.
Edited by Richard44
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Before skinning the wings, the landing gear bays must first be added.
Then the main skin is added. I don't glue the entire thing at once -- I tack the center section first to get everything aligned, then work around each half a bit at a time. The fit has been super tight, but good.
You don't get to see the bottom yet, because I still need to do the seams around the gear bays.
Cheers!
The wing and fuselage have been joined, and the first of the two wing fillets has been added. There's a bit of a goof on the fillet where I had to make a repair after inadvertently rubbing some of the printed color off the part. I'm going to say that this is where some Japanese technicians applied Bondo on the original aircraft.
In the meantime, look what came in the mail!
WAK's 1/100 Brig Badger designed by our friend Tomek of Seahorse models.
A 2-for-1 special edition from Shipyard of a Swedish Yacht and the schooner Berbice.
And the very odd US Navy one-off USS Vesuvius armed with "dynamite guns." This one is from Orel.
I purchased these kits from a very special acquaintance of mine, David Okamura. David and I were members together of the Ship Modelers Association many moons ago, and he's the guy who introduced me to the amazing world of card modeling, so you can blame him for all of the card subjects I've dropped here at the forum.
Cheers!
The forward fuselage has been added. This cylindrical section was quite a booger to shape properly. You can see there is a small gap along the left-hand white part labeled 'WPS' -- fortunately, that stands for "cut out after gluing," and that is where the machine gun channels will be added, so the gap will magically disappear. Forward of this (which comes later in the build) will be interesting, because next there is a bulkhead that supports the cowl, and the kit's paper exhaust pipes are supposed to be glued directly to this bulkhead; the 3D-printed pipes are longer and should ideally pass through this bulkhead and attach to the cylinder heads. I will need to do a lot of thinking about how to make that assembly work.
The next assembly according to the parts numbering is the aft-most fuselage section where the tail wheel well is located -- the fuselage is thus supposed to be built back-to-front. Not sure why that is, but I will probably build up all the sections first just to play it safe, then assemble them together in the correct order. First up is the section right behind the cockpit. Right now I am letting everything set after gluing the ring together and soaking the bulkhead in thin CA. I've punched a couple of holes into the bulkhead so I can manipulate it with round-nose pliers.
Cheers!
The usual robust framing in a Halinski kit, this time for the aft fuselage. The tail wheel well includes a piece with the interior color.
And now for a bit of news: This build will be going on a temporary hiatus. I know I already have another kit on hiatus for this build, so I guess that makes this a hiatus²? 🤔 Anyways, I will be building WAK's SBLim-2A, which shouldn't take too long to build (hopefully). A build log will be created for that shortly.
Cheers!
So, after completing the SBLim and taking a week off to travel and visit family, the Zero is back on the bench!
The aft fuselage is now skinned. A little tricky, as you can see that the forward-most skin tucks underneath the vertical stabilizer, the middle skin rides up the sides of the stabilizer, and the aft skin tapers to a sharp ridge leading down to the tail light. On the underside, the skins must align with the tail wheel well and the tailhook recess.
That's all for now!
