Licorne by mtaylor - 3/16" scale - POF - TERMINATED LOG
Because of the bow flare, the plank does have to be spilled to sit properly. As it twists, it will widen considerably in order to keep the planking run looking 'sweet'.
Edited by druxey
Link to comment
Share on other sites
If it's any comfort, I know what you're talking about.  (Still takes me a second to remember your photos are 'upside down').  Confed has a similar, but much less pronounced, outward flare in the same area of the fo'csle.  But because it's much less pronounced, it is handled by letting the planks follow the lower run and then sanding the top curve to gently blend in to the sheer line. I also spiled it slightly.  I think this is where you are at now.  I remember thinking that, if my situation were any more pronounced (like yours is) it would be a hell of a problem.  And I had the added advantage in that I knew that from the point at which the flare began I'd be painting upward to the rail so some 'creative sanding' blended everything together.
That said, I really like Hahn's solution with the wider plank.
Good luck Mark.  I know you'll figure it out.
Edited by Augie
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Ebony is beautiful, but very difficult to work with....good luck with it Mark...
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Link to comment
Thanks one and all....  I'm still thinking something similar to a stealer method since it shouldn't be just one very wide plank.  Druxey, you're right though.  And no matter how I look at it, I'll have to spile at least one plank. It might even take 3 planks forward to cover that flair area.
I'm still testing, filing, and mentally working on the final solution.
Link to comment
Looking forward to seeing the fix Mark, I am sure it will be something I will want to remember for for future builds, so don't leave me hanging too long :P
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Link to comment
Sam,
Wiping, I think, would be preferred.  The piece I soaked still has the acetone smell is now out in the garage.
Link to comment
Great looking build.  I'll keep watching with interest.  I'm still mystified by scratch builds.
- Bug
Link to comment
Sam,
It's still straight.  :) Once there's no smell, I'll try using it on something.
Bug,
It's big mystery to me also. :D  :D
Meanwhile, back in the shipyard.....
I think, hope, pray, that I've hit on the final solution to the exterior forecastle bulwarks.  After realizing that doing the same thing over and over again again expecting different results is insanity, I went for something just a little bit different.  A combination of spiling and stealers!  No, wait... I was doing that.  :(
Change the wood.. YES!!! Change the dimensions of the wood... YES!!!
Went from plum which I wasn't plum crazy about anyway to cherry.  Change the dimensions from 4" X 9" to 2" X 12".  The wood is more flexible and less grainy than the plum and a nicer color.
After playing with some designs and feeding the scrap box, there's now one main strake that runs the 30 feet of bulwark.  And two stealers to help make the transition in the flair.   The next set pics (in the next several days) will show it fitted and glued in place and hopefully sanded.    By the way, try to ignore the pencil marks.... Oh...I guess I better make the one for the other side while this is still fresh.
Link to comment
Good solution - can't wait to see it in place.
- Bug
Link to comment
I have to learn to stop re-inventing the wheel.  There was reason why Hahn did it the way he did it.  I've scrapped out all previous methods and did his way.
First, I spiled a piece of cherry (2 feet wide X 4 inches thick).
Then made Mr. Clamp to get the curve.
I soaked the wood for about 12 hours and clamped into place.  I ended up with all the curves and bends in the right places.
I can live with this.
Now to go glue them in place and get the ebony trim fitted and fixed into place.
Link to comment
Done... on the port side at least. I'll finish up the starboard side and then attack the quarterdeck outer bulwarks.  Thank heavens they're not as radically shaped.  I do, however, really hate macro as I see some things that need fixing before final sanding, like a few gaps in the planking.
Link to comment
That was a crazy bend.  Well done.  Oh and what gaps are you talking about my untrained eye didn't see any.   :P   Great work Mark.
Link to comment
Thanks John and Daniel and those who "liked".
Daniel,
Trust me.. they are there.  :)
Link to comment
Marc
Looking your topic I say to myself
  • Watch and learn
  • And the watch and learn again
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Marc
  • Watch and learn
That makes two of us.  I'm learning as I go.  I just wish learning wasn't so hard at times.
Link to comment
Great result Mark. See, I just knew that you'd come up with an inspirational solution! :D
Gaps? What gaps? I see nothing! (To quote SGT Schulz......if you remember that show......)
Link to comment
Nothing wrong with improving the tires Mark.  Just leave the wheel alone :D
Really nice work.  Thanks for sharing the problem, thought process and solution with all of us.
Augie
Previous Builds :
Link to comment
Gaps?!? You are seeing things my friend! Nice fix, and glad it all worked out for you...nasty bend, but the result is what counts!
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
Link to comment
Isn't that always the way...   You look at something and wonder why it was done that way, then when you try and do it yourself you find out exactly why.
Nice result.
Colin
Current Builds: HMS Pandora 1/64 Scratch
                         Jeannie Johnston;
                         18thC Longboat with my son
Previous Builds: HMB Bounty - Caldercraft
Running Round my head: HMS Speedy (1782) - vaguely thinking POF
"If at first you don't succeed, try it your wifes' way"
Link to comment
Pedrsistence pays off :) -that is is serious shaping Mark with excellent results.
cheers
Pat
Link to comment
Thanks for the kind words everyone and the "likes". I finished the starboard side and it looks good to my eyes also.  And more importantly, both sides match when looking straight on.  :)
Thanks Grant, err...  Sgt. Schultz.  I've come to the conclusion that we are our own worst enemies as well as critics.
Thanks for that Augie.  I'm not going to guarantee it's right but I did what seemed to work.  The shipyard is sometimes a lonely place.
Link to comment
That's a great fix Mark, you've had some difficult angles there and you've found the right solution, sometimes it works in our favour to be our worst enemies and critics.
She's coming along nicely mate, keep it up.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
I took a picture just check everything...  things need trimming up front and some cleanup but there's no rush until I get the beakhead deck and bulkhead installed in the future and get test for fit, etc.
Oh..looks like it needs more sanding.. I think the expression is "pfffffff". :P
Link to comment
Never enough sanding. Always seem to have it little more with little higher granulation of sandpaper ...
In progress:
Content of log :
Past build:
Link to comment
looking sharp Mark.......but you might want to check that rail at the starboard bow.......looks like it crept up a little on ya.   I can't wait to see the hull completely planks.........she's gonna look sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
